jobbigt paging fel :(
2 svar · 198 visningar · startad av Cactuz
Medlem sedan okt. 2001670 inlägg
KOD:
Set objRs = Server.Createobject("Adodb.Recordset")
strSQL = "Select * from anvandare Order by id asc"
strConString = "Provider=Microsoft.Jet.OLEDB.4.0;Data source=" &_
Server.MapPath("/") & "/data/db.mdb"
intPageId = request.querystring( "pageid" )
if intPageId = "" then intPageId = 1
with objRs
.cursorlocation = 3 'adUseClient
.open strSQL, strConString 'öppnar databasen och hämtar info.
.pagesize = 50 'bestämmer hur många poster per sida.
.absolutepage = intPageId 'bestämmer vilken sida som skall visas.
end with
intPages = cint( objRs.pagecount ) 'Kollar hur många sidor som finns i recordsettet.
intCurrentPost = 0 'Nollställer räknaren som skall hålla kolla på vilken post vi är på.
do while not objRs.eof and intCurrentPost < objRs.pagesize
strContents = strContents &_
"<tr><td><font face='Verdana' size='1'>" & objRs( "Namn" ) & "</td>" &_
"<td><font face='Verdana' size='1'>" & objRs( "kon" ) & "" & objRs( "Alder" ) & "</td></tr>"
intCurrentPost = intCurrentPost + 1
objRs.MoveNext
loop
function getFirstLink()
getFirstLink = " <a href='?id=com/users&pageid=1'>Första sidan</a> "
end function
function getPreviousLink( intPageId )
if intPageId > 1 then
getPreviousLink = " <a href='?id=com/users&pageid=" & intPageId - 1 & "'><<</a> "
end function
for i = 1 to objRs.pagecount
strNavigation = strNavigation & " <a href='?id=com/users&pageid=" & i & "'>" & i & "</a>"
next
function getNextLink( intPageId, intPageCount )
if cint( intPageId ) < cint( intPageCount ) then
getNextLink = " <a href='?id=com/users&pageid=" & intPageId + 1 & "'>>></a> "
end function
function getLastLink( intPageCount )
getLastLink = " <a href='?id=com/users&pageid=" & intPageCount & "'>Sista sidan</a> "
end function
function getPageInfo( intPageId, intPageCount )
getPageInfo = " Antal sidor: " & intPageCount & ", nuvarande sida: " & intPageId & " "
end function
<b><%=response.write("" & getPageInfo(intPageId, intPages) & "") %></b>
<br>
<table cellpadding="7" width="100%">
<tr>
<td>
response.write "<table>" & strContents & "</table>"
response.write ("<br><table><tr><td><font face='Verdana' size='1'><b>" & getFirstLink() & "</b>  " & getPreviousLink(intPageId) & "")
response.write ("" & strNavigation & "")
response.write ("" & getNextLink(intPageId, intPages) & "  <b>" & getLastLink(intPages) & "</b></td></tr></table>")
</font>
</td>
</tr>
</table>
</td>
</tr>
</table>
Får felmeddelandet:
Feltyp:
ADODB.Recordset (0x800A0CC1)
Objektet kunde inte hittas i mängden med det begärda namnet eller numret.
Raden det står att det är fel på är:
Kontrollerat att du verkligen har rätt namn på alla kolumnnamn?
har hittat felet nu... problemet är att jag skriver ut åldern med
dag = rs("Alder_dag")
manad = rs("Alder_manad")
ar = rs("Alder_ar")
if not isnull(ar) and not isnull(manad) and not isnull(dag) then
response.write DiffADate(DateSerial(ar,manad,dag))
response.write " "
hur får jag in d i scriptet?
EDIT: det ska stå där " & Alder & " står.. det va felet.. alder fanns inte längre :)
250 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
121 ms — deklarationer (db)
121 ms — ändringar (db)
