Problem med ASP-SMART-UPLOAD
13 svar · 464 visningar · startad av voigtann1
<HTML>
<BODY BGCOLOR="white">
' Variables
Dim mySmartUpload
Dim file
Dim oConn
Dim oRs
Dim intCount
intCount=0
' Object creation
Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
' Connect to the DB
set oConn = Server.CreateObject("ADODB.Connection")
oConn.Open "driver={Microsoft Access Driver (*.mdb)};dbq=" & server.mappath("db/config.mdb")
' Open a recordset
'strSQL = "SELECT * FROM nobrain ORDER BY id DESC"
'strSQL = "SELECT * from files order by filename,FILE"
strSQL = "SELECT * from files order by filename"
Set oRs = Server.CreateObject("ADODB.recordset")
Set oRs.ActiveConnection = oConn
oRs.Source = strSQL
oRs.LockType = 3
oRs.Open
' Select each file
For each file In mySmartUpload.Files
' Only if the file exist
If not file.IsMissing Then
  '  Add the current file in a DB field
     oRs.AddNew
     file.FileToField oRs.Fields("FILE")
	 oRs("filename") = file.FileName
     oRs.Update
     intCount = intCount + 1
Next
' Only allow txt or htm files
mySmartUpload.AllowedFilesList = "cfg"
' DeniedFilesList can also be used :
' Allow all files except exe, bat and asp
' mySmartUpload.DeniedFilesList = "exe,bat,asp"
' Deny physical path
mySmartUpload.DenyPhysicalPath = True
' Only allow files smaller than 50000 bytes
mySmartUpload.MaxFileSize = 50000
' Deny upload if the total fila size is greater than 200000 bytes
mySmartUpload.TotalMaxFileSize = 200000
' Upload
mySmartUpload.Upload
' Save the files with their original names in a virtual path of the web server
intCount = mySmartUpload.Save("members/" & session("user"))
' sample with a physical path
' intCount = mySmartUpload.Save("c:\temp\")
' Trap errors
If Err Then
Response.Write("<b>ERROR</b><br> You tried to upload something diffrent then: *.cfg, *.txt, *.exe")
Else
' Display the number of files uploaded
Response.Write(intCount & " file(s) uploaded.")
' Destruction
oRs.Close
oConn.Close
Set oRs = Nothing
Set oConn = Nothing
</BODY>
</HTML>
jag klarar uploada filerna .... men dom sparars inte i databasen.. har försökt mixtra med koden som man fick till men det fungera inte.....
detta är ju helt knäppt!
jag vill ha så att den lägger till:
användarnamnet(session)
sen vilken spel det ska läggas i... men det går inte.. får bara en massa errors... har aldrig sett någon sådan här kod i ASP innan.. knäppt!
ingen som använder ASPsmartupload eller?
Är du säker på att du har rätt fält i databasen?
efter många timmas tystnad så började jag pilla.. nu har jag fått allt att fungera.. förutom att man inte kan lägga till någon annan info än filnamnet och ActiveX-objekt.... blir skit sur....:
   strSQL = "SELECT user,game,mo,global,version,dl,FILENAME,FILE FROM Files"
   oRs.Source = strSQL
   oRs.LockType = 3
   oRs.Open
'  Select each file
         oRs.AddNew
		 oRs("FILENAME") = file.FileName
		 oRs("user") = session("user")
		 oRs("game") = "test"
		 oRs("mo") = "test"
		[b] oRs("global") = upload.Request("global")[/b]
		 oRs("version") = "test"
		 oRs("dl") = "0"
         oRs.Update
   Next
Error Type:
Request object, ASP 0208 (0x80004005)
Cannot use the generic Request collection after calling BinaryRead.
Den får ingen data från den andra.. eller så vill den inte ta datan från den andra... VILL VETA HUR MAN FIXAR!!!
snyft!
Kanske.. http://www.aspsmart.com/liblocal/docs/en/aspsmartupload/help/Requirements.htm
Tror felet blir pga av att du inte kan köra request mm
Om du läser object ref. till asp smart upload på deras hemsida så ser du hur du ska göra, de har även en del exempel.
Solbulle och jag har fixat det här.. =) glömde skriva det =) tack så mycket för alla svar
Konstigt detta...
Hade precis samma problem igår :)
Medlem sedan juli 2002252 inlägg
skriv gärna hur ni löste det... har samma problem nu - tråkigt att inte hitta lösningen här :OO
MrHaze
Vad har du för stött på för problem ?
Om man läser dokumentationen på https://www.aspsmart.com kan man lösa typ allt :) Men posta gärna vad som du misslyckas med
Problemet som ALLA verkar ha med ALLA typer av uploadscript/komponenter är att man gör fel vid uppladdningen av formulärsfält.
Först måste man köra uploaden:
Vidare använder man sig INTE av request.form utan av komponentens "inbyggda" variant, i detta fallet:
mySmartUpload.Form("text")
Bäst att lyda Solbulle, han kanske tar fram en käpp och börjar slå oss mindre begåvade... :P
Ha ha, jo jag har den i bakfickan. ;)
Jag har gjort samma fel jag med, det behöver ju inte vara det som som strular men oftast blir svaret att det är där felet ligger.
124 ms — deklarationer (db)
121 ms — ändringar (db)
