Snygga upp koden
7 svar · 266 visningar · startad av medialabs
hej!
Skulle nån vilja ta sig en titt på denna kod och se om man kan snygga upp i asp koden.
<!-- #include file = "../inc/adovbs.inc" -->
<!-- #include file = "artikel_losenord.asp" -->
IF Request.QueryString("alt") = "login" THEN
	IF Request.Form("losen") = losenord AND Request.Form("anv") = anvandare THEN
		Session("access") = "YaHoO"
	END IF
END IF
<body bgcolor="#FFFFFF">
<p align="center"><font face="Verdana" size="6">Artiklar<b><font face="Verdana" size="1">
<script language="JavaScript" type="text/JavaScript" src="../js/funktioner.js"></script>
  </font></b><br>
  <font size="1"> <font size="2">Administration</font></font></font></p>
<%IF Session("access") = "YaHoO" THEN%>
<div align="center"></div>
Connect.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & server.mappath("kontakter.mdb")
IF Request.Querystring("alt") ="del" Then
SQL = "DELETE * FROM kunder WHERE ID = " & Request.Querystring("id")
Connect.execute(SQL)
Response.Redirect "artikel_admin.asp"
ELSE
SQL = "SELECT * From kunder ORDER BY Kontaktperson"
Set RecSet = Connect.Execute(SQL)
DO UNTIL RecSet.EOF %>
  <tr>
    <table width="300" border="0" style="border: #330099 1px solid" align="center">
      <td>
          <table border="0" align="center">
            <tr>
              <td>
                <div align="center"><b><font size="1" face="Verdana">Artikel</font></b><font size="1" face="Verdana"><br>
                  <a href="javascript:popup('las.asp?id=<%=RecSet("id")%>',500,500);"><%=RecSet("Foretagsnamn")%></a></font></div>
              </td>
            </tr>
          </table>
      </td>
      </tr>
      <tr>
        <td height="12">
          <div align="center"><font size="1" face="Verdana"><b><a href="artikel_admin.asp?alt=del&id=2" onClick="return confirm('säkert?');">Radera</a>
            / <a href="artikel_andra.asp?id=<%=RecSet("id")%>">&Auml;ndra</a></b></font></div>
        </td>
      </tr>
    </table>
  <font size="1" face="Verdana">&nbsp;&nbsp;&nbsp; </font><br>
  <tr>
RecSet.MoveNext
Loop
RecSet.Close
Set RecSet = nothing
Connect.Close
Set Connect = nothing
END IF
<%ELSE%>
<form name="form2" method="post" action="artikel_admin.asp?alt=login">
  <font size="1"> <font face="Verdana, Arial, Helvetica, sans-serif"> </font></font>
    <tr>
      <td colspan="2">
        <div align="center"><font size="1"></font> <font size="1"><font face="Verdana"><b>LOGGA
          IN</b></font></font></div>
      </td>
    </tr>
    <tr>
      <td><font size="1"><font face="Verdana, Arial, Helvetica, sans-serif">Anv.
        namn:</font></font></td>
      <td><font size="1"><font size="1"><font face="Verdana, Arial, Helvetica, sans-serif">
        <input type="text" name="anv" style="border: #000000 1px solid; font-family: verdana; font-size: 10px" size="15" maxlength="20">
        </font></font></font></td>
    </tr>
    <tr>
      <td><font size="1"><font face="Verdana, Arial, Helvetica, sans-serif">L&ouml;senord:</font></font></td>
      <td><font size="1"><font face="Verdana, Arial, Helvetica, sans-serif"> </font><font size="1"><font face="Verdana, Arial, Helvetica, sans-serif">
        <input type="text" name="losen" style="border: #000000 1px solid; font-family: verdana; font-size: 10px" size="15" maxlength="20">
    </tr>
    <tr>
      <td>&nbsp;</td>
        <input type="submit" style="border: #000000 1px solid; font-family: verdana; font-size: 10px" name="Submit2" value="Logga in">
        </font></font></td>
    </tr>
    <tr>
      <td colspan="2">
        <div align="center"><font face="Verdana" size="1">(<b>admin</b> p&aring;
          b&aring;da &auml;r f&ouml;rvalt)</font></div>
      </td>
    </tr>
  </table>
<% END IF %>
Du kan ju till att börja med skriva <%Option Explicit%> i början av dokumentet så att du måste deklarera alla variabler. Det ger en liten prestandaökning..
(Dim Connect, SQL....)
Medlem sedan jan. 2002286 inlägg
Det ger ingen prestandaökning alls..
Det ända syftet med att dimma grejorna är att man skall kunna felsöka lättare..
Dvs programmera med Explicit
du använder ju inget ifrån
Men jag har för mig att asp.dll hanterar variablerna snabbare om de finns deklarerade... Men jag kanske kommer ihåg fel.
Medlem sedan aug. 2002207 inlägg
Det har jag också för mig :)
Typ att den hela tiden måste kontrollera om varibeln existerar eller inte om man inte använder Option Explicit. Om man använder det så vet den hela tiden om varibeln i fråga existerar eller inte, därav en liten prestandaökning.
Medlem sedan dec. 20002 526 inlägg
snygga upp din kod med stylesheets ;) jakla massa font face.... och en del i styles i dina tabeller...
...och så blir det mycket lättare att ändra senare. Byta färger, fonter osv...
130 ms — deklarationer (db)
130 ms — ändringar (db)
