Det är en funktion, så du får sätta in den "fil" du vill kolla i funktionen, typ:
filetype("bild.gif")
Eller kanske göra en ytterligare funktion av det hela:
Dim objFSO, objFile
Dim sMapPath, objFolder
Set objFSO = CreateObject("Scripting.FileSystemObject")
sMapPath = server.mapPath("./.")
Set objFolder = objFSO.GetFolder(sMapPath)
For Each objFile in objFolder.Files
If objFile.Name = ID Then
Response.Write "<font color='#ff0000'> x </font>"
Else
Response.Write "»"
Response.Write "<a href=default.asp?id=" & objFile.Name & ">"
Response.write objFile.Name
Response.write "</a> "
Response.write Kommentar(objFile.Name)
Response.write "<br>"
Next
Set objFSO = Nothing
Set objFolder = Nothing
Function filetype(filename)
filetype= lcase(left(filename,instr(filename,".") -1))
End Function
Function Kommentar(filename)
If filetype(filename) = "jpg" Then
Kommentar = "its a bloody picture!"
Else
Kommentar = "its a bloody.... something-else!!"
End Function
