Har Problem med QueryString
6 svar · 305 visningar · startad av MystiX
MystiXMedlem sedan mars 200218 inlägg
Suttit Nu i ett jäkla tag men det vägrar funka
Jag är en nybörjare inom ASP + att jag har testar lite grejer i denna kod + att jag skulle börja snygga till den när jag fått allt å funka :)
Hjälp vore snällt
<% Response.Buffer = TRUE %>
<html>
<!-- #include virtual="/databas/adovbs.inc" -->
Dim IDnum
Idnum = Request.QueryString("ID")
If Idnum2 = "" Then
Idnum2 = Idnum
<meta http-equiv="Content-Language" content="sv">
<meta name="GENERATOR" content="Microsoft FrontPage 5.0">
<meta name="ProgId" content="FrontPage.Editor.Document">
<meta http-equiv="Content-Type" content="text/html; charset=windows-1252">
<title>MystiX Soccer System</title>
<body>
<p style="margin-top: 0; margin-bottom: 0"> </p>
<p style="margin-top: 0; margin-bottom: 0" align="center"><font face="Verdana">
MystiX Soccer System</font></p>
<p> </p>
<table border="0" cellpadding="0" cellspacing="0" style="border-collapse: collapse" bordercolor="#111111" width="60%" height="206">
<tr><% =IDnum %><br>
<% =IDnum2 %>
<td width="17%" height="206" align="left" valign="top">
<p style="margin-top: 0; margin-bottom: 0"><font size="1" face="Verdana">
response.write "<a href='login.asp?ID=" & recset("ID") & "'> Account</a>"
<font color="#000000">Account Setup</font></a></font></p>
<a href="soccer.asp?ID=" & RecSet("ID")&soccer=predict">
<font color="#000000">New Predic</font></a></font></p>
<p> </td>
<% If Request.QueryString("soccer") = add Then %>
Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=c:\inetpub\wwwroot\asp\soccer\soccer.mdb"
Set RecSete = Server.CreateObject("ADODB.Recordset")
Visa = "SELECT * FROM users WHERE ID = " & Request.Form("ad") & " "
RecSete.Open Visa, Connect, adOpenStatic, adLockOptimistic
RecSete("Name") = Request.Form("Name")
RecSete("Email") = Request.Form("Email")
RecSete("Password") = Request.Form("Password")
RecSete.Update
RecSete.Close
Connect.Close
If Session("Admin") = "" Then
Response.Redirect "adminsite.htm"
If Request.QueryString("soccer") = "account" Then
Dim Idnum2
Idnum2 = Request.QueryString("ID")
Updater = "SELECT * FROM users WHERE ID = " & Trim(Request.QueryString("ID")) & " "
RecSet.Open Updater, Connect, adOpenStatic, adLockOptimistic
\<td width="55%" height="206" align="left" valign="top"\>
\<form method="POST" action="soccer.asp?ID=\<% =Request.Form("ad") %\>&soccer=add" onsubmit="return FrontPage_Form1_Validator(this)" language="JavaScript" name="FrontPage_Form1"\>
  \<p style="margin-top: 0; margin-bottom: 0"\>&nbsp;\</p\>
  \<input type="hidden" name="AD" value="\<% =Idnum2 %\>"\>
  \<p style="margin-top: 0; margin-bottom: 0"\>Name\</p\>
  \<!--webbot bot="Validation" b-value-required="TRUE" i-minimum-length="1" i-maximum-length="100" --\>\<input type="text" name="Name" Value="\<% =RecSet("Name") %\>" size="20" maxlength="100"\>\</p\>
  \<p style="margin-top: 0; margin-bottom: 0"\>Email:\</p\>
  \<!--webbot bot="Validation" b-value-required="TRUE" i-minimum-length="1" i-maximum-length="100" --\>\<input type="text" name="Email" Value="\<% =RecSet("Email") %\>" size="20" maxlength="100"\>\</p\>
  \<p style="margin-top: 0; margin-bottom: 0"\>Password\</p\>
  \<!--webbot bot="Validation" b-value-required="TRUE" i-minimum-length="1" i-maximum-length="100" --\>\<input type="text" name="Password" Value="\<% =RecSet("Password") %\>" size="20" maxlength="100"\>\</p\>
  \<p\>\<input type="submit" value="Save" name="B1"\>
  \<input type="reset" value="Reset All" name="B2"\>\</p\>
\</form\>
 </td>
<% End If %>
<td width="28%" height="206" align="left" valign="top"> </td>
</tr>
</table>
</html>
Glömde kanske å säga att det är när man ska hämta informationen från Databasen till fältena + när man ska redigera från fältena till Databasen, det verkar bli nå mongo med QueryStringen.
Ska det vara olika variabelnamn: IDnum och idnum mfl?
vidare verkar det saknas lite fnuttar, tex:
ska väl vara:
If Request.QueryString("soccer") = "add"
<a href="soccer.asp?ID=<% RecSet("ID")%>&soccer=predict">
<input type="hidden" name="ad" value="<% =Idnum2 %>">
Nja ska ju bara kunna hålla reda på ID numret.
Nu funkar allt som det ska förutom efter man addat infon
då blire ID´n i QueryStringen såhär soccer.asp?ID=
Och då blir fel i alla länkar sen.
Nån som har nån aning om hur man ska fixa det, fixa å trixxa med min kod bara det funkar så :)
sawMedlem sedan mars 20011 880 inlägg
Ett av det första du måste göra är ju att rensa upp, så att du ser vad du har skrivit. Det här är ju inget vidare:
Här har du en p style förmycket, dessutom så har du skrivit in en reponse.write mitt i en HTML-formatering.
En annan sak, gör inte så här:
Dim IDnum
If Idnum2 = "" Then
Idnum2 = Idnum
Lägg så mycket du kan inom ASP-tagen. Att hålla på och öppna ASP-taggarna, och därefter stänga för att på nästa rad öppna igen är helt förkastligt.
Jag fixade det Hehe
Tack Iaf
Fungerar allt nu?
Bra i så fall.
136 ms totalt · 3 externa anrop · v20260731065814-full.0e50b1ef
