fel i strängar?
0 svar · 134 visningar · startad av LR^evil.sid
Medlem sedan maj 2002560 inlägg
jag har nu mera problem med variabler och ifsatser som inte gör vad de ska...
problemet är att ifsatsen går till else även fast variablerna är exat likadana
[red]	response.write "oldF: <br>|" & oldF & "|<br>dbFiles: <br>|" & dbFiles & "|"
	if cstr ( oldF ) = cstr ( dbFiles ) then
		response.write _
			"Det finns inga nya l&aring;tar sedan ditt senaste bes&ouml;k<br>" & vbcrlf
	[blue][b]else[/b][/blue]
		response.write "inte lika"
		arrFiles = split ( oldF, " " )
		for x = 0 to ubound ( arrFiles )
			addFile = dbFiles
			addFile = " " & replace ( addFile, " " & arrFiles ( x ) & " ", " " )
			dbFiles = addFile
		next
		addFile = trim ( addFile )
		arrFiles = split ( addFile, " " )
		response.write _
			"<table cellpadding = '0' cellspacing = '0' border = '0'>"
		for i = 0 to ubound ( arrFiles )
				set rs = con.execute ( " select dwn_file from dwn where dwn_id = "&arrFiles ( i )&" " )
				response.write _
					"<tr><td>*&nbsp;</td><td> <a href = 'files.asp?action=upone&id=" & arrFiles ( i ) &"'>" & replace ( rs ( "dwn_file" ), "_", " " ) & "</a><br><br></td></tr>"
		next
		response.write _
			"</table>"
	end if[/red]
247 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
120 ms — deklarationer (db)
118 ms — ändringar (db)
