Loop i vides paging....?
25 svar · 570 visningar · startad av crisse6
crisse6Medlem sedan dec. 20002 526 inlägg
hej...med denna kod blir det fel, sedan har jag problem med Paginglänkarna... hmm... kan någon ordna detta är det ett stort tack... db-kopplingen är inkluderad...
Set objRs = Server.CreateObject("ADODB.Recordset")
strSQL = "SELECT * FROM add_forum Where svarid = '" & Request.Querystring("svarid") & "'"
SQL = "SELECT * FROM medlemmar"
set objRs2=Databas.execute(SQL)
intPageId = request.querystring( "pageid" )
if intPageId = "" then intPageId = 1
with objRs
  .cursorLocation = 3
  .open strSQL, Databas
  .pagesize = 10
  .absolutepage = intPageId
end with
intPages = cint( objRs.pagecount )
intCurrentPost = 0
response.write "<font face=Verdana size=2 class=rubrik> -->" & objRs("rubrik") & "</font><br><br>"
response.write "<table width=500 cellspacing=1 cellpadding=2><tr><td bgcolor=#EFEFEF width=100><font face=Verdana size=1><b>Skribent:</b></font></td><td bgcolor=#EFEFEF><font face=Verdana size=1><b>Tråd:</b></td></tr></table>"
do until objRs.eof and intCurrentPost < objRs.pagesize
if bgcolor = "#FFFFFF" then
  bgcolor = "#EFEFEF"
  bgcolor = "#FFFFFF"
  strContents = strContents &_
    "<table width=500 bgcolor="& bgcolor &"><tr><td width=100 valign=top><b>"& objRs("anvandarnamn") &"</b><br><br>" &_
    "<font face=Verdana size=1>"& objRs2("antal_inlagg") & " inlägg<br>" &_
    "</td><td><font face=Verdana size=1>" & objRs("rubrik") & "<br><br>" & objRs("inlagg") & "</font></td></tr>"
  intCurrentPost = intCurrentPost + 1
  objRs.movenext
loop
for i = 1 to objRs.pagecount
  strNavigation = strNavigation & " <a href='?pageid=" & i & "&trad=" & Request.Querystring("trad") & "&svarid=" & request.querystring("svarid") & "'>" & i & "</a>"
next
response.write "<table>" & strContents & "</table>"
response.write "<table><tr><td><font face=Verdan size=1>" & strNavigation & "</td></tr></table></font>"
fel:
Microsoft VBScript compilation error '800a040e'
'loop' without 'do'
/forum/las.asp, line 38
loop
rad 38:
loop
puhh!
Då tar vi ett steg i taget.
  bgcolor = "#EFEFEF"
  bgcolor = "#FFFFFF"
[b]end if[/b]
ska det inte stå objRs på den raden?
@nders, end if orsakde expected statement eller nåt....
solbulle, objRs2 ska vara så, det är två olika tabeller... kolla i början
Det ska vara ett end if där. Vilken rad pekade det nya felmeddelandet på?
Microsoft VBScript compilation error '800a0400'
Expected statement
/forum/las.asp, line 45
rad 45:
Vilket end if är det? Det sista i din kod? Varför har du den där?
hmm...
jag flyttade ner den nu längst ner, fick då loop felet... konstigt...
Vad flyttade du ner var? Hur ser koden ut?
HeHoMedlem sedan apr. 2000277 inlägg
Inte vet jag men nu är ju INTE if-satsen i loopen stängd.
Den stänger du ju längst ned, utanför loopen och det går ju inte.
set objRs=Databas.execute(strSQL)
with objRs
  .cursorLocation = 3
  .pagesize = 10
end with
intCurrentPost = 0
  bgcolor = "#EFEFEF"
  bgcolor = "#FFFFFF"
  objRs.movenext
loop
next
så ser den ut nu, men om jag stänger den uppe inom loopen så får jag Expected Statement, och är det ingen alls (end if)eller om end if ligger längst ner så blir det felmess på raden där det står "loop", beskrivning: loop utan do? hmmm.... knepigt...
doggelitoMedlem sedan juni 20003 076 inlägg
du kan ju alltid börja med att avsluta denna:
  bgcolor = "#EFEFEF"
  bgcolor = "#FFFFFF"
[b]end if[/b]
sen kan du ta bort 1 end if längst ned. :)
Jag skulle nog rekomender att båda "end if" längst ner tas bort.
stämmer bra det! ;)
doggelito, om du hade läst inläggen innan så hade du inte behövt att skriva ;) men inget illa menat, tackar för alla som kan tänka sig att hjälpa mig!
jo, det såg jag nog.
men eftersom du klistrade in felaktig kod så tänkte jag att det var
bäst att påminna igen. ;)
satte end if där vid if satsen som ni sagt tidigare, tog bort de två end if längst ner, kanske ett steg på rätt väg? får nytt felmess :e
ADODB.Recordset error '800a0e79'
Operation is not allowed when the object is open.
/forum/las.asp, line 13
13:
  .cursorLocation = 3
du kan nog ta bort denna rad: set objRs=Databas.execute(strSQL)
eftersom den öppnas två ggr.
144 ms totalt · 3 externa anrop · v20260731065814-full.30151723
