Enkelt problem..?
6 svar · 615 visningar · startad av Jeppeweb
JeppewebMedlem sedan sep. 2006462 inlägg
Slutade att fungera efter att jag lade till den här raden, varför?
if arrArticlesData(9, intArticlesLoop) = Filmer then
				'display article details
				response.write("<p>"& ids("Kategori") &": <a href='"& strBlogLocation &"games.asp?Category="& arrArticlesData(8, intArticlesLoop) &"' title='Kategori: "& safe_text(SQL_decode(arrArticlesData(9, intArticlesLoop))) &"'>"& SQL_decode(arrArticlesData(9, intArticlesLoop)) &"</a>")
					response.write(" - "& ids("") &" "& web_time(arrArticlesData(4, intArticlesLoop), strBlogTimeFormat, "Full") &" - ")
						'check comments are enabled
					if arrArticlesData(5, intArticlesLoop) = 1 and intBlogCommentEnabled = 1 then
						response.write(" <a href='"& strBlogLocation &"games.asp?Display="& arrArticlesData(0, intArticlesLoop) &"#Comments' title='"& ids("Antal kommentarer") &": "& safe_text(arrArticlesData(6, intArticlesLoop)) &"'>"& arrArticlesData(6, intArticlesLoop) &" "& ids("kommentarer") &"</a> - <a href='#' title='Lägg till det här spelet i dina favoriter.'>Favorit</a> - <a href='#' title='Vad tycker du om artikeln? Rösta!'>Rösta</a></p>")
Microsoft VBScript compilation error '800a040e'
'loop' without 'do'
/index2.asp, line 526
loop
Tacksam för hjälp!
Som felmeddelandet säger saknas ett "do" någonstans.
Jo, okej. Var?
                response.write("<p>")
				'check whether the article has an exceprt
				if arrArticlesData(2, intArticlesLoop) <> "" then
					'display article exceprt
					response.write(SQL_decode(arrArticlesData(2, intArticlesLoop)))
					'display full atricle link
					response.write("<p class='link'>")
						response.write("<a href='"& strBlogLocation &"games.asp?Display="& arrArticlesData(0, intArticlesLoop) &"' title='"& replace(ids("Fortsätt."),"#TITLE#",safe_text(SQL_decode(arrArticlesData(1, intArticlesLoop)))) &"'>"& replace(ids("Spela"),"#TITLE#",SQL_decode(arrArticlesData(1, intArticlesLoop))) &"</a>")
					response.write("</p>")
					'display full article
					response.write(SQL_decode(arrArticlesData(3, intArticlesLoop)))
                response.write("<p>&nbsp;</p>")
					'check for images and whether the gallery is enabled
					if (isnull(arrArticlesData(7, intArticlesLoop)) = false and arrArticlesData(7, intArticlesLoop) <> "") and intBlogGalleryEnabled = 1 then
						'display thumbnail gallery
						call display_thumbs(SQL_decode(arrArticlesData(7, intArticlesLoop)))
			response.write("</div>")
			'increment counter
			intArticlesLoop = intArticlesLoop + 1
		loop
Tacksam för hjälp..
Min gissning är att det saknas ett end if som tillhör koden du pejstade in.
Indentera koden ordentligt så är det lätt att fånga upp den typen av fel.
Innan den första if-satsen, möjligtvis. Har du "do" någonstans? Om inte, varför finns "loop" med?
Grejjade det problemet.. Nu till ett annat, jag vill bara visa information från en kategori, jag har ett id på varje kategori, 0,1,2,3 osv...
if arrArticlesData(8, intArticlesLoop) = 0 then
Varför fungerar inte det där? Den visar all information ifrån alla kategorier...
Vad innehåller arrArticlesData? Uppfylls aldrig villkoret? I sådana fall finns inte värdet noll på de indexena?
