Konstigt pagin fel
5 svar · 223 visningar · startad av FIgg3
Medlem sedan sep. 2001354 inlägg
Hejsan...
Jag har stött på ett mycket konstigt problem må jag säga...
 file = Server.MapPath("book.mdb")
 Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq="& file
 SQL = "SELECT * FROM book ORDER BY ID DESC"
 RecSet.Open SQL, Connect, adOpenStatic, adLockOptimistic
' ####### - PAGIN SCRIPTET STARTAR HÄR - #######
RecSet.pagesize = 10
sida = Request.QueryString("sida")
If sida = "" then sida = 1
if RecSet.EOF then
Response.write "Det finns inga poster att hämta i databasen"
Else
Do until RecSet.EOF or fldcounter = RecSet.pagesize
fldcounter = fldcounter + 1
RecSet.AbsolutePage = sida
totalPages = RecSet.PageCount
                    <b><%=RecSet("Rubrik")%></b><br>
                    <%=RecSet("mess")%><br>
                    <%=RecSet("namn")%>
                    <%If RecSet("hemsida") = "" then
Response.write " - H"
ElseIf RecSet("hemsida") = "http://" then
response.write " - H"
Else
                    - <a href="<%=RecSet("hemsida")%>" target="_blank">H</a>
                    <%End If%>
                    <%If RecSet("mail") = "" then
Response.write " - M"
ElseIf RecSet("mail") = "@" then
response.write " - M"
Else
                    - <a href="mailto:<%=RecSet("mail")%>"> M</a>
                    <%End If%>
                    - <%=RecSet("datum")%> <br>
                    <br>
RecSet.MoveNext
Loop
                    </font><font size="-2" face="Verdana, Arial, Helvetica, sans-serif">br>
                    </font></p>
                  <p>&nbsp;</p>
              </td>
            </tr>
          </table>
        </td>
      </tr>
      <tr>
        <td><img src="down.gif" width="264" height="6"></td>
      </tr>
      <tr>
        <td>&nbsp;</td>
      </tr>
      <tr>
        <td> <img src="top.gif"></td>
      </tr>
      <tr>
        <td background="tb_bg.gif">
          <table width="95%" border="0" cellspacing="0" cellpadding="0" align="center" height="16">
            <tr>
              <td><font size="-2" face="Verdana, Arial, Helvetica, sans-serif">
Response.write "<a href=book.asp?sida=1>Första sidan</a> &nbsp;"
i = 0
For i = 1 to RecSet.PageCount
Response.write "<a href=book.asp?sida="& i &">"& i &"</a> &nbsp;"
Next
Response.write "<a href=book.asp?sida="& totalPages &">Sista sidan</a>"
RecSet.Close
Set RecSet = Nothing
Connect.close
Denna koden fungera bra så länge pagesize är 1 men sätter man det till två t.ex så vissas samma inlägga två gånger och inte två olika, byttar man sida så är det samma där fast med ett nytt inlägg... är det någon som kan hitta vad jag har gjort fel tro?
Ingen?
Medlem sedan apr. 20021 203 inlägg
Förstår inte! Det finns ju ingen variabel som heter Pagesize den heter ju Recset.Pagesize.. sen så förstår jag inte vad du snackar om när du säger att det fungerar då den är ställd till 1...
Du har ju deklarerat den som 10!
Jag menar Recset.Pagesize men jag skrev bara pagesize....
Och ja den är ställd på 10 för att jag testade scriptet först när det var ställt till 1 sedan ställde jag det till 10 och då funkar det inte och nu står 10 kvar....
Flytta dessa rader
så att de ligger innan din do-loop börjar
Tack larsG det funkar nu...
254 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
122 ms — deklarationer (db)
122 ms — ändringar (db)
