Kan det bero på att du har On error resume next med, kommentera bort det.
Hej hej! Tack för all hjälp här! Kan ni också titta på denna kod! Jag får inget fel meddelande, det e bara att mejlen inte kommer fram! Jag har inte gjort detta script själv!
'Replace the email address below with your email address
fromemail = "support@firegamez.com"
'Grab the submitted variables (page is the page they've come from, set by the hidden variable at the login box)
username = Request.Form("username")
'Check no s**t is trying to hack in using SQL commands
if InStr(username, "'") or InStr(username, """") or InStr(username, "=") then
sqlflag = True
'Open connection
<!--#include file="conn.asp"-->
'Get a recordset corresponding to the submitted username and password
sql = "SELECT password, email FROM users WHERE username = '" & username & "' AND active = True"
Set rsUser = Server.CreateObject("ADODB.Recordset")
rsUser.Open sql, conn, 3, 3
'If there was a valid recordset there, then send them back to the page they came from, with the username cookie set
If (not rsUser.BOF) and (not rsUser.EOF) and sqlflag <> True then
set objMail = Server.CreateObject("CDONTS.NewMail")
if err.number <> 0 then
noObj = True
mailbody = "Tja " & username & vbcrlf & vbcrlf
mailbody = mailbody & "Ditt lösenord till Firegamez är:" & vbcrlf & vbcrlf
mailbody = mailbody & " " & rsUser("password") & vbcrlf & vbcrlf
mailbody = mailbody & "----------------------------------------------------" & vbcrlf
mailbody = mailbody & "Firegamez.com [url]http://www.firegamez.com[/url]"
objMail.Body = mailbody
objMail.to = rsUser("email")
objMail.from = fromemail
objMail.subject = "Glömt lösenordet"
objMail.send
set objMail = nothing
sentok = true
'Otherwise, display an invalid entry screen
rsUser.close
set rsUser = nothing
conn.close
set conn = nothing%>
