<% Visar sig inte.. (lektion)
6 svar · 233 visningar · startad av sin_adec
Medlem sedan apr. 2002272 inlägg
Hej!...
jag sitter här skriver lite lektioner i ASP..
det här vill inte visa sig på sidan..
[röd]
 <% Response.write "Välkommen till min hemsida" %>
Idag är det<%= Date %>
[/röd]
använder mig av följande kod
strPress = Recset("lektion")
strPress = Replace (strPress,vbCrLf,"<br>")
strPress = Replace(strPress,"[fet]","<B>")
strPress = Replace(strPress,"[/fet]","</B>")
strPress = Replace(strPress,"[b]","<Big>")
strPress = Replace(strPress,"[/b]","</Big>")
strPress = Replace(strPress, "[url]", "<a href=""")
strPress = Replace(strPress, "[/url]", "</a>")
strPress = Replace(strPress, "[mitten]", "<center>")
strPress = Replace(strPress, "[/mitten]", "</center>")
strPress = Replace(strPress,"","<u>")
strPress = Replace(strPress,"","</u>")
strPress = Replace(strPress,"","<i>")
strPress = Replace(strPress,"","</i>")
strPress = Replace(strPress,"[vit]","<font color=""#ffffff"">")
strPress = Replace(strPress,"[/vit]","</font>")
strPress = Replace(strPress,"[blå]","<font color=""#0000FF"">")
strPress = Replace(strPress,"[/blå]","</font>")
strPress = Replace(strPress,"[gul]","<font color=""#FFFF00"">")
strPress = Replace(strPress,"[/gul]","</font>")
strPress = Replace(strPress,"[röd]","<font color=""#FF0000"">")
strPress = Replace(strPress,"[/röd]","</font>")
strPress = Replace(strPress,"[orange]","<font color=""#FF9933"">")
strPress = Replace(strPress,"[/orange]","</font>")
strPress = Replace(strPress,"[grön]","<font color=""#00CC00"">")
strPress = Replace(strPress,"[/grön]","</font>")
strPress = Replace(strPress,"[grå]","<font color=""#999999"">")
strPress = Replace(strPress,"[/grå]","</font>")
strPress = Replace(strPress,"[rosa]","<font color=""#FF6699"">")
strPress = Replace(strPress,"[/rosa]","</font>")
strPress = Replace(strPress,"[lila]","<font color=""#660066"">")
strPress = Replace(strPress,"[/lila]","</font>")
strPress = Replace(strPress,"[ljusblå]","<font color=""#CCCCFF"">")
strPress = Replace(strPress,"[/ljusblå]","</font>")
Response.Write strPress
när jag sen kollar på lektionen.. alltså efter att det har sparats i databasen
blir det bara
"idag är det "
jag vill att koden ska visa sig..
Medlem sedan apr. 20021 203 inlägg
Ett första tips är alldrig använda [röd] utan istället [rod] eller .... som på wF!
Och koden som du skriver mellan röd och /röd, är det i en textarea som sedan tas emot av en annan sida där Replacen finns, eller?
:q
japp..
Ok, men du kan inte skriva in ASP-kod på en HTML-sida som sedan skickas vidare. Då får du istället först lagra datumet i en variabel:
Variable = Date
och sedan får du med t.ex. med ett javascript göra så att när man trycker på en knapp så ploppar datumet fram (i.e. variabeln som det är sparat i.)
Om jag förstod din fråga rätt...
Förresten, på din hemsida står det att du snackar Lingala. Var talas det språket?
Medlem sedan juli 20011 084 inlägg
tror du verkligen de är så smart att skriva lektioner...? När du fortfarande själv får problem?
ps. man kan väll inte ha asp variabler i databas?
269 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
128 ms — deklarationer (db)
128 ms — ändringar (db)
