bild storlek
11 svar · 839 visningar · startad av jns
jnsMedlem sedan dec. 2001132 inlägg
hur kan man få reda på storleken på en bild? Alltså hur många pixlar hög/bred bilden är.
if Request.Querystring.count = 0 then
response.write "fel"
Dim Bild,text
Bild = Request.QueryString("bild")
text = Request.QueryString("text")
response.write "text: "&text &"<br>"
response.write "Bild namn: "&bild &"<br>"
function GetBytes(flnm, offset, bytes)
Dim objFSO
Dim objFTemp
Dim objTextStream
Dim lngSize
on error resume next
Set objFSO = CreateObject("Scripting.FileSystemObject")
' First, we get the filesize
Set objFTemp = objFSO.GetFile(flnm)
lngSize = objFTemp.Size
set objFTemp = nothing
fsoForReading = 1
Set objTextStream = objFSO.OpenTextFile(flnm, fsoForReading)
if offset > 0 then
strBuff = objTextStream.Read(offset - 1)
if bytes = -1 then ' Get All!
GetBytes = objTextStream.Read(lngSize) 'ReadAll
GetBytes = objTextStream.Read(bytes)
objTextStream.Close
set objTextStream = nothing
set objFSO = nothing
end function
function lngConvert(strTemp)
lngConvert = clng(asc(left(strTemp, 1)) + ((asc(right(strTemp, 1)) * 256)))
end function
function lngConvert2(strTemp)
lngConvert2 = clng(asc(right(strTemp, 1)) + ((asc(left(strTemp, 1)) * 256)))
end function
function gfxSpex(flnm, width, height, depth, strImageType)
dim strPNG
dim strGIF
dim strBMP
dim strType
strType = ""
strImageType = "(unknown)"
gfxSpex = False
strPNG = chr(137) & chr(80) & chr(78)
strGIF = "GIF"
strBMP = chr(66) & chr(77)
strType = GetBytes(flnm, 0, 3)
if strType = strGIF then
strImageType = "GIF"
Width = lngConvert(GetBytes(flnm, 7, 2))
Height = lngConvert(GetBytes(flnm, 9, 2))
Depth = 2 ^ ((asc(GetBytes(flnm, 11, 1)) and 7) + 1)
gfxSpex = True
strBuff = GetBytes(flnm, 0, -1)
lngSize = len(strBuff)
flgFound = 0
strTarget = chr(255) & chr(216) & chr(255)
flgFound = instr(strBuff, strTarget)
if flgFound = 0 then
exit function
lngPos = flgFound + 2
ExitLoop = false
do while ExitLoop = False and lngPos < lngSize
do while asc(mid(strBuff, lngPos, 1)) = 255 and lngPos < lngSize
lngPos = lngPos + 1
loop
if asc(mid(strBuff, lngPos, 1)) < 192 or asc(mid(strBuff, lngPos, 1)) > 195 then
lngMarkerSize = lngConvert2(mid(strBuff, lngPos + 1, 2))
lngPos = lngPos + lngMarkerSize + 1
ExitLoop = True
loop
if ExitLoop = False then
Width = -1
Height = -1
Depth = -1
Height = lngConvert2(mid(strBuff, lngPos + 4, 2))
Width = lngConvert2(mid(strBuff, lngPos + 6, 2))
Depth = 2 ^ (asc(mid(strBuff, lngPos + 8, 1)) * 8)
gfxSpex = True
end function
sub test(flnm)
if right(flnm, 3)="gif" then
flgFound = 0
strImageType = "JPG"
ExitLoop = false
lngPos = lngPos + 1
loop
ExitLoop = True
loop
if ExitLoop = "False" then
Width = -1
Height = -1
Depth = -1
a=width
b=height
response.write("Mått:<br>" &a &"*" &b &"<br>")
end sub
call test(server.mappath("bilder/" &Bild& ""))
response.write "<img border=""0"" src=""bilder/" &Bild& """><br>"
<html>
<body>
</html>
men det går att lösa med JavaScript med.. och det e mindre kod med JavaScript... bästa är PHP
Dim Bild,text,rubrik
rubrik = Request.QueryString("rubrik")
<img src="bilder/<%=bild%>" name="bilden"><br>
response.write "Rubrik: <b>"&rubrik &"</b><br>"
<script language="javascript">
document.write(" Mått: " +document.bilden.width + " * " + document.bilden.height);
nu förstår jag nästan ingenting :q... hur kan man göra med javascript då? jag har en form där man fyller i adressen till bilden... typ http://www.kallessida.com/bild.gif ?
Red. Å jag håller klaffen för voigtan verkar fixa biffen... :r
om vi spara denna fil som bilder.asp
så anropar du med formen:
ifylnningsformuläret döper vi "show_this_pic"
så här:
Dim Bild
Bild = Request.Form("show_this_pic")
<img src="<%=bild%>" name="bilden"><br>
ok nu förstår jag.. tack... men kan man göra detta utan att visa bilden... och kan man få över dessa värden till asp:n?
du vill att dom ska sparas i en databas???
hmm.. okey... låt mej tänka lite... gör så här:
skapar en databas:
ID
bildnamn
height
width
om du har gjort ett formulär som jag sa.. så gör du så att den ska köra på add.asp (eller vad du vill)
i add.asp:
Dim Bild
connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=" & server.MapPath("db/databas.mdb")Set RecSet = Server.CreateObject("ADODB.Recordset")
Addera = "SELECT * FROM pcs ORDER BY id DESC"
RecSet.Open Addera, Connect, 3, 3
RecSet.AddNew
RecSet("bildnamn") = Bild
RecSet("width") = document.bilden.width
RecSet("height") = document.bilden.height
RecSet.Update
RecSet.Close
Connect.Close
Response.Redirect "/voigtan/olis/admin/Chaform.asp"
eller något.. du kanske måste göra document.bilden.width och height till någon verbial.. du får testa lite
easMedlem sedan sep. 2001269 inlägg
<body onload="document.hbForm.bredd=document.bilden.width; document.hbForm.hojd=document.bilden.height">
Dim Bild
IF Request.Form("bredd") <> "" THEN
ELSE
      Bild = Request.Quertstring("bild")
END IF
<form name=hbForm action="denHärFilen.asp?bild=<%=Request.Form("show_this_pic")%>" method=post>
<inut type=hidden name=bredd>
<inut type=hidden name=hojd>
document.write(" Mått: " +document.bilden.width+ " * " + document.bilden.height);
<a href="#" onclick="document.hbForm.submit()">Spara i databasen</a>
RecSet.AddNew
RecSet("width") = Request.Form("bredd")
RecSet("height") = Request.Form("hojd")
RecSet.Update
RecSet.Close
Connect.Close
Response.Redirect "enSida.asp"
END IF
Koden kanske inte funkar helt perfekt och får gjärna förbättras.
PatrikBMedlem sedan mars 20002 836 inlägg
med javascript på klientsidan så kan du kolla hur bred bilden är, hur hög den är och hur många byte den är på.
Du behöver alltså inte ladda upp hela bilden för att kolla detta.
Testa denna:
<HTML>
<HEAD>
<TITLE>Untitled Document</TITLE>
<META http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<SCRIPT language="javascript">
function imgSize(obj, w, h, fs){
	var imgpath = obj.value;
	var imgTemp = new Image();
	imgTemp.src = imgpath;
	// -- kontrollera hur bred bilden är --
	if (imgTemp.width >= w){
		alert('Bilden är för bred.\nDen får max. vara ' + w + ' pixlar bred.\n\nVälj en annan bild.');
		document.location.reload();
	// -- kontrollera bildens höjd --
	}else if(imgTemp.height >= h){
		alert('Bilden är för hög.\nDen får max. vara ' + h + ' pixlar hög.\n\nVälj en annan bild.');
	// -- kontrollera hur stor bilden är i bytes --
	}else if(imgTemp.fileSize > fs){
		alert('Bilden får inte vara mer än ' + fs + ' byte stor.\n\nVälj en annan bild.');
	imgTemp.src = '';
</SCRIPT>
</HEAD>
<BODY bgcolor="#FFFFFF" text="#000000">
<FORM name="form1" method="post" action="test.asp" enctype="multipart/form-data">
  <INPUT type="file" name="file" onChange="imgSize(this, 100, 50, 100);">
  <INPUT type="submit" name="Submit" value="Submit">
</FORM>
</BODY>
</HTML>
anropas så här imgSize(this, bildensbredd, bildenshöjd, bildensstorlekibyte)
finns en hel del "luckor" i koden ..... men, så är jag ingen javascriptare. ta denna kod in i det forumet så hjälper dem dig vidare för att få den att känna av bilden i eventet onSubmit istället + att den ska kika efter filändelsen.
ändrade så att den reloadade sidan och då blir det ingen bild som kan laddas upp :e
cya,
PatrikB
WickmarkMedlem sedan juli 2003162 inlägg
Dim Bild,text
Dim objFSO
Dim objFTemp
Dim objTextStream
Dim lngSize
fsoForReading = 1
if offset > 0 then
objTextStream.Close
end function
end function
end function
dim strPNG
dim strGIF
dim strBMP
dim strType
strType = ""
gfxSpex = False
strGIF = "GIF"
gfxSpex = True
flgFound = 0
exit function
ExitLoop = false
lngPos = lngPos + 1
loop
ExitLoop = True
loop
Width = -1
Height = -1
Depth = -1
gfxSpex = True
end function
sub test(flnm)
flgFound = 0
ExitLoop = false
lngPos = lngPos + 1
loop
ExitLoop = True
loop
Width = -1
Height = -1
Depth = -1
a=width
b=height
end sub
<html>
<body>
</html>
Hur gör jag om jag vill få precis alla filerna i en speciell mapp att bli uppradade med både höjd och bredd utskrivet ?
Tex:
< a href="LaggTillIDatabas.asp?hojd=[HÖJD]&bredd=[BREDD]" >
137 ms totalt · 3 externa anrop · v20260731065814-full.fb544a5a
