hjälp med att byta ut cdonts till aspsmartmail i scriptet
24 svar · 627 visningar · startad av medialabs
SKulle behöva hjälp med att byta ut cdonts mailen till Aspsmartmail istället.....
<html>
<title>CodeAve.com(404 - File Not Found)</title>
<body bgcolor="#FFFFFF">
<% querystring=trim(replace(request.servervariables("query_string"),"404;",""))
' Grab the server varible for querystring. If the user was redirected to
' this page beacuse a file was not found the server variable query_string
' would contain a string similar to this convention
' 404;http://www.yourservsername.com/name_of_missing_file.ext
' for display pirposes the 404; is removed via text replace
if querystring <> "" then %>
The item you were looking for <br>
<%= querystring %> <br>
could not be located on the server.<br>
An email message has been sent to the webmaster to correct this ASAP.<p>
' If you have CDONTS installed this will send a mail message to any address you want
' However, this portion of the script has been commented out to avoid us getting mail
' from the output of this script
if right(referrer,3) <> "ico" then
' Check to see if the file missing is an ico request
' IE 5 looks for it everywhere and you may want to filter it out
' as a 404 error for an favicon.ico or one with a broken link in
' LINK REL="SHORTCUT ICON" will not result in the user being redirected to this page
' Here we begin building our mail message varible
' by stating which document as missing and when the error occurred
' and follwing it with all the servervaribles (This will tell which browser
' they were using and a few other helpful items
' message = message + "The following page was requested and not found on the server at " & now() &chr(13)
' message = message & querystring & "<br> Below are all the server varibles for the request<p>" & message_rpt
' set sm = server.createobject("CDONTS.newmail")
' Create the CDONTS mail object
' sm.from = "from_mail_address@yourserver.com"
' sm.to = "to_mail_address@yourserver.com"
' Set the mail adress for the sender and the mail address that
' will receive the message they both should be valid addresses
' sm.subject = "File Not Found - "& querystring
' Create a subject with name of the location that was requested
' sm.bodyformat = 0 'if sending as HTML
' sm.mailformat = 0 'if sending as HTML
' Place the mail format to html
' sm.body = message
' Set the body of the message equal to the text string created
' sm.send
' Send the mail message
' set sm = nothing
' Clean up the server
end if 'End check for .ico files
' If a user were to directly hit your 404 error page
' without generating an error display this alternate message
You have reaced the 404 error page however,<br>
we could not detect a broken link or a missing file<p>
<% end if 'end check of querystring values %>
To return to the page you were previously on click <a href="javascript:history.back()">here</a>.
</html>
MVH
OJJE
icq: 126670708
msn: javawebb@swipnet.se
Behöver hjälp med detta nu!! =)
Snäll! =(
Kan ingen hjälpa mig??
Skulle vara otroligt tacksam om man fick hjälp med detta!!!
Har du försökt?
http://www.aspsmart.com/
<HTML> <BODY BGCOLOR="white">
<H1>aspSmartMail : Sample 1</H1> <HR>
<%  	On error resume next
	Dim mySmartMail
Set mySmartMail = Server.CreateObject("aspSmartMail.SmartMail")  '	Mail Server '	*********** 	mySmartMail.Server = "mail.yourdomain.com"  '	From '	**** 	mySmartMail.SenderName = "Your Name" 	mySmartMail.SenderAddress = "youremail@yourdomain.com"  '	To '	** 	mySmartMail.Recipients.Add "yourfriend@anydomain.com", "Friend's name"  '	Message '	******* 	mySmartMail.Subject = "aspSmartMail Sample 1" 	mySmartMail.Body = "This mail has been sent with aspSmartMail."  '	Send the message '	**************** 	mySmartMail.SendMail  	if Err.Number<>0 then  		Response.write "Error: " & Err.description  	else  		Response.write "An e-mail has just been sent to " & mySmartMail.Recipients.Item(1).Name & "."  	end if  %> </body> </html>
red. asch, inte gick det att klistra in det där inte...
Tror detta bör fungera, du får ändra alla epostadresser o server.
<html>
' 404;[url]http://www.yourservsername.com/name_of_missing_file.ext[/url]
Dim mySmartMail
'	Mail Server
'	From
'	To
 	mySmartMail.Recipients.Add "youremail@anydomain.com", "Your Name"
' mySmartMail.Subject  = "File Not Found - "& querystring
' mySmartMail.Body = message
' mySmartMail.SendMail
To return to the page you were previously on click <a href="java script:history.back()">here</a>.
</html>
Red. mailserver finns nu.
d
Var ska jag ställa in Min mail server.
D.v.s : mail.domain.com ??
Hupp, de raderna "försvann" visst:
' Mail Server
Sätter du in efter raden:
Tack!
Nu funkar 404 sidan som den skaoch jag får ett mail varje gång man kommer till en "trasig" sida!
Kul :birp
RE
Detta är mailet jag får tillbaka.
Från: OJJE <noreply@domain.fdfdf> Svara
Ämne: File Not Found - http://www.domain.com/fdsf.asp
Datum: Sat, 30 Mar 2002 01:49:50, +0100
The following page was requested and not found on the server at 2002-03-30 01:49:50
http://www.domain.nu/fdsf.asp Below are all the server varibles for the request
Vet du hur man snyggar upp detta??
Så att det blir lättare att kolla på detta och om man kan includera besökarens ip adress???
Nu ska du få så du tiger ;)
Släng in detta: (byt ut, ja du fattar)
 message = message + "Denna sida söktes men hittades inte på servern vid: " & now() &chr(13)
 message = message & "<br>" & querystring & "<br> Här följer fakta om webläsaren mm:<p>"
For Each objItem In Request.ServerVariables
 message = message & objItem & ": " & Request.ServerVariables(objItem) & "<BR>"
Next
Vill du inte ha all den faktan kan du köra typ:
 message = message & "Refererande sida: " & request.servervariables("remote_addr")
 message = message & "IP-adress: " & request.servervariables("remote_addr")
Hehe, blev mycket snyggare direkt! tack! tack!!
hehe.. har du mer att komma med eller tog det slut nu?! :OO :bire
Hm... vad vill du mer ha nu då?
En tanke bara, du har aldrig tänkt på att gå o lägga dig o så? :e
allt som går!
Hehe.. Sova??
det har jag inte gjort på länge... sitter med en Coca Cola här och kollar på Jay Leno show!
Men vad mer skulle man kunna inkluidera på en 404 sida???
Attans, vi kan nog ta varann i hand :birp
Prövade du det övre av scriptsnuttarna? Den med For each osv.
Den listar alla servervariabler du kan få reda på, du kan ju välja att bara plocka ut de som du vill ha. (Som vi gjorde i det nedre exemplet.)
Ja,
Jag använder den nedre kåååden. men jag ska slänga ett öga på den övre raden imorrn :OO
Nä, nu är det dags att låta datorn svalna ett par timmar. :r
Men jag är evigt tacksam för all hjälp jag har fått av dig! :bire :birp
Sov gått! :stud
Medlem sedan jan. 2003188 inlägg
hmm en liten fråga bara??? vad har du skrivit på html sidan?? behöver lite hjälp med den...
vad menar du med HTML sidan?
alltså... om man kopplar felmeddalnden direkt till en .asp fil så funkar det ju inte... så som jag har gjort nu är att jag har en html fil som sedan skickas atomatiskt till en asp fil som visar felmeddalandet och skickar ett mejl... men hur har du gjort då??
jag döpte den till 404.asp istället för en html fil.....
mm... det gjorde jag också... men då funkade den inte som en asp fil... och om man högerklickade och visade källa... så såg man all kod... även asp koden... och det skickades inget mejl...
270 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
122 ms — deklarationer (db)
145 ms — hämta tråd, inlägg och bilagor (db)
118 ms — ändringar (db)
