Path not found
4 svar · 352 visningar · startad av SoulGod
SoulGodMedlem sedan aug. 20051 200 inlägg
Jag har nu stött på nästa problem i min kod...
Microsoft VBScript runtime  error '800a004c'
Path not found
/blogg/Includes/inc-configuration.asp, line 85
Och koden jag kör (varning för lång kod)
Raden under " 'load language file " är rad 85 som den klagar på.
'dimension variables
dim intBlogEnabled, intBlogTimeOffset, intBlogAccountRegistration, intBlogAccountAuthorisation, intBlogLinkEnabled, intBlogLinkLimit, intBlogFeedEnabled, intBlogFeedLimit
dim strBlogEmailComponent, strBlogEmailHost, strBlogEmailAddress, strBlogEmailSignature, intBlogEmailNotification, intBlogEmailVerification, intBlogArticleLimit
dim intBlogGalleryEnabled, intBlogGalleryHeight, intBlogGalleryWidth, intBlogCommentEnabled, intBlogCommentModeration, intBlogCommentRegistration, intBlogCommentLimit, intBlogSearchLimit, intBlogEventsEnabled, intBlogPrivate
dim intBlogArchiveEnabled, intBlogArchiveDuration, intBlogGravatarEnabled, intBlogGravatarDimensions, strBlogGravatarRating, intBlogFeedCharacters, intBlogArticlePaging
dim strBlogTitle, strBlogDescription, strBlogTheme, strBlogLocation, strBlogTimeFormat, strBlogMetaKeywords, strBlogMetaDescription, strBlogSidebar
'load blog configuration
sub load_config()
	application.lock
	dim rsConfiguration, sqlConfiguration
	'grab configuration values
	set rsConfiguration = server.createobject("adodb.recordset")
	sqlConfiguration = "SELECT Blog_Enabled, Blog_Name, Blog_Description, Blog_Theme, Blog_Location, Blog_Time_Format, Blog_Time_Offset, Blog_Account_Registration, Blog_Account_Authorisation, Blog_Link_Enabled, Blog_Link_Limit, Blog_Feed_Enabled, Blog_Feed_Limit, Blog_Email_Component, Blog_Email_Host, Blog_Email_Address, Blog_Email_Signature, Blog_Email_Notification, Blog_Email_Verification, Blog_Article_Limit, Blog_Search_Limit, Blog_Events_Enabled, Blog_Gallery_Enabled, Blog_Gallery_Height, Blog_Gallery_Width, Blog_Comment_Enabled, Blog_Comment_Moderation, Blog_Comment_Registration, Blog_Comment_Limit, Blog_Meta_Keywords, Blog_Meta_Description, Blog_Private, Blog_Sidebar, Blog_Archive_Enabled, Blog_Archive_Duration, Blog_Feed_Characters, Blog_Gravatar_Enabled, Blog_Gravatar_Dimensions, Blog_Gravatar_Rating, Blog_Feed_Characters, Blog_Article_Paging FROM FB_Configuration;"
	rsConfiguration.cursorlocation = 3
	rsConfiguration.open sqlConfiguration, adoConn
	if not (rsConfiguration.bof or rsConfiguration.eof) then
		application("Blog_Enabled") = rsConfiguration("Blog_Enabled")
		application("Blog_Name") = SQL_decode(rsConfiguration("Blog_Name"))
		application("Blog_Description") = SQL_decode(rsConfiguration("Blog_Description"))
		application("Blog_Theme") = SQL_decode(rsConfiguration("Blog_Theme"))
		application("Blog_Location") = rsConfiguration("Blog_Location")
		application("Blog_Time_Format") = rsConfiguration("Blog_Time_Format")
		application("Blog_Time_Offset") = rsConfiguration("Blog_Time_Offset")
		application("Blog_Account_Registration") = rsConfiguration("Blog_Account_Registration")
		application("Blog_Account_Authorisation") = rsConfiguration("Blog_Account_Authorisation")
		application("Blog_Link_Enabled") = rsConfiguration("Blog_Link_Enabled")
		application("Blog_Link_Limit") = rsConfiguration("Blog_Link_Limit")
		application("Blog_Feed_Enabled") = rsConfiguration("Blog_Feed_Enabled")
		application("Blog_Feed_Limit") = rsConfiguration("Blog_Feed_Limit")'
		application("Blog_Email_Component") = rsConfiguration("Blog_Email_Component")
		application("Blog_Email_Host") = SQL_decode(rsConfiguration("Blog_Email_Host"))
		application("Blog_Email_Address") = SQL_decode(rsConfiguration("Blog_Email_Address"))
		application("Blog_Email_Signature") = SQL_decode(rsConfiguration("Blog_Email_Signature"))
		application("Blog_Email_Notification") = rsConfiguration("Blog_Email_Notification")
		application("Blog_Email_Verification") = rsConfiguration("Blog_Email_Verification")
		application("Blog_Article_Limit") = rsConfiguration("Blog_Article_Limit")
		application("Blog_Search_Limit") = rsConfiguration("Blog_Search_Limit")
		application("Blog_Events_Enabled") = rsConfiguration("Blog_Events_Enabled")
		application("Blog_Gallery_Enabled") = rsConfiguration("Blog_Gallery_Enabled")
		application("Blog_Gallery_Height") = rsConfiguration("Blog_Gallery_Height")
		application("Blog_Gallery_Width") = rsConfiguration("Blog_Gallery_Width")
		application("Blog_Comment_Enabled") = rsConfiguration("Blog_Comment_Enabled")
		application("Blog_Comment_Moderation") = rsConfiguration("Blog_Comment_Moderation")
		application("Blog_Comment_Registration") = rsConfiguration("Blog_Comment_Registration")
		application("Blog_Comment_Limit") = rsConfiguration("Blog_Comment_Limit")
		application("Blog_Meta_Keywords") = SQL_decode(rsConfiguration("Blog_Meta_Keywords"))
		application("Blog_Meta_Description") = SQL_decode(rsConfiguration("Blog_Meta_Description"))
		application("Blog_Private") = rsConfiguration("Blog_Private")
		application("Blog_Sidebar") = SQL_decode(rsConfiguration("Blog_Sidebar"))
		application("Blog_Archive_Enabled") = rsConfiguration("Blog_Archive_Enabled")
		application("Blog_Archive_Duration") = rsConfiguration("Blog_Archive_Duration")
		application("Blog_Gravatar_Enabled") = rsConfiguration("Blog_Gravatar_Enabled")
		application("Blog_Gravatar_Dimensions") = rsConfiguration("Blog_Gravatar_Dimensions")
		application("Blog_Gravatar_Rating") = rsConfiguration("Blog_Gravatar_Rating")
		application("Blog_Feed_Characters") = rsConfiguration("Blog_Feed_Characters")
		application("Blog_Article_Paging") = rsConfiguration("Blog_Article_Paging")
	rsConfiguration.close
	set rsConfiguration = nothing
	'increment query count
	intQuery = intQuery + 1
	application("cfgLoaded") = true
	application.unlock
end sub
'load ids data
sub load_ids_strings()
	dim strTempValue, objFSO, objTextStream, arrStrings, i, strStrings
	application.lock
	'load language file
	set objFSO = server.createobject("Scripting.FileSystemObject")
	set objTextStream = objFSO.opentextfile(server.mappath("\") & Blog_Folder(application("Blog_Location"), true) &"Includes\strings-" & strLanguage & ".txt",1)
	strStrings = objTextStream.readall
	objTextStream.close
	set objFSO = nothing
	'create string array
	if strStrings <> "" then arrStrings = split(strStrings,vbCrLf)
	'loop through all translations
	for i = 0 to ubound(arrStrings)
		if arrStrings(i) <> "" and left(arrStrings(i),1) <> ";" then
			strTempValue = mid(arrStrings(i),instr(arrStrings(i),",")+1)
			'replace global variables as needed
			strTempValue = replace(strTempValue,"$BLOGTITLE$",strBlogTitle)
			strTempValue = replace(strTempValue,"$BLOGLOCATION$",strBlogLocation)
			strTempValue = replace(strTempValue,"$SEARCHLIMIT$",intBlogSearchLimit)
			'set application parameter
			application("ids_"& left(arrStrings(i),instr(arrStrings(i),",")-1)) = strTempValue
	next
	application("idsLoaded") = true
	application.unlock
end sub
'check whether configration file is loaded
if not application("cfgLoaded") then
	call load_config()
'set global variables
intBlogEnabled = application("Blog_Enabled")
strBlogTitle = application("Blog_Name")
strBlogDescription = application("Blog_Description")
strBlogTheme = application("Blog_Theme")
strBlogLocation = application("Blog_Location")
strBlogTimeFormat = application("Blog_Time_Format")
intBlogTimeOffset = application("Blog_Time_Offset")
intBlogAccountRegistration = application("Blog_Account_Registration")
intBlogAccountAuthorisation = application("Blog_Account_Authorisation")
intBlogLinkEnabled = application("Blog_Link_Enabled")
intBlogLinkLimit = application("Blog_Link_Limit")
intBlogFeedEnabled = application("Blog_Feed_Enabled")
intBlogFeedLimit = application("Blog_Feed_Limit")'
strBlogEmailComponent = application("Blog_Email_Component")
strBlogEmailHost = application("Blog_Email_Host")
strBlogEmailAddress = application("Blog_Email_Address")
strBlogEmailSignature = application("Blog_Email_Signature")
intBlogEmailNotification = application("Blog_Email_Notification")
intBlogEmailVerification = application("Blog_Email_Verification")
intBlogArticleLimit = application("Blog_Article_Limit")
intBlogSearchLimit = application("Blog_Search_Limit")
intBlogEventsEnabled = application("Blog_Events_Enabled")
intBlogGalleryEnabled = application("Blog_Gallery_Enabled")
intBlogGalleryHeight = application("Blog_Gallery_Height")
intBlogGalleryWidth = application("Blog_Gallery_Width")
intBlogCommentEnabled = application("Blog_Comment_Enabled")
intBlogCommentModeration = application("Blog_Comment_Moderation")
intBlogCommentRegistration = application("Blog_Comment_Registration")
intBlogCommentLimit = application("Blog_Comment_Limit")
strBlogMetaKeywords = application("Blog_Meta_Keywords")
strBlogMetaDescription = application("Blog_Meta_Description")
intBlogPrivate = application("Blog_Private")
strBlogSidebar = application("Blog_Sidebar")
intBlogArchiveEnabled = application("Blog_Archive_Enabled")
intBlogArchiveDuration = application("Blog_Archive_Duration")
intBlogGravatarEnabled = application("Blog_Gravatar_Enabled")
intBlogGravatarDimensions = application("Blog_Gravatar_Dimensions")
strBlogGravatarRating = application("Blog_Gravatar_Rating")
intBlogFeedCharacters = application("Blog_Feed_Characters")
intBlogArticlePaging = application("Blog_Article_Paging")
'check whether ids strings are loaded
if not application("idsLoaded") then
	call load_ids_strings()
Sökvägen finns inte. Kontrollera att filen ligger där den ska.
Skriv ut sökvägen du försöker hämta den på, och jämför.
TravoniMedlem sedan okt. 20041 556 inlägg
OT: En milijon applicationvariabler är inte att föredra prestandamässigt.
@anders >
Jag skrev ut sökvägen helt (exakt filnamn o.s.v.)
Och jag har försökt både med exakt sökväg från "default.asp" filen,
och likaså från "inc-filen", men jag får fortfarande path not found.
Om jag ändrar ngt i sökvägslänken så står det plötsligt "file not found",
men när man uppdaterar igen så står det "path not found" igen.
Travoni > Ej jag som gjort just den delen av kodningen, så jag låter det vara tills jag lärt mig det ;)
har du bytt ut "server.mappath("\")" mot exemeplvis: "c:\bob\filer\" ?
142 ms totalt · 3 externa anrop · v20260731065814-full.30151723
