Lite hjälp ang cdonts mailing
12 svar · 1 481 visningar · startad av Biasse
Medlem sedan aug. 2003480 inlägg
Jag fick detta av en snubbe och jag fattar ingenting. Det ska enligt honom lösa problemet att sända mail från ett forum fast telia stoppat det. Jag testade men det händer inte mycket. Helt klart är nått galet :q
index.asp
<form action="send_mail.asp" method="post">
Namn : <input type="text" name="namn" size=20>
E-post : <input type="text" name="email" size=20>
Meddelande : <textarea name="mess" cols=25 rows=4></textarea>
<input type="submit" value="Skicka">
send_mail.asp
Dim namn,email,mess
namn = Request.Form("namn")
email = Request.Form("email")
mess = Request.Form("mess")
Const cdoSendUsingMethod        = "http://schemas.microsoft.com/cdo/configuration/sendusing"
			Const cdoSendUsingPort          = 2
			Const cdoSMTPServer             = "http://schemas.microsoft.com/cdo/configuration/smtpserver"
			Const cdoSMTPServerPort         = "http://schemas.microsoft.com/cdo/configuration/smtpserverport"
			Const cdoSMTPConnectionTimeout  = "http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout"
			Const cdoSMTPAuthenticate       = "http://schemas.microsoft.com/cdo/configuration/smtpauthenticate"
			Const cdoBasic                  = 1
			Const cdoSendUserName           = "http://schemas.microsoft.com/cdo/configuration/sendusername"
			Const cdoSendPassword           = "http://schemas.microsoft.com/cdo/configuration/sendpassword"
			Dim objConfig  ' As CDO.Configuration
			Dim objMessage ' As CDO.Message
			Dim Fields     ' As ADODB.Fields
			' Get a handle on the config object and it's fields
			Set objConfig = Server.CreateObject("CDO.Configuration")
			Set Fields = objConfig.Fields
			' Set config fields we care about
			With Fields
				.Item(cdoSendUsingMethod)       = cdoSendUsingPort
				.Item(cdoSMTPServer)            = "smtprelay1.telia.com"
				.Item(cdoSMTPServerPort)        = 25
				.Item(cdoSMTPConnectionTimeout) = 10
				.Item(cdoSMTPAuthenticate)      = cdoBasic
				.Item(cdoSendUserName)          = "name"
				.Item(cdoSendPassword)          = "password"
											End With
			Set Fields = Nothing
			Set objMessage = Nothing
			Set objConfig = Nothing
set CDOMail = Server.CreateObject("CDONTS.NewMail")
	CDOMail.From = "tomten@sverige.se"
	CDOMail.To = "tomten@internet.com"
	CDOMail.Subject = "årets heta lista"
	CDOMail.Body = "Alla Barnen får julklappar utan Sven, för han kan inte hitta hem... :-) "
	CDOMail.Send
Set CDOMail = Nothing
Det är väl inte CDONTS du har ...?? All den koden för det!?
Byt ut tometen -adressen till din egen. Det som i vissa fall kan vara av vikt är att ha samma avsändare dom själva domänen heter.
Som exempel: Din domän är webforum.nu
Vissa webbhotell konfigurerar att din avsändare måste heta i stil med "noreply@webforum.nu"
Are you with!?
Medlem sedan maj 20031 682 inlägg
Vad händer när du använder dig utav den koden?
Får du något felmeddelande?
Har du installerat CDONTS på din webserver?
/red kollade inte på koden så noga. :r
Testa att byt från --- till:
.Item(cdoSMTPServer) = "mail1.telia.com"
Alltså, server för utgående post. Du ska inte behöva lösenord för den servern... (???)
			With Fields
			'	.Item(cdoSMTPServerPort)        = 25
			'	.Item(cdoSMTPConnectionTimeout) = 10
			'	.Item(cdoSMTPAuthenticate)      = cdoBasic
			'	.Item(cdoSendUserName)          = "name"
			'	.Item(cdoSendPassword)          = "password"
			End With
Testa att avmarkera de fem sista raderna. Default port borde vara 25. Bara om du vill ha annan portnummer kan man skriva det...
Sitter på jobbet nu men ska testa imorgon. Vad jag förstod ska man skriva in sitt namn/pass i telia mailen så skulle den gå över den. Han menar på att han använde all den koden .. skriptet gick igenom men inget mail kom.
En bit till på väg..
Har ju fattat att detta inte är cdonts och fått det att sända mail. Nästa steg är att koppla detta till min mdb.
Tabellen heter "members" & kollumen "mail". Funktionen jag söker är att skicka massmail till alla adresser i "mail". Har provat lite men klarar inte att loopa ur dom samt att tala om för scriptet att hitta dom. Bara själva kopplingen ligger med nu.
<form method="POST">
<p>Skriv ditt meddelande:<br>
<textarea rows="2" name="TextField" cols="20"></textarea></p>
<p>Skriv din e-post adress<br>
<input type="text" name="TextEmail" size="20"></p>
<p><input type="submit" value="Skicka" name="ButtonSend"><input type="reset" value="Töm fält" name="ButtonReset"></p>
Conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\inetpub\wwwroot\test\mail.mdb"
SQL = "Select mail from members"
If Request.Form("ButtonSend")<>"" Then SendMail
Sub SendMail
EmailServer="smtprelay1.telia.com"
EmailSubject="Info"
EmailSender="info@info.com"
EmailAddress=Request.Form("TextEmail")
EmailText=Request.Form("TextField")
Set objMessage = CreateObject("CDO.Message")
objMessage.Subject = EmailSubject
objMessage.Sender = EmailSender
objMessage.To = EmailAddress
objMessage.TextBody = EmailText
objMessage.Configuration.Fields.Item _
("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
'Name or IP of Remote SMTP Server
("http://schemas.microsoft.com/cdo/configuration/smtpserver") = EmailServer
'Server port (typically 25)
("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
'smtpconnectiontimeout (typically 10)
("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 10
'cdoSMTPAuthenticate
("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic
'cdoSendUserName
("http://schemas.microsoft.com/cdo/configuration/sendusername") = "xxxxxxxx"
'cdoSendPassword
("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "xxxxxxxx"
objMessage.Configuration.Fields.Update
objMessage.Send
Response.Redirect "mail.asp"
End Sub
Koppla ditt Recordset med din SQL och loopar ut ditt Recordset.
Recset = conn.Execute(sql)
Do Until Recset.Eof
' Mail kod här
Recset.Movenext
Loop
Hur lägger du in det? Jag får :
Feltyp:
Körningsfel i Microsoft VBScript (0x800A01B6)
Objektet stöder inte egenskapen eller metoden.: 'Eof'
/mail.asp, line 16
Sen måste man koppla kollumen mail till scriptet i detta och hur skriver man in det?
Set Recset = conn.Execute(sql)
Do Until Recset.Eof
' Mail kod här
Recset.Movenext
Loop
EmailAddress=Recset("mail")
istället
Feltyp:
Kompileringsfel i Microsoft VBScript (0x800A03EA)
Syntaxfel
/mail.asp, line 19
Sub SendMail
Conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\inetpub\wwwroot\diggers\lagret\digelo.mdb"
Do Until Recset.Eof
Sub SendMail
EmailServer="smtprelay1.telia.com" ' Vilken mailserver ska webbsidan använda för att skicka mail
EmailSubject="Info" ' Vad ska stå i subject på mailet
EmailSender="info@info.com" ' Vilken adress ska stå om avsändare
EmailAddress=Recset("mail") ' Vilken e-post adress ska mailet skicka till
EmailText=Request.Form("TextField") ' Vilken text ska stå i mailet
'cdoSendUserName
'cdoSendPassword
objMessage.Send
End Sub
Recset.Movenext
Loop
Du kan inte ha en Sub (definitionen) i en loop. Jag tar en titt på detta när jag kommer hem.
	Do Until Recset.Eof
		SendMail RecSet("mail") , Request.Form("TextField")
		RecSet.MoveNext
	Loop
	Set RecSet = Nothing
	Conn.Close
	Set Conn = Nothing
Sub SendMail(mail, message)
	Dim EmailServer, EmailSubject, EmailSender, EmailAddress, EmailText
	EmailSubject = "Info" ' Vad ska stå i subject på mailet
	EmailSender = "info@info.com" ' Vilken adress ska stå om avsändare
	EmailAddress = mail ' Vilken e-post adress ska mailet skicka till
	EmailText = message ' Vilken text ska stå i mailet
	objMessage.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
	objMessage.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserver") = EmailServer
	objMessage.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
	objMessage.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 10
	objMessage.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic
	'cdoSendUserName
	objMessage.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusername") = "xxxxxxxx"
	'cdoSendPassword
	objMessage.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "xxxxxxxx"
	objMessage.Send
End Sub
Gött.. Nu funkar det perfekt.. Trodde "sub" skulle vara med. Tackar
255 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
119 ms — deklarationer (db)
123 ms — ändringar (db)
