webb basrat NT login.
3 svar · 303 visningar · startad av medialabs
medialabsMedlem sedan mars 20023 686 inlägg
hej!
Jag har fått tag på ett Login script i asp. Och den visar en NT login och nu undrar jag var jag ska sätta in lösenord och användarnamn??
Response.Buffer = True
Response.Clear
Dim Myname, MyPass
GetUser Myname, MyPass
Response.Write MyName & "->" & MyPass
If Len(Myname) = 0 Then
Response.Status = "401 Unauthorized"
Response.AddHeader "WWW-Authenticate","BASIC Realm=enter your realm here"
Response.End
Sub GetUser(LOGON_USER, LOGON_PASSWORD)
Dim UP, Pos, Auth
Auth = Request.ServerVariables("HTTP_AUTHORIZATION")
LOGON_USER = ""
LOGON_PASSWORD = ""
If LCase(Left(Auth, 5)) = "basic" Then
UP = Base64Decode(Mid(Auth, 7))
Pos = InStr(UP, ":")
If Pos > 1 Then
LOGON_USER = Left(UP, Pos - 1)
LOGON_PASSWORD = Mid(UP, Pos + 1)
End Sub
' Decodes a base-64 encoded string.
Function Base64Decode(base64String)
Const Base64CodeBase = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/"
Dim dataLength, Out, groupBegin
dataLength = Len(base64String)
Out = ""
If dataLength Mod 4 <> 0 Then
Err.Raise 1, "Base64Decode", "Bad Base64 string."
Exit Function
' Now decode each group:
For groupBegin = 1 To dataLength Step 4
Dim numDataBytes, CharCounter, thisChar, thisData, groupData
' Each data group encodes up To 3 actual
' bytes.
numDataBytes = 3
groupData = 0
For CharCounter = 0 To 3
' <B>Convert</B> each charac
' ter into 6 bits of data, And add it To
' an integer For temporary storage. If a
' character is a '=', there
' is one fewer data byte. (There can onl
' y be a maximum of 2 '=' In
' the whole string.)
thisChar = Mid(base64String, groupBegin + CharCounter, 1)
If thisChar = "=" Then
numDataBytes = numDataBytes - 1
thisData = 0
Else
thisData = InStr(Base64CodeBase, thisChar) - 1
If thisData=-1 Then
Err.Raise 2, "Base64Decode", "Bad character In Base64 string."
Exit Function
groupData = 64 * groupData + thisData
Next
' Convert 3-byte integer into up To 3 ch
' aracters
Dim OneChar
For CharCounter = 1 To numDataBytes
Select Case CharCounter
Case 1: OneChar = groupData \ 65536
Case 2: OneChar = (groupData And 65535) \ 256
Case 3: OneChar = (groupData And 255)
End Select
Out = Out & Chr(OneChar)
Next
Next
Base64Decode = Out
End Function
Går inte detta script mot filsystemet på servern? :q
(Har inte kollar närmare på det)
Det är bara att ta och klistra in koden i en .asp fil så funkar den men jag vill ta och sätta in lösenord i den. Men har inte hittat platsen var man ska sätta in den.
Som jag sa; baseras inte denna inloggning på en användare och ett lösenord som kommer ifrån operativsystemet (Windows 2000 kanske?) på servern?
Du sätter alltsås inte ett lösenord, det anger du under användarens inställningar.
136 ms totalt · 3 externa anrop · v20260731065814-full.fb544a5a
