Jag bör väll också tilläga att jag får felet:
Feltyp:
aspSmartUpload (0x800A0009)
Subscript out of range
/version2/ForumMessage.asp, line 25
.. Och att line 25 är: mySmartUpload.Upload
4 svar · 343 visningar · startad av UnConed
'Skriver in info som man skickar
IF Request.QueryString("Do") = "Add" Then
'Dimmar variabler
Dim Slumptal, SlumptalDatabas, TidenNu, Klockan, Datum, Sposten
TidenNu = Date & Time
Klockan = Time
Datum = Date
Sposten = Time & "-" & Session("Username")
Randomize
Slumptal = Int(Rnd * 1000000000000)
' Variables
Dim mySmartUpload
Dim intCount
' Object creation
Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
' Upload
mySmartUpload.MaxFileSize = 400000
mySmartUpload.AllowedFilesList = "jpg,gif,png"
' DeniedFilesList can also be used :
' Allow all files except exe, bat and asp
' mySmartUpload.DeniedFilesList = "exe,bat,asp"
' Deny physical path
mySmartUpload.DenyPhysicalPath = True
For each file In mySmartUpload.Files
' Only if the file exist
If not file.IsMissing Then
' Save the files with his original names in a virtual path of the web server
file.SaveAs("Upload/" & Session("Username") & "/Forum/" & Slumptal & "." & file.FileExt)
SlumptalDatabas = Slumptal & "." & file.FileExt
' sample with a physical path
' file.SaveAs("c:\temp\" & file.FileName)
' Uppdaterar Sqln till databasen
Connect.Open "driver=MySQL;server=localhost;uid=uid;pwd=lösenord;database=Forum"
SQL = "INSERT INTO svar (Fran, PersonalStatus, Tid, Bild, Rubrik, Meddelande, SvarsID, Bifogat) Values ('" & Session("Username") & "','" & Session("Status") & "','" & Klockan & "','" & Session("Image") & "','" & mySmartUpload.Form("headline") & "','" & mySmartUpload.Form("Meddelande") & "','" & mySmartUpload.Form("SvarsID") & "','" & SlumptalDatabas & "')"
Connect.Execute(SQL)
Connect.Close
Set Connect = Nothing
ELSE
SQL = "INSERT INTO svar (Fran, PersonalStatus, Tid, Bild, Rubrik, Meddelande, SvarsID) Values ('" & Session("Username") & "','" & Session("Status") & "','" & Klockan & "','" & Session("Image") & "','" & mySmartUpload.Form("headline") & "','" & mySmartUpload.Form("Meddelande") & "','" & mySmartUpload.Form("SvarsID") & "')"
Connect.Close
Next
'------DETTA SKA ALLTID VARA MED!
'Uppdaterar info till rubriken
SQL = "UPDATE rubrik Set Sposten = '" & Sposten & "',DatumTid = '" & TidenNu & "',SettAlla = 'Nej',Svar = Svar + 1 Where ID = '" & Request.Form("SvarsID") & "'"
Connect.Close
Set Connect = nothing
Response.Redirect "ForumMessage.asp?Org=" & Request.Form("OrgForum") & "&Open=" & Request.Form("SvarsID")
End IF
Feltyp:
Du försöker alltså att uppdatera båda en bild och information till en databas? Skulle gärna också ha hjälp med detta, har också kört fast
Skall inte objektet initieras? (Det där lät bra)
Typ:
mySmartUpload.initialize(pageContext);
http://www.jspsmart.com/liblocal/docs/en/jspsmartupload/help/Requirements.htm
Anders
Visste inte att du behöver hjälp. aja, har ingen aning heller.
Föresten, jag vill betatesta v2.
