Ett felmeddelande hjälp tack!
10 svar · 213 visningar · startad av jwradhe
Medlem sedan juni 2002711 inlägg
va betyder
Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
[Microsoft][ODBC Microsoft Access Driver] The SELECT statement includes a reserved word or an argument name that is misspelled or missing, or the punctuation is incorrect.
/spelat.asp, line 5
va för nåt som inte e bra?
här e lite kod oxå
<% Set Connect = Server.CreateObject("ADODB.connection")
Connect.open = "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & Server.MapPath("db/spelat.mdb")
VISA = "SELECT TOP 6* FROM spelat ORDER by date DESC "
Set RecSet =  Connect.execute(VISA)
<table width="382" border="0" cellspacing="0" cellpadding="0" height="20">
  <tr>
    <td width="22" align="left" valign="top"><font face="Verdana, Arial, Helvetica, sans-serif" size="1">
      <% do until RecSet.EOF %>
      </font>
      <table width="354" border="0" cellspacing="0" cellpadding="0" height="19">
        <tr>
          <td width="200"><font face="Verdana, Arial, Helvetica, sans-serif" size="1">
            <%=RecSet("date")%> / <%=RecSet("lag1")%> - <%=RecSet("lag2")%></font></td>
          <td width="67"><font face="Verdana, Arial, Helvetica, sans-serif" size="1"><%=RecSet("re1")%>
            -<%=RecSet("re2")%></font></td>
          <td width="87"><font face="Verdana, Arial, Helvetica, sans-serif" size="1">Kl:
            <%=RecSet("matchtid")%></font></td>
          <% RecSet.MoveNext
loop
RecSet.close
Connect.close
Set RecSet = nothing
Set Connect = nothing %>
        </tr>
      </table>
      <font face="Verdana, Arial, Helvetica, sans-serif" size="1"> </font></td>
  </tr>
</table>
<font face="Verdana, Arial, Helvetica, sans-serif" size="1"> </font><font face="Verdana, Arial, Helvetica, sans-serif" size="1">
</font> <font face="Verdana, Arial, Helvetica, sans-serif" size="1"> </font><font face="Verdana, Arial, Helvetica, sans-serif" size="1">
</font>
<p>&nbsp;
Medlem sedan nov. 2001348 inlägg
VISA = "SELECT TOP 6 * FROM spelat ORDER by date DESC"
typ?
[red]
VISA = "SELECT TOP 6* FROM spelat ORDER by [date] DESC "
[/red]
Varför göra man så? Funkar fin fint för mig med "ORDER by date"
tack!
Jag har för mig att date är ett reserverat ord.....*chansade lite*
kan nån förklara vart man ska söka igen koden för att hitta felet om dets tår så här " Provider error '80020005'
Type mismatch.
/spelat_add.asp, line 13
Hur ser rad 13 ut ?
Ja icaaq, du har nog rätt, brukar döpa mina fält till "datum" när jag tänker efter.. :)
icaaq :
Rad 13 - RecSet("matchtid") = Request.Form("matchtid")
Jag skulle ha testat
[red]
RecSet("matchtid") = Cdate(Request.Form("matchtid"))
[/red]
eller det beror på vad du har satt för "typ" matchtidkolummnen :)
286 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
136 ms — deklarationer (db)
148 ms — hämta tråd, inlägg och bilagor (db)
135 ms — ändringar (db)
