Jmail fel!
6 svar · 272 visningar · startad av [AMD]Zmaster
Medlem sedan mars 20021 716 inlägg
Det kommer inget felmeddelande, det står bara att nyhetsbrevet är skickat.
If Request.Querystring("action") = "sent" Then
Set RecSet=Conn.Execute("SELECT * From nyhetsbrev")
Meddelande = Replace(Request.Form("Meddelande"), vbCrLf, "<BR>" & vbCrLf)
On Error Resume Next
Do While Not RecSet.EOF
smtpServer = "mail.aleborg.com"
smtpPort = 25
dim sender, subject, body, smtpServer, smtpPort
' Now gets the data from Form
sender = Request.Form("dinemail")
receiver = Request.Form("Email")
subject = Request.Form("Subject")
body = Request.Form("meddelande")
Set mail = CreateObject ("JMail.SMTPMail")
mail.ServerAddress = smtpServer & ":" & smtpPort
mail.Sender = sender
mail.Subject = subject
mail.AddRecipient receiver
mail.ContentType = "text/html" ' or you can put 'text/plain' for plain text email
mail.ISOEncodeHeaders = false
mail.ContentTransferEncoding = "8bit"
mail.Body = body
' 1 - highest priority (Urgent) ' 3 - normal ' 5 - lowest
mail.Priority = 3
' Add sender's IP address (not required, but useful for web-based email)
mail.AddHeader "Originating-IP", Request.ServerVariables ("REMOTE_ADDR")
' Actually send mail
mail.Execute
set mail = nothing
RecSet.MoveNext
Loop
RecSet.Close
Set RecSet = Nothing
Session("mess") = "<b>Nyhetsbrevet har nu skickats!</b>"
Response.Redirect "admin.asp?sektion=4"
Kommentera bort
ON ERROR resume next
Då får jag felmeddelande:
jmail.SMTPMail error '8000ffff'
Error: 502 The following recipients could not be sent to:
/hnadmin/admin.asp, line 1048
Kontrollera innehållet i variablerna innan du skickar iväg mailet.
Jag kan ingenting om ASP, vad menar du med "Kontrollera innehållet i variablerna innan du skickar iväg mailet."?
Det viktiga är att kontrollera innehållet i variablerna sender och receiver.
Response.write "sender: " & sender & "<br>"
Response.write "receiver: " & receiver & "<br>"
Kommentera också bort execute-raden.
Mvh,
Äh, jag blir så lack på detta, jag fattar ingenting =(.
Jag struntar i det så länge =(
123 ms — deklarationer (db)
125 ms — ändringar (db)
