Varför visas inga resultat?
17 svar · 276 visningar · startad av Lazerzubb
Medlem sedan mars 2000542 inlägg
Jag får inga resultat här även om min "kan ej vara korrekt" a kod som räknar antal träffar visar att det finns träffar, och jag vet att det ska finnas träffar.
Mvh.
<%	Set Connect = Server.CreateObject("ADODB.Connection")
	Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=databas.mdb"
If Request.Form("city") <> "" Then
SQL = "SELECT * From star WHERE province LIKE '" & Request.Form("city")& "%' OR city LIKE '" & Request.Form("city")&_
 "%' AND price BETWEEN '" & Request.Form("LPrice")& "%' AND '" & Request.Form("HPrice")&_
 "%' AND bedr BETWEEN '" & Request.Form("beds")& "%' AND '" & Request.Form("bedsh")&_
 "%' AND bathr BETWEEN '" & Request.Form("baths")& "%' AND '" & Request.Form("bathsh")&_
 "%' AND htype LIKE '" & Request.Form("typ")&_
 "%' AND term LIKE '" & Request.Form("rental")&_
 "%' ORDER BY price DESC"
set rs=Connect.Execute(SQL)
mSQL = "SELECT COUNT(*) from star where city LIKE '%" & Request.Form("City") & "%' AND htype LIKE '" & Request.Form("typ")&_
 "%' OR province LIKE '" & Request.Form("City")& "%' AND htype LIKE '" & Request.Form("typ")&_
 "%' AND term LIKE '" & Request.Form("rental")& "%'"
set rs1=Connect.Execute(mSQL)
Your
      search returned
      <B><% Response.write RS1(0) %></B>
if not rs.eof then
do until rs.eof
<table width="57%" border="0" cellspacing="0" cellpadding="0" height="18">
  <tr>
    <td width="17%">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
<IMG SRC="picture5.gif" alt="" border="0">
    </td>
    <td width="27%"><font face="Verdana" size="1"><%=rs("City")%><BR><%=rs("Province")%></font></td>
    <td width="12%"><font face="Verdana" size="1"><%=rs("bedr")%></font></td>
    <td width="10%"><font face="Verdana" size="1"><%=rs("bathr")%></font></td>
    <td width="14%"><font face="Verdana" size="1"><%=rs("htype")%></font></td>
    <td width="20%"><font face="Verdana" size="1">&nbsp;&euro;<%=rs("price")%></font></td>
  </tr>
</table>
<table width="57%" border="0" cellspacing="0" cellpadding="0">
  <tr>
    <td><img src="line.gif" width="560" height="1"></td>
  </tr>
</table>
<br>
<%rs.movenext
loop
Hittade inget.
rs.close
set rs=Nothing
Connect.close
set connect=nothing
SQL = "SELECT * From star WHERE (province LIKE '" & Request.Form("city")& "%' OR city LIKE '" & Request.Form("city")&_
 "%') AND price BETWEEN '" & Request.Form("LPrice")& "' AND '" & Request.Form("HPrice")&_
 "' AND bedr BETWEEN '" & Request.Form("beds")& "' AND '" & Request.Form("bedsh")&_
 "' AND bathr BETWEEN '" & Request.Form("baths")& "' AND '" & Request.Form("bathsh")&_
 "' AND htype = '" & Request.Form("typ")&_
 "' AND term = '" & Request.Form("rental")&_
 "' ORDER BY price DESC"
% är bara relevant om du använder like
Nu tittade jag inte på din andra select.
Tack, men den vill fortfarande inte visa något.
Mvh.
jag förstår inte varför din fråga med select count(*) har andra villkor än din första fråga.
Ett annat problem är att du hanterar numeriska värden, t.ex. price som om det vore strängar.
Ett villkor som
where price between '7' and '10'
är aldrig sant
Ett villkor som
kod:--------------------------------------------------------------------------------
är aldrig sant
Snälla förklara, inte bra på asp, jag ska byta ut koden i "count" så att den blir samma som i SQL.
Strängar jämförs tecken för tecken, så om du har villkoret
if "8" < "10" then
så är det inte uppfyllt eftersom "8" är större än "1".
Thx, hur gör jag för att göra så att priset gämförs som ett helt tal?
Du får byta datatyp till number i databasen och i ditt villkor får du ta bort alla apostrofer
AND price BETWEEN " & Request.Form("LPrice")& " AND " & Request.Form("HPrice")&_
Detta borde väl även gälla bedr och bathr
Får felmeddelande.
 "%') AND price BETWEEN " & Request.Form("LPrice")& " AND " & Request.Form("HPrice")&_
 " AND bedr BETWEEN " & Request.Form("beds")& " AND " & Request.Form("bedsh")&_
 " AND bathr BETWEEN " & Request.Form("baths")& " AND " & Request.Form("bathsh")&_
 "' AND term = '" & Request.Form("sale")&_
Mvh.
Vad för felmeddelande?
Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
[Microsoft][ODBC Microsoft Access Driver] Syntax error (missing operator) in query expression '(province LIKE 'cannes%' OR city LIKE 'cannes%') AND price BETWEEN 0 AND 99000000' AND bedr BETWEEN 0 AND 999' AND bathr BETWEEN 0 AND 999' AND htype = 'Villa' AND term = 'Sale' ORDER BY price DESC'.
Du har en apostrof före AND bathr och en före AND htype .
De ska nog inte vara där.
Mvh,
Ser ut att funka nu, tack!!!
Vilken kod ska jag ha för att få summan att visas rätt när det kommer till antal sökträffar.
mSQL = "SELECT COUNT(*) from star WHERE (province LIKE '" & Request.Form("city")& "%' OR city LIKE '" & Request.Form("city")&_
 " AND htype = " & Request.Form("typ")&_
 "' AND term = '" & Request.Form("sale")& "%'"
Jag är inte helt säker på att jag förstår frågan, men jag gör ett försök...
Response.write rs1(0) & " antal träffar"
Mvh,
Jag skriver ut resultatet med
Men "COUNT" koden funkar inte.
 AND price BETWEEN 0 AND 99000000 AND bedr BETWEEN 0 AND 999 AND bathr BETWEEN 0 AND
 999 AND htype = Villa' AND term = 'Sale%''.
Ah jag fixade det med
        Set RS    = Server.CreateObject("ADODB.Recordset")
If Request.Form("sale") <> "" Then
 " AND htype = '" & Request.Form("typ")&_
RS.Open SQL, Connect, 3, 3
och
<% Response.write "<tr><td>" & RS.RecordCount & " poster funna</td></tr>"
Det saknas en apostrof framför villa.
Kan ta det här också.
Om jag har
<input type="radio" name="typ" value="Villa">
  Villa<br>
  <input type="radio" name="typ" value="Apartment">
  Apartment<br>
  <input type="radio" name="typ" value="" checked>
  Both <br>
I Formuläret, och vill att both ska visa både apartment och villa, hur gör jag det?
Söksträngen:
260 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
119 ms — deklarationer (db)
128 ms — ändringar (db)
