Gruppera i en tabell
ASPur ASP
2 svar · 297 visningar · startad av devotion
Jag har följande kod som består av två funktioner.
Hur gör jag för att kunna gruppera i tabellen? Säg att jag vill gruppera på kunder. Då vill jag få en tabellrad med kundens namn, under denna ska tillhörande poster listas.
Jag har testat lite med följande princip, men får det inte riktigt att fungera.
sLastGroup="###"
while not Rs.EOF
    if Rs("MittFält")<>sLastGroup then
        response.write"<tr><td colspan='xxx'>Wee!</td></tr>)
    sLastGroup=Rs("MittFält")
    Response.write "<tr><td>...</td><td>...</td></tr>"
wend
Mina funktioner:
function InsertContractTemplates()
		dim s, i
		dim Conn, Rs, sSQL
		dim a
		dim sTaskList, lastContract, sLastGroup
		Set Conn = CreateObject( "ADODB.Connection" )
		Conn.Open Application.sDbConnectionString
		Set Rs = CreateObject( "ADODB.Recordset" )
		sSQL = "SELECT "
		for i=0 to g_nCols-1
			sSQL = sSQL & g_sColField(i) & " AS FIELD_" & i & ", "
		next
		sSQL = sSQL & "[tblContract].[CustomerNr] AS CustomerNr, [tblContractTemplate].[Id] AS TemplateId, [tblContractTemplate].[StartDate], [tblContractTemplate].[StopDate]," _
			& " [tblContractTemplate].[RepeatUnit], [tblContractTemplate].[RepeatAmount], [tblContractTemplate].[RepeatAt], [tblContractTemplate].[DurationUnit]," _
			& " [tblContractTemplate].[DurationAmount], [tblContractTemplate].[StartAtMinute], [tblContractTemplate].[FixedStartDate], [tblContractTemplate].[GeneratedStopDate]," _
			& " [tblTask].[Status] AS TaskStatus, tblTask.[Id] AS TaskId, tblTask.[PlanstartDate], [tblUsers].[Sign] AS UserSign, [tblUsers].[Name] AS UserName" _
			& " FROM [tblContract]" _
			& " LEFT JOIN [tblContractTemplate]" _
			& " ON [tblContract].[Id] = [tblContractTemplate].[ContractId]" _
			& " LEFT JOIN [tblUsers]" _
			& " ON [tblContractTemplate].[User]= [tblUsers].[Name]" _
			& " LEFT JOIN tblContractTask" _
			& " ON tblContractTemplate.[Id] = tblContractTask.TemplateId" _
			& " LEFT JOIN tblTask" _
			& " ON tblContractTask.TaskId = tblTask.[Id]" _
			& " WHERE [tblContractTemplate].[ContractId] IN (" & sContractId & ")"
		if par_user<>"" then sSQL = sSQL & " AND [tblContractTemplate].[User]='" & par_user & "' "
		'Kunna visa typ av avtal
		if par_type<>"" then sSQL = sSQL & " AND [tblContractTemplate].[CustomT1]='" & par_type & "' "
		'Kunna visa endast visa
		if par_status<>"" then sSQL = sSQL & " AND [tblTask].[Status]=" & par_status & " "
		sSQL = sSQL & " ORDER BY [tblContract].[CustomerNr]"
		'sSQL = sSQL & " ORDER BY [tblContract].[CustomerNr] AND " & g_sColField(0)
		Rs.Open sSQL, Conn, 1
		lastContract=""
		sTaskList=""
		'sLastGroup="###"
		while not Rs.EOF
		'if Rs("CustomerNr")<>sLastGroup then
			'Response.write "<tr><td colspan='xxx'>" & sLastGroup & "</td></tr>"
		'end if
		'response.write Rs("CustomerNr")
			if Rs("TemplateId") <> lastContract then
				if sTaskList<> "" then
					Rs.moveprevious
					a = split(right(sTaskList, len(sTaskList)-1), ",")
					s = s & InsertRow(Rs, a)
					Rs.movenext
					sTaskList=""
			sTaskList=sTaskList & "," & Rs("TaskId") & "|||" & Rs("TaskStatus") & "|||" & Rs("PlanStartDate") & "|||" & Rs("UserSign")
			'sLastGroup=Rs("CustomerNr")
			lastContract=Rs("TemplateId")
			Rs.MoveNext
		wend
			rs.moveprevious
			sTaskList=""
		Rs.Close
		Conn.Close
		set Rs=Nothing
		Set Conn=Nothing
		InsertContractTemplates=s
	end function
Och
function InsertRow(Rs, a)
		dim s
		dim tmDate(255)
		dim nDates
		dim m, i, j, l
		dim sOutput
		dim aTemp
		dim monthInfo(11)
		dim lTaskId, nTaskStatus, dStartDate
		dim re, tempRe
		set re=new regexp
		re.pattern="^\|{9}$"
		for i=0 to ubound(a)
			if not re.test(a(i)) then
				tempRe=re.pattern
				re.pattern="\d{4}-\d{2}-\d{2}"
				set match=re.execute(a(i))
				if match.count>0 then
					m=datepart("m", CDate(match(0)))
					monthInfo(cint(m)-1)=a(i)
				 re.pattern=tempRe
		next
		set re=nothing
		response.write Rs("CustomerNr") & "<br>"
		s = "<tr valign='top'>"
			s = s & "<td nowrap>" & Rs("FIELD_" & i) & "</td>"
		next
		nDates=GenerateDates(Rs, tmDate)
		for i=0 to g_nDateCols-1
			s = s & "<td width='35' nowrap align='center'"
			if i mod 2=0 then s = s & " bgcolor='" & g_sAltDateColor & "'"
			s = s & ">"
			if isEmpty(monthInfo(i)) then
				'Ingen ikon för denna månad
				lTaskId=-1
				nTaskStatus=-1
				dStartDate=-1
				sUserSign=-1
				'gör en split på monthInfo(i) och "|||", och skicka in dem till GetTaskStatusImg
				aTemp = split (monthinfo(i), "|||")
				lTaskId=aTemp(0)
				nTaskStatus=aTemp(1)
				dStartDate=aTemp(2)
				sUserSign=aTemp(3)
			sOutput=""
			for j=0 to nDates-1
				if DatePart("M", tmDate(j))=DatePart("M", g_tmStartDate(i)) then
					sOutput = GetCellValue(sOutput, Rs("TemplateId"), tmDate(j))
			next
			if sOutput="" then
				sOutput=GetTaskStatusImg(lTaskId, nTaskStatus, g_tmStartDate(i), dStartDate, sUserSign)
			s = s & sOutput
			s = s & "&nbsp;</td>"
		next
		s = s & "</tr>"
		InsertRow=s
	end function
Mycket tacksam för hjälp!
Henrik
I while-loopen i InsertContractTemplates körs response.write som skall skriva ut kundnamnet. I variablen "s" ackumuleras samtidigt övrigt resultat. Alla response.write:s körs ju innan allt innehåll i "s", varför samtliga kundnamn skrivs ut först och därefter allt annat.
Testa med att ackumulera även
...i "s".
Såklart.... :)
Henrik
138 ms totalt · 3 externa anrop · v20260731065814-full.c74b5be1
