Sortera!!!
1 svar · 295 visningar · startad av ragnared
Medlem sedan apr. 2003152 inlägg
Hur gör man om man vill att den bara ska hämta en av varje från kategori?
		<%Response.Buffer = "True"%>
db = Server.MapPath("databas/main.mdb")
function blured()
for (a in document.links) document.links[a].onfocus = document.links[a].blur;
if (document.all)
document.onmousedown = blured;
<%Set Conn = Server.CreateObject("ADODB.Connection")
Conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & db
SQL = "Select * From galleri"
If Request.Querystring("kat") = "" then
   Id = 1
Else
   Id= Request.Querystring("kat")
	<br>
<table width="509" border="0" height="86" cellspacing="0" cellpadding="0" >
Const perSida = 30
Sidan = Request.QueryString("sida")
If Sidan = "" then
   sida = 1
Else
   sida = Sidan
With RecSet
  .CursorLocation = 3
  .CacheSize = perSida
End With
SQL = "SELECT DISTINCT kategori,id,bild FROM galleri group by kategori,id,bild"
RecSet.Open SQL, Conn
If RecSet.EOF Then%>
  <tr>
    <td class="normal" height="15" width="506"><br><br><br>
	<p align="center"><font size="6" face="times new roman">Bilderna är på ingång...</font></td>
  </tr>
<%Else%>
  <tr>
    <td height="1" width="509"></td>
  </tr>
<%Numcols = 5
With RecSet
  .MoveFirst
  .PageSize = perSida
  .AbsolutePage = sida
End With
Sidor =  RecSet.PageCount
X = 0
Do While Not RecSet.EOF And X < RecSet.PageSize
    Response.Write "<tr>"
For i=1 to Numcols
    Response.Write "<td width=133 align=left class=normal>"
If RecSet.EOF then
    Response.Write "&nbsp;"
Else%>
    <font size="1" face="Verdana">
    <td height="69" width="509">
    <a href="visa1.asp?id=<%=RecSet("id")%>">
    <span style="text-decoration: none">
    <img src="uppladdning/image/<%=RecSet("Bild")%>" width="78" border="0" height="80" >&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;</span></font><span style="text-decoration: none"></font></span></a>
&nbsp;&nbsp;
<%If RecSet("id") = "" Then%>
<%Else%>
<%End If%>
<%X = X + 1
Recset.MoveNext
     Response.Write "</td>"
Next
     Response.Write "</tr>"
Loop
Recset.Close
Conn.Close
Set Recset = Nothing
Set Conn = Nothing
End If%>
</td>
				</tr>
			</table>
		</td>
		<td height="548" width="117" bgcolor="#FFFFFF" valign="top">
		&nbsp;</td>
		<td height="548" width="163" bgcolor="#FFFFFF" valign="top">
						<br><br><%
DSNtemp="DRIVER={Microsoft Access Driver (*.mdb)}; "
          DSNtemp=dsntemp & "DBQ=" & server.mappath("databas/main.mdb")
          sqlstmt = "SELECT * FROM sommar order by datum desc"
          rs.Open sqlstmt, DSNtemp, 3, 3
TotalRecs = rs.recordcount
x = 0
For x = 1 to 18
	If rs.eof then
		Exit For
	Else
		id = rs("id")
		datum1 = rs("datum")
		namn1 = rs("namn")
		nr1 = rs("nr")
			<table cellSpacing="0" width="163" border="0" id="table2" height="4">
				         <tr>
					<td vAlign="top" width="161">
					<b><a href="visa.asp?kat=<% =nr1 %>">
					<font face="Arial" size="1">
					<% =datum1 %><br><% =namn1 %></a></td>
				</tr>         <tr>
					<td vAlign="top" width="161"></td>
				</tr>
rs.MoveNext
next%>
			</table>
Medlem sedan sep. 2004828 inlägg
Byt från
till
SELECT DISTINCT kategori,max(id),max(bild) FROM galleri group by kategori
438 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
127 ms — deklarationer (db)
307 ms — hämta tråd, inlägg och bilagor (db)
128 ms — ändringar (db)
