fel?
1 svar · 172 visningar · startad av jns
jnsMedlem sedan dec. 2001132 inlägg
ADODB.Recordset error '800a0bb9'
Arguments are of the wrong type, are out of acceptable range, or are in conflict with one another.
/kalasmannen/guider.asp, line 81
detta felmeddelnade får jag på denna kod:
sortera = request.querystring("sort")
subject = request.querystring("sub")
set mincon =Server.CreateObject("ADODB.Connection")
set rs = server.createobject("ADODB.Recordset")
mincon.Open "DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" & Server.MapPath("\kalasmannen\db\db_guider.mdb")
if subject = hardware then
if sortera = "" then
SQL = "SELECT * from hardware order by ID desc"
if sortera = "titel" then
SQL = "SELECT * from hardware order by titel asc"
if sortera = "forfattare" then
SQL = "SELECT * from hardware order by av asc"
if sortera = "datum" then
SQL = "SELECT * from hardware order by datum asc"
if subject = software then
SQL = "SELECT * from software order by ID desc"
SQL = "SELECT * from software order by titel asc"
SQL = "SELECT * from software order by av asc"
SQL = "SELECT * from software order by datum asc"
if subject = other then
SQL = "SELECT * from other order by ID desc"
SQL = "SELECT * from other order by titel asc"
SQL = "SELECT * from other order by av asc"
SQL = "SELECT * from other order by datum asc"
rs.Open SQL, mincon
color = 0
men vad är felet?
rad 81 är alltså
rs.Open SQL, mincon
if subject = "hardware" then
och likadant på de andra rader där du jämför subject. Det som händer är att variabeln SQL aldrig tilldelas något värde.
131 ms totalt · 3 externa anrop · v20260731065814-full.fb544a5a
