Rätt??
12 svar · 205 visningar · startad av jwradhe
Medlem sedan juni 2002711 inlägg
Connect.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & db
SQL = "SELECT * From inlagg order by ID desc"
if request.querystring("bort") = "ja" then
Set RecSet2 = Server.CreateObject("ADODB.Recordset")
Addera = "SELECT * FROM gastbok where id ="& request.querystring("id")
RecSet2.Open Addera, Connect, 3, 3
RecSet2.delete
RecSet2.update
RecSet2.Close
Set RecSet2 = nothing
Set RecSet = connect.execute(SQL)
Medlem sedan feb. 20012 412 inlägg
sql ="DELETE FROM gastbok where id ="& request.querystring("id")
Connect.execute(sql),,128
funkar inte.
här e hela koden istället
<!-- #include file="adovbs.inc" -->
<!-- #include file="settings.asp" -->
<html>
<title>Untitled Document</title>
<body bgcolor="#CCCCCC" text="#000000">
<div align="center">
  <p>&nbsp;</p>
  <br><%
  <table style="border-top: #000000 1px solid;border-bottom: #000000 1px solid;border-left: #000000 1px solid;border-right: #000000 1px solid;" width="450" border="0" cellspacing="0" cellpadding="0">
    <tr>
      <td align="center" valign="top">
<table width="440" border="0" cellspacing="0" cellpadding="0">
          <tr>
            <td><% if session("inloggad") <> "ja" then %>
<form name="form" method="post" action="admin.asp?loggain=ja"> ' länkad till admin.asp
Lösenord
<br>
<input name="los" type="password" id="los">
<br>
<input type="submit" name="Submit" value="Submit">
              <p><br>
response.write session("fel") 'om fel lösen har fyllts i kommer det sägas här
                <a href="admin.asp?loggaut=ja">Logga ut</a>
                <% do until recset.EOF %>
                <br>
              <hr size="1">
              <font face="Verdana, Arial, Helvetica, sans-serif" size="1"><%=RecSet("amne")%>
              - <%=RecSet("IP")%> <br>
              <%=RecSet("meddelande")%> <br>
              <br>
              Skrivet av: <a href="mailto:<%=RecSet("email")%>"><%=RecSet("namn")%></a>
              <%If RecSet("hemsida") <> "" Then%>
              <a href="<%=RecSet("hemsida")%>">Hemsida</a>
              <%End If%>
              <br>
              Svar:
              <%If RecSet("svar") <> "" Then%>
              <%=RecSet("svar")%>
              <%else %>
              Inget svar .
              <%End If%>
              </font> <br>
RecSet.MoveNext
Loop
RecSet.Close
Connect.Close
Set RecSet = nothing
Set Connect = nothing
              <br><% if session("inloggad") = "ja" then %>
<A HREF="gastbok.asp?bort=ja&id=<%=recset("id")%>">Ta bort</A>
<% end if %>
              <br>
              <hr size="1">
              <br>
              <br>
              <% end if %>
if request.querystring("loggain") = "ja" then
if request.form("los") = "jimmy" then
session("fel") = "fel lösen !"
if request.querystring("loggaut") = "ja" then session.abandon
          </tr>
        </table>
      </td>
    </tr>
  </table>
</html>
På vilket sätt fungerar det inte?
Medlem sedan jan. 20022 440 inlägg
Koden är inte det viktiga, det viktiga är att skicka med felmeddelande och raderna runt det felmeddelandet pekar på. Pekar felmeddelandet på rs.Open SQL, Conn,,128 tex så betyder det att något är fel innan den raden.
Det är jättejobbigt att börja kika igenom så långa kodstycken.
feltext:
Microsoft JET Database Engine error '80040e10'
No value given for one or more required parameters.
/jimmyw/admin.asp, line 26
kod:
<html>
  <p>
Addera = "SELECT * FROM inlagg where id ="& request.querystring("id")
RecSet2.delete
RecSet2.update
RecSet2.Close
Set RecSet2 = nothing   <---- rad 26
  </p>
    <tr>
          <tr>
Lösenord
<br>
<br>
              <p><br>
                <br>
              <hr size="1">
              <br>
              <%End If%>
              <br>
              Svar:
              <%=RecSet("svar")%>
              <%else %>
              Inget svar .
              <%End If%>
              </font> <br>
              <a href="gastbok.asp?bort=ja&id=<%=recset("id")%>">Ta bort</a>
              <% end if %>
RecSet.MoveNext
Loop
RecSet.Close
Connect.Close
              <br>
              <br>
              <hr size="1">
              <br>
              <br>
              <% end if %>
          </tr>
        </table>
      </td>
    </tr>
  </table>
</html>
<html>
<p>
Addera = "DELETE FROM inlagg where id ="& request.querystring("id")
Connect.Execute Addera,,128
</p>
<tr>
<tr>
Lösenord
<br>
<br>
<p><br>
<br>
<hr size="1">
<br>
<%End If%>
<br>
Svar:
<%=RecSet("svar")%>
<%else %>
Inget svar .
<%End If%>
</font> <br>
<% end if %>
RecSet.MoveNext
Loop
RecSet.Close
Connect.Close
<br>
<br>
<hr size="1">
<br>
<br>
<% end if %>
</tr>
</table>
</td>
</tr>
</table>
</html>
När du inte ska använda ett recordset finns det ingen anledning att skapa ett....
jwradhe:
Inte för att klanka ner på dig, men jag tror att det kan vara en ide att försöka göra lite färre "kodväxlingar" (eller vad det nu heter.)
typ som här:
<%End If%>
<br>
Svar:
<%=RecSet("svar")%>
<%else %>
Inget svar .
<%End If%>
</font> <br>
<% end if %>
va menar du?
Han menar att du ska inte använda dig så mycket växlingar mellan asp och html kod på det sättet du gör. Det blir väldigt svårt att överblicka koden och hitta fel mm.
Istället för det du gjorde där försök att lägga allting inuti asp koden och processa det som är HTML med response.write istället.
Den största anledningen om inte annat är, vad jag har lärt mig, att inte servern behöver arbeta lika mycket om växlingarna hålls nere.
Sen är det väl iofs också lättare att följa koden.
I script som dessa kanske man inte "tjänar" så mycket på att spara in på växlingarna, men kan man göra det till en god vana tror jag nog man vinner på det i längden.
typ:
	response.write "<a href="" & RecSet("hemsida") & "">Hemsida</a>"
response.write "<br>Svar: "
If RecSet("svar") <> ""  then
	response.write RecSet("svar")
	response.write "Inget svar."
response.write "</font><br>"
	response.write "<a href=""gastbok.asp?bort=ja&id=" & recset("id") & """>Ta bort</a>"
(Bara för det finns det väl felaktigheter i den kod jag postar...)
265 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
117 ms — deklarationer (db)
123 ms — ändringar (db)
