har den applikation för att ladda upp bilder. Men hur gör man för att man bara får ladda upp en bild som är max 15 kb?
Det ska komma upp en alert-ruta då.
<!-- Denna upploadkod kommer från sidan [url]www.joakimweb.com[/url] -->
<% Response.Expires = 0 %>
Dim UPLOAD_PATH
UPLOAD_PATH = Server.MapPath("krypinbild/")
Dim g_oFso, g_oFolder, g_oFile
Set g_oFso = Server.CreateObject("Scripting.FileSystemObject")
Set g_oFolder = g_oFso.getFolder(UPLOAD_PATH)
If (Request.ServerVariables("REQUEST_METHOD") = "POST") Then
Dim g_oUpload
Set g_oUpload = get_upload_files()
Dim fpos, fcontent
fcontent = g_oUpload("upload").Item("content")
Set g_oFile = g_oFso.CreateTextFile(UPLOAD_PATH & "\" & extract_filename(g_oUpload("upload").Item("filename")))
For fpos = 1 to LenB(fcontent)
g_oFile.Write chr(AscB(MidB(fcontent, fpos, 1)))
Next
g_oFile.Close: Set g_oFile = Nothing
Response.Redirect Request.ServerVariables("SCRIPT_NAME")
Response.Write "<html><body><table>"
For Each g_oFile In g_oFolder.Files
Next
Response.Write "<tr><td align=""right""><form name=""frmUpload"" method=""post"" enctype=""multipart/form-data"" action=""" & Request.ServerVariables("SCRIPT_NAME") & """>"
Response.Write "<input type=""file"" name=""upload"" style=""Border: 1px solid; font-family: verdana; font-size: 10px""> <input type=""submit"" value=""Ladda upp"" style=""border: #000000 1px solid; font-family: verdana; font-size: 10px""></td></tr>"
Response.Write "</table></body></html>"
Function get_upload_files()
Dim upload_object, request_binaries
Dim position_start, position_end
Dim boundary, boundary_pos
Set upload_object = Server.CreateObject("Scripting.Dictionary")
request_binaries = Request.BinaryRead(Request.TotalBytes)
position_start = 1
position_end = InstrB(position_start, request_binaries, get_byte_string(chr(13)))
boundary = MidB(request_binaries, position_start, (position_end - position_start))
boundary_pos = InstrB(1, request_binaries, boundary)
Do Until (boundary_pos = InstrB(request_binaries, boundary & get_byte_string("--")))
If Not(Response.IsClientConnected) Then Response.End
Dim name, pos_file
position_start = (InstrB(InstrB(boundary_pos, request_binaries, get_byte_string("Content-Disposition")), request_binaries, get_byte_string("name=")) + 6)
position_end = InstrB(position_start, request_binaries, get_byte_string(chr(34)))
name = get_string(MidB(request_binaries, position_start, (position_end - position_start)))
pos_file = InstrB(boundary_pos, request_binaries, get_byte_string("filename="))
If ((pos_file <> 0) AND (pos_file < InstrB(position_end, request_binaries, boundary))) Then
upload_object.Add name, Server.CreateObject("Scripting.Dictionary")
position_start = (pos_file + 10)
upload_object.item(name).Add "filename", get_string(MidB(request_binaries, position_start, (position_end - position_start)))
position_start = (InstrB(position_end, request_binaries, get_byte_string("Content-Type:")) + 14)
upload_object.item(name).Add "content-type", get_string(MidB(request_binaries, position_start, (position_end - position_start)))
position_start = (position_end + 4)
position_end = InstrB(position_start, request_binaries, boundary) - 2
upload_object.item(name).Add "size", ((position_end - position_start))
upload_object.item(name).Add "content", MidB(request_binaries, position_start, (position_end - position_start))
SQL = "SELECT * from members WHERE id = "&session("id")&""
RecSet.Open SQL, Connect, adOpenStatic, adLockOptimistic
RecSet("bild") = "bild_yes"
RecSet.Update
RecSet.Close
boundary_pos = InstrB(boundary_pos + LenB(boundary), request_binaries, boundary)
Loop
Set get_upload_files = upload_object
End Function
Function get_byte_string(str)
Dim cnt
For cnt = 1 to Len(str)
get_byte_string = get_byte_string & chrB(AscB(Mid(str, cnt, 1)))
Next
End Function
Function get_string(str)
Dim cnt
For cnt = 1 to LenB(str)
get_string = get_string & chr(AscB(MidB(str, cnt, 1)))
Next
End Function
Function extract_filename(filename)
extract_filename = "bild"&session("id")&".jpg"
End Function
Observera att Request.TotalBytes är nog lite större än bilden, bla. så skickas övrig formulärdata med. Skicka en bild och skriv ut variabeln, så kan du "trimma" värdet lite uppåt.
