Vad ar det jag missar?
11 svar · 264 visningar · startad av annesophie
Medlem sedan juni 20012 236 inlägg
Jag far foljande felmeddelande pa "conn.execute(sql)" raden:
Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
[Microsoft][ODBC Microsoft Access Driver] Syntax error in INSERT INTO statement.
/evaluation/documents/evalcheck.asp, line 166
Sidan evalcheck.asp ser ut sa har:
option explicit
response.buffer=true
dim conn
dim sql
dim rs
dim fname
dim lname
dim email
dim country
dim vicor1Qone
dim vicor1Qtwo
dim vicor1Qthree
dim vicor1Qfour
dim vicor2Qone
dim vicor2Qtwo
dim vicor2Qthree
dim vicor2Qfour
dim eos1Qone
dim eos1Qtwo
dim eos1Qthree
dim eos1Qfour
dim craftec1Qone
dim craftec1Qtwo
dim craftec1Qthree
dim craftec1Qfour
dim ault1Qone
dim ault1Qtwo
dim ault1Qthree
dim ault1Qfour
dim ault2Qone
dim ault2Qtwo
dim ault2Qthree
dim ault2Qfour
dim ault3Qone
dim ault3Qtwo
dim ault3Qthree
dim ault3Qfour
dim condor1Qone
dim condor1Qtwo
dim condor1Qthree
dim condor1Qfour
dim pbx1Qone
dim pbx1Qtwo
dim pbx1Qthree
dim pbx1Qfour
dim pbx2Qone
dim pbx2Qtwo
dim pbx2Qthree
dim pbx2Qfour
dim pbx3Qone
dim pbx3Qtwo
dim pbx3Qthree
dim pbx3Qfour
dim pbx3Qfive
dim pbx4Qone
dim pbxt4Qtwo
dim pbx4Qthree
dim pbx4Qfour
dim otherQone
dim otherQtwo
dim comments
fname=request.form("fname")
lname=request.form("lname")
email=request.form("email")
country=request.form("country")
vicor1Qone=request.form("vicor1Qone")
vicor1Qtwo=request.form("vicor1Qtwo")
vicor1Qthree=request.form("vicor1Qthree")
vicor1Qfour=request.form("vicor1Qfour")
vicor2Qone=request.form("vicor2Qone")
vicor2Qtwo=request.form("vicor2Qtwo")
vicor2Qthree=request.form("vicor2Qthree")
vicor2Qfour=request.form("vicor2Qfour")
eos1Qone=request.form("eos1Qone")
eos1Qtwo=request.form("eos1Qtwo")
eos1Qthree=request.form("eos1Qthree")
eos1Qfour=request.form("eos1Qfour")
craftec1Qone=request.form("craftec1Qone")
craftec1Qtwo=request.form("craftec1Qtwo")
craftec1Qthree=request.form("craftec1Qthree")
craftec1Qfour=request.form("craftec1Qfour")
ault1Qone=request.form("ault1Qone")
ault1Qtwo=request.form("ault1Qtwo")
ault1Qthree=request.form("ault1Qthree")
ault1Qfour=request.form("ault1Qfour")
ault2Qone=request.form("ault2Qone")
ault2Qtwo=request.form("ault2Qtwo")
ault2Qthree=request.form("ault2Qthree")
ault2Qfour=request.form("ault2Qfour")
ault3Qone=request.form("ault3Qone")
ault3Qtwo=request.form("ault3Qtwo")
ault3Qthree=request.form("ault3Qthree")
ault3Qfour=request.form("ault3Qfour")
condor1Qone=request.form("condor1Qone")
condor1Qtwo=request.form("condor1Qtwo")
condor1Qthree=request.form("condor1Qthree")
condor1Qfour=request.form("condor1Qfour")
pbx1Qone=request.form("pbx1Qone")
pbx1Qtwo=request.form("pbx1Qtwo")
pbx1Qthree=request.form("pbx1Qthree")
pbx1Qfour=request.form("pbx1Qfour")
pbx2Qone=request.form("pbx2Qone")
pbx2Qtwo=request.form("pbx2Qtwo")
pbx2Qthree=request.form("pbx2Qthree")
pbx2Qfour=request.form("pbx2Qfour")
pbx3Qone=request.form("pbx3Qone")
pbx3Qtwo=request.form("pbx3Qtwo")
pbx3Qthree=request.form("pbx3Qthree")
pbx3Qfour=request.form("pbx3Qfour")
pbx3Qfive=request.form("pbx3Qfive")
pbx4Qone=request.form("pbx4Qone")
pbxt4Qtwo=request.form("pbxt4Qtwo")
pbx4Qthree=request.form("pbx4Qthree")
pbx4Qfour=request.form("pbx4Qfour")
otherQone=request.form("otherQone")
otherQtwo=request.form("otherQtwo")
comments=request.form("comments")
<!-- #INCLUDE FILE="koppling.asp" -->
sql="INSERT INTO [eval] (fname, lname, email, country, vicor1Qone, vicor1Qtwo, vicor1Qthree, vicor1Qfour, vicor2Qone, vicor2Qtwo, vicor2Qthree, vicor2Qfour, eos1Qone, eos1Qtwo, eos1Qthree, eos1Qfour, craftec1Qone, craftec1Qtwo, craftec1Qthree, craftec1Qfour, ault1Qone, ault1Qtwo, ault1Qthree, ault1Qfour, ault2Qone, ault2Qtwo, ault2Qthree, ault2Qfour, ault3Qone, ault3Qtwo, ault3Qthree, ault3Qfour, condor1Qone, condor1Qtwo, condor1Qthree, condor1Qfour, pbx1Qone, pbx1Qtwo, pbx1Qthree, pbx1Qfour, pbx2Qone, pbx2Qtwo, pbx2Qthree, pbx2Qfour, pbx3Qone, pbx3Qtwo, pbx3Qthree, pbx3Qfour, pbx3Qfive, pbx4Qone, pbxt4Qtwo, pbx4Qthree, pbx4Qfour, otherQone, otherQtwo, comments) " &_
"VALUES ('"&fname&"','"&lname&"','"&email&"','"&country&"',"&vicor1Qone&","&vicor1Qtwo&","&vicor1Qthree&","&vicor1Qfour&","&vicor2Qone&","&vicor2Qtwo&","&vicor2Qthree&","&vicor2Qfour&","&eos1Qone&","&eos1Qtwo&","&eos1Qthree&","&eos1Qfour&","&craftec1Qone&","&craftec1Qtwo&","&craftec1Qthree&","&craftec1Qfour&","&ault1Qone&","&ault1Qtwo&","&ault1Qthree&","&ault1Qfour&","&ault2Qone&","&ault2Qtwo&","&ault2Qthree&","&ault2Qfour&","&ault3Qone&","&ault3Qtwo&","&ault3Qthree&","&ault3Qfour&","&condor1Qone&","&condor1Qtwo&","&condor1Qthree&","&condor1Qfour&","&pbx1Qone&","&pbx1Qtwo&","&pbx1Qthree&","&pbx1Qfour&","&pbx2Qone&","&pbx2Qtwo&","&pbx2Qthree&","&pbx2Qfour&","&pbx3Qone&","&pbx3Qtwo&","&pbx3Qthree&","&pbx3Qfour&","&pbx3Qfive&","&pbx4Qone&","&pbxt4Qtwo&","&pbx4Qthree&","&pbx4Qfour&","&otherQone&","&otherQtwo&",'"&comments&"');"
conn.execute(sql)
response.write sql
response.redirect("evaluation.html")
Jag har dubbelkollat sa att alla falt stammer overens med vad som ska in..sa det ar inte det som ar fel. Jag kan inte skriva ut sql satsen, jJag har lagt in en check och den reagerar inte pa tomma falt alls sa jag tar for givet att det ar fel pa evalchecksidan nagonstans. Satte precis alla tabellfalt till not required som test i databasen men far fortfarande samma fel.
I min insert fick jag automatisk radbrytning da det var sa manga falt sa jag gjorde en "manuell" radbrytning precis innan VALUES...ar detta ratt?
Jag behover hjalp...please!
/A
Jag är lite osäker på om du verkligen ska ha fnuttar i slutet och i början av raden samt det sista semikolonet.
Borde det inte vara:
sql="INSERT INTO [eval] (fname, osv...) &_
VALUES (' " &fnamne& " ' osv) "
Jo det maste jag nog for annars far jag:
Microsoft VBScript compilation error '800a0409'
Unterminated string constant
/evaluation/documents/evalcheck.asp, line 164
OBS! Jag kan inte se nagon text som ar satt mellan ['KOD] taggar av nagon anledning sa undvik garna dom i denna traden.
HEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEELP!!!
Funkar det om du inte gör radbrytning alls då?
Kan du lägga till en utskift av variabeln sql och visa resultatet.
response.write sql
Det kanske är någon av dina strängar som innehåller en ' eller något. För att skydda sig mot sådant (även av säkerhetsskäl) så måste man lägga till att man byter alla förekomster av ' till '' i sql-statement.
fname=replace(request.form("fname"),"'","''")
'och så vidare med övriga variabler
Testa att göra så här i så fall:
sql = "INSERT INTO [eval]"
sql = sql & "(fname, osv...)"
sql = sql & "VALUES (' " &fnamne& " ' osv... )"
Om jag gor sa som Hypatia visar sa...
/evaluation/documents/evalcheck.asp, line 95
vilket ar: conn.execute(sql)
Sa har ser det ut nu:
sql = sql & "(fname, lname, email, country, vicor1Qone, vicor1Qtwo, vicor1Qthree, vicor1Qfour, vicor2Qone, vicor2Qtwo, vicor2Qthree, vicor2Qfour, eos1Qone, eos1Qtwo, eos1Qthree, eos1Qfour, craftec1Qone, craftec1Qtwo, craftec1Qthree, craftec1Qfour, ault1Qone, ault1Qtwo, ault1Qthree, ault1Qfour, ault2Qone, ault2Qtwo, ault2Qthree, ault2Qfour, ault3Qone, ault3Qtwo, ault3Qthree, ault3Qfour, condor1Qone, condor1Qtwo, condor1Qthree, condor1Qfour, pbx1Qone, pbx1Qtwo, pbx1Qthree, pbx1Qfour, pbx2Qone, pbx2Qtwo, pbx2Qthree, pbx2Qfour, pbx3Qone, pbx3Qtwo, pbx3Qthree, pbx3Qfour, pbx3Qfive, pbx4Qone, pbxt4Qtwo, pbx4Qthree, pbx4Qfour, otherQone, otherQtwo, comments)"
sql = sql & "VALUES ('"& fname &"', '"&lname&"' , '"&email&"' , '"&country&"' , "&vicor1Qone&" , "&vicor1Qtwo&" , "&vicor1Qthree&" , "&vicor1Qfour&" , "&vicor2Qone&" , "&vicor2Qtwo&" , "&vicor2Qthree&" , "&vicor2Qfour&" , "&eos1Qone&" , "&eos1Qtwo&" , "&eos1Qthree&" , "&eos1Qfour&" , "&craftec1Qone&" , "&craftec1Qtwo&" , "&craftec1Qthree&" , "&craftec1Qfour&" , "&ault1Qone&" , "&ault1Qtwo&" , "&ault1Qthree&" , "&ault1Qfour&","&ault2Qone&","&ault2Qtwo&","&ault2Qthree&","&ault2Qfour&","&ault3Qone&","&ault3Qtwo&","&ault3Qthree&","&ault3Qfour&","&condor1Qone&","&condor1Qtwo&","&condor1Qthree&","&condor1Qfour&","&pbx1Qone&","&pbx1Qtwo&","&pbx1Qthree&","&pbx1Qfour&","&pbx2Qone&","&pbx2Qtwo&","&pbx2Qthree&","&pbx2Qfour&","&pbx3Qone&","&pbx3Qtwo&","&pbx3Qthree&","&pbx3Qfour&","&pbx3Qfive&","&pbx4Qone&","&pbxt4Qtwo&","&pbx4Qthree&","&pbx4Qfour&","&otherQone&","&otherQtwo&",'"&comments&"' )"
conn.execute(sql)
response.write sql
LarsG>
INSERT INTO [eval](fname, lname, email, country, vicor1Qone, vicor1Qtwo, vicor1Qthree, vicor1Qfour, vicor2Qone, vicor2Qtwo, vicor2Qthree, vicor2Qfour, eos1Qone, eos1Qtwo, eos1Qthree, eos1Qfour, craftec1Qone, craftec1Qtwo, craftec1Qthree, craftec1Qfour, ault1Qone, ault1Qtwo, ault1Qthree, ault1Qfour, ault2Qone, ault2Qtwo, ault2Qthree, ault2Qfour, ault3Qone, ault3Qtwo, ault3Qthree, ault3Qfour, condor1Qone, condor1Qtwo, condor1Qthree, condor1Qfour, pbx1Qone, pbx1Qtwo, pbx1Qthree, pbx1Qfour, pbx2Qone, pbx2Qtwo, pbx2Qthree, pbx2Qfour, pbx3Qone, pbx3Qtwo, pbx3Qthree, pbx3Qfour, pbx3Qfive, pbx4Qone, pbxt4Qtwo, pbx4Qthree, pbx4Qfour, otherQone, otherQtwo, comments)VALUES ('dasd', 'dasd' , 'dasd@dsad.se' , 'Denmark' , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1 , 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,2,,2,2,1,2,'dsada' )
/evaluation/documents/evalcheck.asp, line 94
Hmmm ser ett tomt fat forresten!!!! Maste leta lite vad det kan vara...
Red. lite sen där...
Hmmm tror att jag har lost det...ett mellanslag hade tagit sig in i ett falt.
Jag aterkommer!
Det funkade... :) Tack for hjalpen allihop! Skont att WF finns!
Medlem sedan mars 200125 inlägg
Kör Trim(Request.Form("namn")) så slipper du mellanslag före å efter strängens början
626 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
150 ms — deklarationer (db)
473 ms — hämta tråd, inlägg och bilagor (db)
146 ms — ändringar (db)
