The application requested an operation on an object with a reference to a closed..
ASPur ASP
7 svar · 284 visningar · startad av SPinckney
SPinckneyMedlem sedan juli 2002104 inlägg
Hejsan,
Detta errormeddelandet får jag på ett script där man lägger till Anställda. Det har alltså fungerat förut under en lång tid.
The application requested an operation on an object with a reference to a closed or invalid Connection object.
Line 19
Ett litet utklipp ur sidan.asp
'Feed the submitted data into the session
checkdate = request.form.item("App_DOB")
if checkdate = "" then checkdate = #01/01/1801#
if not isDate(checkdate) then response.redirect("InvalidDOB.asp")
for each MyItem in Request.Form
	session(MyItem) = Request.Form.Item (MyItem)
next
Function PopulateData(Area)
	set dbengine = session("Database")
	dim i
	dim rstLanguage
	dim TotalLanguages
	set rstLanguage = CreateObject("adodb.recordset")
	[b]rstLanguage.Open "select * from skills where skilltype = '" & Area & "'", dbEngine[/b]
	while not rstLanguage.EOF
		if i/3 = i\3 then
			if i<>0 then
rstLanguage.Open "select * from skills where skilltype = '" & Area & "'", dbEngine, 3, 3
Innehåller verkligen dbEngine korrekt värde?
Det gjorde tyvärr ingen skillnad
Sidan som skickar infot har följande kod
if session("HRuser") = "" then response.redirect ("SignOn.asp?urlfor=default")
function clearSession()
session("DonePost") = ""
for each MyItem in session.Contents
	if left(MyItem,4) = "APP_" or left(MyItem,6) = "SKILL_" then
		session(MyItem) = ""
next
end function
clearSession
<% ' setup db connection
on error resume next
session("Connection").close
set Session("Connection") = Nothing
strConn = "Driver={Microsoft Access Driver (*.mdb)};DBq=" & dbpath
set dbEngine = createobject("adodb.connection")
dbengine.Open strconn
set session("Connection") = dbEngine
Sen kommer alla input typesen etc
Den verkar klaga på Area
rstLanguage.Open "select * from skills where skilltype = '" & [b]Area[/b] & "'", dbEngine, 3, 3
Vad innehåller area då? (Har svårt att tro att det skulle vara det, såvida den inte innehåller apostrofer..)
Man ska aldrig lägga connections i Session eller Application. Det sänker prestanda något oerhört. Börja med att ändra den biten, och kolla sedan om det funkar.
Men om jag nu vill ha det så tills vidare vad ska jag då sätta
dbengine till ?
Varför det lagras i en session är för att det är 5steg och datan matas in på sista sidan alltså på sida5
Det är ingen anledning till att lagra ditt connectionobjekt i en session. Du behöver bara använda connection precis innan du öppnar databasen. Och om det nu skulle vara så att du behöver göra det på varje, av dina fem sidor, öppna ett separat på varje sida då istället; eller optimera din kod. :)
123 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
