Datum/tid & SQL UPDATE & snurra
27 svar · 508 visningar · startad av CatZ
CatZMedlem sedan jan. 20022 440 inlägg
while not rs.eof
response.write "<tr class=td2>" & _
"<td align=right>Spelkv&auml;ll 1</td>" & _
"<td><select name=dag>" &_
"<option>.: V&auml;lj Dag :.</option>" & _
"<option value=Måndag"
If rs("dag") = "Måndag" Then response.write " Selected"
response.write ">Måndag</option>" & _
"<option value=Tisdag"
If rs("dag") = "Tisdag" Then response.write " Selected"
response.write ">Tisdag</option>" & _
"<option value=Onsdag"
If rs("dag") = "Onsdag" Then response.write " Selected"
response.write ">Onsdag</option>" & _
"<option value=Torsdag"
If rs("dag") = "Torsdag" Then response.write " Selected"
response.write ">Torsdag</option>" & _
"<option value=Fredag"
If rs("dag") = "Fredag" Then response.write " Selected"
response.write ">Fredag</option>" & _
"<option value=Lördag"
If rs("dag") = "Lördag" Then response.write " Selected"
response.write ">Lördag</option>" & _
"<option value=Söndag"
If rs("dag") = "Söndag" Then response.write " Selected"
response.write ">Söndag</option>" & _
"</select>" & _
"Tid: " & _
"<input name=tid type=text size=5 maxlength=5 value=" & FormatDateTime(rs("tid"),4) & "></td>" & _
"<td><input name=dagid type=hidden value=" & rs("dagID") & "></td>" & _
 "<td></td>" & _
"</tr>"
rs.movenext
wend
SQL2 = "UPDATE kbdag SET" & _
" dag = '" & Request.Form("dag") & "', " & _
" tid = #" & Request.Form("tid") & "# " & _
" WHERE KrID = " & Request.Querystring("id") & " " & _
" AND dagID = " & Request.Form("dagID")
dbCom.Execute SQL2,,128
Den koden ger följande fel:
Feltyp:
Microsoft OLE DB Provider for ODBC Drivers (0x80040E14)
[Microsoft][Drivrutin för ODBC Microsoft Access] Syntaxfel i datum i frågeuttrycket '#16:00'.
/admin/admin_klubbar.asp, line 279
Och 279 är ju då givetvis dbCom.Execute SQL2,,128
Någon som fattar någe? jag gör det inte
cyprysMedlem sedan dec. 20003 563 inlägg
Pröva skriva ut den? response.write SQL2
Testa annars med
" tid = '" & Request.Form("tid") & "' " & _
har du kolumnen tid som date eller varchar?
EkströmMedlem sedan feb. 20022 594 inlägg
En liten fråga bara. Varför sparar du dag och tid i separata kolumner?
för att det på samma dag kan förekomma flera tider så det blir ändå att spara dubbelt i databasen :)
Såhär blir det när jag skriver ut det...
UPDATE kbdag SET dag = 'Söndag, Tisdag', tid = #16:00, 18:30# WHERE KrID = 1317570844 AND dagID = 5, 6
Jo, men du skulle kunnat spara det i endast en kolumn. Onödigt det du gjort tycker jag...
Du kan inte spara flera siffror i en INT kolumn.
Gör om alla till varchar och sätt ' ' runt om. Inte KrID dock.
Tiden tar du bort # runt.
Dock tycker även jag att du kanske ska tänka om. Det kanske går att göra lite smidigare? Bara kanske ;)
Det hjälper lixom inte eller ? Om jag har 7 kolumner med dagar som jag fyller i tid i eller 2 kolumner som jag fyller i dag OCH tid... vad är knas ?
Grejen är nog att man behöver inte dela upp tid och datum. now() skriver ju datum i format 2002-01-01 19:00:00 så den innehåller ju allt man vill.
Sen är det bara att köra datepart på den för att få ut precis det man vill.
Jo men eftersom det är en stående tid så funkar ju inte now() så bra ;)
Men jag funderar på att skita i att tillåta ändringar i den tiden och göra en länk så att man måste ändra en tid åt gången
För nu får jag upp följande felmeddelande:
Feltyp:
[Microsoft][Drivrutin för ODBC Microsoft Access] Syntaxfel (komma) i frågeuttrycket 'KrID = 1317570844 AND dagID = 5, 6'.
Kan man inte uppdatera flera olika poster med en uppdatering i samma tabell ?
Jodå, varför skulle du inte kunna göra det?
Det är where-delen av din SQL-fråga som styr vilka poster som skall uppdateras. Du kan använda IN() för att ange flera fältvärden.
...AND dagID [b]IN (5, 6)[/b]
Mvh,
aha, men i det här fallet så är det inte förutbestämt.. kan man göra
 WHERE KrID = Request.Querystring("id") AND dagID IN Request.Form("dagID")
Uppdaterar den alla dagID fälten korrekt iså fall ?
WHERE KrID = " & Request.Querystring("id") & " AND dagID IN ("  & Request.Form("dagID") & ")"
puss puss LarsG :f
while not rs.eof
"<td align=right>Spelkväll 1</td>" & _
"<option>.: Välj Dag :.</option>" & _
'osv
rs.movenext
wend
Hur gör jag så att jag kan skriva ett alternativ om det inte finns någon spelkväll ?
if not rs.eof then
resonse.write osv
istä'llet för while not rs.eof ? nej men ni vet... ? ett andra alternativ om det ínte finns någon spelkväll
Du är på rätt spår.
if rs.eof then
EOF betyder ju end of file, och är true när recordsetet är tomt. :)
Mvh,
Jag testade med
If rs.eof = TRUE then
response.write "Inga spelkvällar"
Else
while not rs.eof
Jag fattar nog inte :r
På vilket sätt fungerar inte det där då?
Feltyp:
ADODB.Field (0x80020009)
Antingen är BOF eller EOF satt till True, eller så har aktuell post raderats. Den begärda åtgärden kräver en aktuell post.
277 ms totalt · 3 externa anrop · v20260731065814-full.30151723
130 ms — hämta forumlista (db)
128 ms — hämta statistik (db)
