Jmail - Bulkmerge?
6 svar · 247 visningar · startad av crisse6
Medlem sedan dec. 20002 526 inlägg
Sitter och ska försöka fixa i ordning en mailinglista, men jag vet inte hur man går till väga... Har hört något om att det finns en motod i Jmail som heter Bulkmerge tror jag?! Jag var inne på diamec.net eller vad dom heter och hittade denna kod:
<% @LANGUAGE="VBSCRIPT" %>
<html>
<body>
' First we will create a message object that will serve as a
' template for the merge.
' The merge fields are marked with %% in the front and in the
' end.
' Note how we use merge fields even in the addRecipient method
set msgTemplate = Server.CreateObject( "JMail.Message" )
msgTemplate.From = "me@myDomain.com"
msgTemplate.FromName = "Mailinglist info!"
msgTemplate.AddRecipient "%%EMail%%", "%%Name%%"
msgTemplate.Subject = "Hi %%Name%%"
msgTemplate.Body = "Hello %%Name%%, you are my favorite website visitor!"
' There, our message template is done. Next we create the mailmerge object.
set mMerge = Server.CreateObject( "JMail.MailMerge" )
' Now, tell mailMerge to use the template we created earlier
mMerge.MailTemplate = msgTemplate
' Before we start emailing thousands of recipients, we make testrun.
' The line below tells MailMerge to process only 10 recipients
' and to send the emails to "myEMail@company.com" instead.
' This way we can see if our template is as expected. When we
' are ready to go live, just remove the line below.
mMerge.SetDebugMode( "myEMail@company.com", 10 )
' Okay lets do the merge. As we do an ADO resultset merge, we do not need to
' specify each merge variable.
' The myRS is assumed to hold a ADO recordset.
' If we didn't have to many recipients, we wouldn't have to enque the emails,
' instead we would have to specify the mailserver like this
' MailMerge.BulkMerge( myRS, false, "mail.myDomain.com" )'
' However, we will now enque it and therefore sets the second parameter to
' true and instead of supplying the mailserver address, we specify where
' our MS pickup directory is (if you run windows 2000 this is optional).
' The BulkMerge() method automatically sends/enques our emails, so we
' do not need to use the send() method.
mMerge.BulkMerge myRS, true, "c:\inetpub\mailroot\pickup"
' Thats it! One template, a workload of emails.
Mailmerge complete!
</html>
Vad ska man göra i den för att den ska fungera på det webhotell jag har?
Sedan så vill jag veta helt säkert om mitt hotell stöder Jmail? Kan man få reda på det utan att behöva ringa support, typ genom en kodsnutt?!
Helo!
för att testa om ditt webbhotell har stöd för JMail kan du endast köra denna kodsnutt:
Får du inget felmeddelande kan du köra JMail.
Det andra, om att få .BulkMerge att funka kan bli knepigare. Det beror på att du måste ha en sökväg till den katalogen som har hand om mailkön på mailservern. Bara att ringa support och fråga, eller om det står ngt i ditt avtal med olika lösenord för tex ftp, mail m.m .... har du tur så står pickup-mappen med där.
ps .... fast man kanske kan göra på ngt annat sätt, inte riktigt hemma på JMail 4 .... DS
cya,
PatrikB
okey!
fick felmess nu, så Jmail funkar ej.
En annan sak, CDONTS hur ser man om man har stöd för det då?
Finns det något bra tips hur man ska göra för att ordna en smidig mailinglista med det?
ingen som kan hjälpa????
Medlem sedan juni 20001 257 inlägg
CDONTS stödjer mig veterligen inte queueing av e-post. Att skicka fler än ett par hundra mail på samma gång kommer således sannolikt att leda till timeout.
TimeOuten kan lätt ändras eller så bygger man en paging-liknande lösning
Timeout:
<% Server.ScriptTimeout = 3600 %>
vilket gör att scriptet kan köras i en timme (3600 sec)
Paginglösning:
http://www.webforum.nu/showthread.php?s=&postid=334904#post334904
vi tar det via icq PatrikB ;)
273 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
135 ms — deklarationer (db)
133 ms — ändringar (db)
