uppdatera frames
1 svar · 360 visningar · startad av WebbisNet
WebbisNetMedlem sedan feb. 20032 027 inlägg
hur får jag mina andra frames att uppdateras när färgerna är sparade på sidan
<!-- #include virtual="/include/dbconn.asp" -->
<!-- #include virtual="/include/functions.asp" -->
<!-- #include virtual="/include/variabler.asp" -->
<html>
parent.bottomframe.location.href='bottom1.asp';
parent.rightframe.location.href='right1.asp';
parent.topframe.location.href='top1.asp';
parent.leftframe.location.href='left1.asp';
<body>
Dim objConn, SQL
if request.querystring("do") = "bg" then
varColor = Request.Form("bg")
	SET objConn = connect()
	SQL = "update tblUsers set krypincolor='"& varColor &"' WHERE userID=" & Session("userID") & ""
	'response.write SQL
	'response.end
	objConn.Execute(SQL)
response.redirect "krypincolor.asp?do=change"
elseif request.querystring("do") = "link" then
varColor = Request.Form("link")
	SQL = "update tblUsers set linkcolor='"& varColor &"' WHERE userID=" & Session("userID") & ""
	'response.write SQL
	'response.end
elseif request.querystring("do") = "text" then
varColor = Request.Form("text")
	SQL = "update tblUsers set textcolor='"& varColor &"' WHERE userID=" & Session("userID") & ""
	'response.write SQL
	'response.end
</html>
Du tar bort din response.redirect så du ger browsern en chans att ta hand om ditt javascript?
