Tja!
Jag har en sån där Jmail som jag skulle vilja skickade ett svar till alla som använder den.
Alltså nåt i stil med:
"Tack för ditt brev. Det har nu kommit fram till Gustav"
Så här ser det ut för tillfället:
' Create the JMail message Object
set msg = Server.CreateOBject( "JMail.Message" )
' Set logging to true to ease any potential debugging
' And set silent to true as we wish to handle our errors ourself
msg.Logging = true
msg.silent = true
' Most mailservers require a valid email address
' for the sender
if not instr(request.form( "Email" ),"@") >0 then
msg.From = "ingenmail@ifylld.se"
msg.From = request.form( "Email" )
msg.FromName = Request.Form( "Namn" )
' Note that as addRecipient is method and not
' a property, we do not use an equals ( = ) sign
msg.AddRecipient "ekesand@mariterm.se", "Birgitta Ekesand"
' The subject of the message
msg.Subject = Request.Form( "Subject" )
arrList=split(request.form("fieldlist"),",")
for each strField in arrList
msg.appendtext(strField & ": " & Request.form(strField)& vbcrlf )
next
' Now send the message, using the indicated mailserver
if not msg.Send("mail.mariterm.se" ) then
Response.write "<pre>" & msg.log & "</pre>"
Response.write "Ditt mail har skickats!"
' And we're done! the message has been sent.
