Jag har 2 "formfields"
Region och stad.
fråga:
Om man bara väljer region ska den visa alla som har samma värde (fältet "province")
Väljer man stad ska bara matchande städer visas.
Vad ska man ändra nedan?
SQL = "SELECT * From star WHERE (province LIKE '" & Request.Form("stad")& "%' OR city LIKE '" & Request.Form("resort")&_
"%') AND price BETWEEN " & Request.Form("LPrice")& " AND " & Request.Form("HPrice")&_
SQL = "SELECT * From star where price BETWEEN " & _
if Request.Form("stad") <> "" then
sql = sql & " and province LIKE '" & Request.Form("stad") & "%' "
if Request.Form("resort") <> "" then
sql = sql & " and city LIKE '" & Request.Form("resort")& "%'"
Thx, funkar inte riktigt, har säkert satt in koden konstigt
<% Set Connect = Server.CreateObject("ADODB.Connection")
Set RS = Server.CreateObject("ADODB.Recordset")
Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=mindb.mdb"
if Request.Form("region") <> "" then
sql = sql & " and province LIKE '" & Request.Form("region") & "%' "
SQL = "SELECT * From star WHERE price BETWEEN " & Request.Form("LPrice")& " AND " & Request.Form("HPrice")&_
" AND bedr BETWEEN " & Request.Form("beds")& " AND " & Request.Form("bedsh")&_
" AND bathr BETWEEN " & Request.Form("baths")& " AND " & Request.Form("bathsh")&_
" AND htype IN (" & Request.Form("typ")&_
") AND term = '" & Request.Form("sale")&_
"' ORDER BY price DESC"
RS.Open SQL, Connect, 3, 3
") AND term = '" & Request.Form("sale") & "'"
SQL = sql & " ORDER BY price DESC"
If Request.Form("sale") <> "" Then
<font size="2"> <font face="Verdana, Arial, Helvetica, sans-serif" color="#0968AE">Your
search returned
<B><% Response.write RS.RecordCount %></B>
results</font></font></td>
</tr>
</table>
if not rs.eof then
do until rs.eof
<table width="57%" border="0" cellspacing="0" cellpadding="0" height="18">
<tr>
<td width="17%">
<%=rs("tpic")%>
</td>
<td width="27%"><font face="Verdana" size="1"><A HREF="detail.asp?id=<%=rs("ID")%>"><%=rs("City")%></A><BR><%=rs("Province")%></font></td>
<td width="12%"><font face="Verdana" size="1"><%=rs("bedr")%></font></td>
<td width="10%"><font face="Verdana" size="1"><%=rs("bathr")%></font></td>
<td width="14%"><font face="Verdana" size="1"><%=rs("htype")%></font></td>
<td width="20%"><font face="Verdana" size="1"> €<% Response.Write FormatNumber(rs("price"), 0, -1, -1) %></font></td>
</tr>
</table>
<table width="57%" border="0" cellspacing="0" cellpadding="0">
<tr>
<td><img src="line.gif" width="560" height="1"></td>
</tr>
</table>
<br>
<%rs.movenext
loop
Hittade inget.
rs.close
set rs=Nothing
Connect.close
set connect=nothing
277 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
