Besöks räknare ? (Global.asa)
9 svar · 466 visningar · startad av Tobbster
Medlem sedan mars 2001309 inlägg
Jag försöker få en enkel besöks räknare att funka men det vill sig inte !
Koden ser ut så här!
Global.asa
<SCRIPT LANGUAGE=VBScript RUNAT=Server>
Sub Session_OnStart
' Start count script
        myFile = Server.MapPath("count.txt")
        ' create counter object
        Set objCount = Server.CreateObject("Scripting.FileSystemObject")
        Set myCountFile = objCount.OpenTextFile(myFile)
        ' check for counter cookie
        If Request.Cookies("counter") = "1" Then
                Application.Lock
                        Application("counter") = CInt(myCountFile.ReadLine)
                        myCountFile.Close
                        Set myCountFile = nothing
                Application.UnLock
        Else
                Response.Cookies("counter") = "1"
                Response.Cookies("counter").Expires = DateAdd("d",1,Now())
        Application.Lock
                Application("counter") = CInt(myCountFile.ReadLine + 1)
                myCountFile.Close
                Set myCountFile = objCount.CreateTextFile (myFile,true)
                        myCountFile.WriteLine Application("counter")
        Application.Unlock
                Set     objCount = nothing
End Sub
Sub Session_OnEnd
End Sub
Sub Application_OnStart
End Sub
Sub Application_OnEnd
End Sub
</SCRIPT>
på Sidan där räknaren ska visas !
<Html>
<Head>
<link rel=stylesheet href="mall.css"typ="text/css">
<title>Presentation</title>
</Head>
       <BODY>
       <h1>&nbsp;</h1>
             <center>
             <table  VALIGN="top" ALIGN="center"   width ="450" height ="450" border ="0" >
                    <TR>
                        <td VALIGN="middle" ALIGN="center" width ="450" height ="338"><img src="bilder/"></td>
                     </TR>
                     <TR>
                        <td VALIGN="top" ALIGN="left" width ="450" height ="100">Här kommer det stå massor med saker om K.I.B <br>
                        Eller hur !</td>
                     </TR>
                      <TR>
                           <td class="nav" VALIGN="top" ALIGN="left" width ="450" height ="100"><h3> Senaste Matchen!</h3>
                           Matchen mot VTI gick bra.<br>Den slutade 5-2 till K.I.B <br>
                           <a class="blacksmall" href="senastematchen.html">Läs mer om matchen....  </td>
                      </TR>
                      <TR>
                          <td>
                          [red]    <%response.write "Antal Besökare: " %>
                              <%=Application("counter")%>  [/red]
                           </td>
                      </TR>
               <table>
             </center>
       </BODY>
</HTML>
Global.asa
ligger i min root katalog på webhotellet där ligger även min count.txt.
Är det någon som kan se vad det är för fel !
Får inget felmedelande men det skrivs inget i textfilen och om jag skriver ditt en 1:a så får inte applikation variabeln det värdet ialla fall.
Nu är det så att om jag skriver en siffra i textfilen så visas det ibland !
Någon som vet vad problemet kan vara !
Problemet med att det inte räknas upp när nyabesökare varit på sidan kvarstår !
Inga felmeddelanden........
ehh.. en fråga bara:
varför i hela fridens skriver du:
Medlem sedan aug. 20011 099 inlägg
det där var ju onödigt :birp
ju mindre <%%> desto bätrre prestanda på sidan!
Poffe
Det är för att förut såg den raden ut så här !
<%response.write "Antal Besökare: " &  Application("counter")%>
ibland skriver den ut ett nummer sist jag kollade så skrev den ut 1487, och så många besökare har jag inte haft sen igår !
Medlem sedan mars 2001196 inlägg
Ändrade lite i global.asa, satte dateadd("s")=sekund istället för d=day och kommenterade bort borttagningen av objektet...
Sub Session_OnStart
                Application.Lock
                        myCountFile.Close
                Application.UnLock
        Else
                Response.Cookies("counter").Expires = DateAdd("s",1,Now())
        Application.Lock
                'myCountFile.Close
                'Set myCountFile = nothing
        Application.Unlock
Tyvärr hjälpte inte det lolukokasos...........
Någon som har någon annan ide?
@nders kanske, du brukar ju ha svar på det mesta.......
Det tar jag som en komplimang. :)
Jag sneglade lite på koden, och har ett par anmärkningar.
  1. Använd CLng() istället för CInt(). En integer sträcker sig till 32768, sedan får du ett felmeddelande.
  2. När du räknar upp så har du +1 innanför parentesen. Du försöker alltså lägga till något till ett värde som inte nödvändigtvis är ett tal. Flytta ut till utanför parentesen. Application("counter") = CLng(myCountFile.ReadLine) + 1
Jag tror visserligen inte att detta kommer lösa problemet, men ändå.
Prova att köra koden på en vanlig asp-sida, då det är lättare att se vad som händer, och lättare att felsöka.
mvh,
När jag kör koden lokalt enligt mitt inlägg ovan fungerar det alldeles utmärkt. Är det samma problem även när du testar den koden?
som svar på Lukas inlägg så !
JA det är samma problem då ........
Tackar @nders för din påpekande !
253 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
118 ms — deklarationer (db)
124 ms — ändringar (db)
