Ingen fel meddelande
13 svar · 615 visningar · startad av SGuncel
Medlem sedan jan. 2007217 inlägg
Får inte fel meddelandet när jag skriver in fel anv och lösen.
Jag kommer till gamla login sidan när jag testar skriva fel anv och lösen.
<!-- #include file="../Inc/DBConnection.asp" -->
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<link rel="stylesheet" href="login.css" type="text/css" />
<script type="text/javascript" language="javascript">
var showForgotPassword = 0;
function showForgotPass() {
if (!showForgotPassword) {
document.getElementById('ForgotPassword').style.display='inline';
showForgotPassword= 1;
} else {
document.getElementById('ForgotPassword').style.display='none';
showForgotPassword= 0;
var showCreateAcc = 0;
function showCreateAccount() {
if (!showCreateAccount) {
document.getElementById('CreateAccount').style.display='inline';
showCreateAccount = 1;
} else {
document.getElementById('CreateAccount').style.display='none';
showCreateAccount = 0;
<script language="javascript" type="text/javascript">
function popUpMessage(strText, strRedirect)
    alert(strText);
    if (strRedirect != '')
        self.location = strRedirect;
<title>Namnlös 1</title>
<body>
<div style="position: absolute; left: 262px; top: 170px; z-index: 10000">
<div class="Login_Info_Background"><span class="Login_Info_Rubrik">Välkommen till ...</span>
<br />
<div style="position: absolute; left: 41px; top: 84px; z-index: 10000"><span class="Login_Info_Liten_Text">Turkiets egen community, i Sverige.</span></div>
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<div style="position: absolute; left: 267px; top: 639px; z-index: 10000" class="Login_Info_Text">
Info | KontaktInformation | Annonsera Hos Oss</div>
<div style="position: absolute; left: 686px; top: 292px; z-index: 10000; height:20px">
<form action="?user=logIn" method="post">
<span class="Login_Info_LoggaIn">
	Logga In</span>
<br />
<input type="text" name="UsrTLAlias" value="Användarnamn" onFocus="if(this.value=='Användarnamn'){this.value='';}" onBlur="if(this.value==''){this.value='Användarnamn';}" />
&nbsp;&nbsp;&nbsp;&nbsp;
<input type="password" name="UsrPassword" value="Lösenord" onFocus="if(this.value=='Lösenord'){this.value='';}" onBlur="if(this.value==''){this.value='Lösenord';}" />
<div style="position: absolute; left: 969px; top: 319px; z-index: 10000; height:20px" class="Login_Info_Medlem_Lose">
<input type="submit" value="Logga in" name="Logga in" class="Input_submit" />
<div style="position: absolute; left: 686px; top: 341px; z-index: 10000; height:20px" class="Login_Info_Medlem_Lose">
Bli medlem!
<div style="position: absolute; left: 832px; top: 341px; z-index: 10000; height:20px" class="Login_Info_Medlem_Lose">
<a href="javascript:showForgotPass();">Glömt lösenord!</a>
<div id="ForgotPassword" style="display: none; position: absolute; left: 686px; top: 377px; z-index: 10000; height:20px">
	Glömt Lösenord</span>
	<br />
	<span class="Login_Info_Medlem_Lose">Skriv in ditt användarnamn så skickas ditt lösenord till din mail.</span>
	<br />
<input type="text" name="UsrTLAlias" value="Användarnamn" onFocus="if(this.value=='Användarnamn'){this.value='';}" onBlur="if(this.value==''){this.value='Användarnamn';}" />&nbsp;
<div style="position: absolute; left: 149px; top: 46px; z-index: 10000">
	<input type="submit" value="Skicka" name="Skicka" class="Input_submit" /></div>
If Request.Querystring("user") = "logIn" then
	Set ObjRS = ObjConn.Execute("SELECT * FROM TLUsers where UsrTLAlias='"& SafeSQL(Request.Form("UsrTLAlias")) &"' AND UsrPassword='"& SafeSQL(Request.Form("UsrPassword")) &"'")
		If ObjRS.Eof then
popUpMessage('Fel inloggningsuppgifter.', 'default.asp');
Else
Session.TimeOut = 15
Session("UsrTLAlias") = ObjRS("UsrTLAlias")
Session("UsrID") = ObjRS("UsrID")
Session("UsrLogin") = "UsrOnline"
ObjConn.Execute("Update TLUsers set UsrLastLogin='" & now() & "', UsrLoginIP='"&SafeSQL(Request.ServerVariables("REMOTE_ADDR"))&"', UsrStats='Online', UsrTotalLogin=UsrTotalLogin+1 where UsrID="&SafeSQL(Session("UsrID"))&"")
ObjConn.Close : Set ObjConn = nothing
Response.Redirect "../Main/RegisterFinish_Check.asp"
</html>
Om du försöker undvika att posta en miljon irrelevanta kodrader så är det betydligt enklare för oss att hjälpa till.
Hur vet vi vilken den "gamla loginsidan" är? Hur vet vi vilken den nya är?
Beskriv felet lite närmare, och posta endast relevant kod.
Den gamla ligger i en mapp som heter Login och nya i en mapp som heter New Login.
När jag skriver fel användarnamn och lösenord så kommer jag till gamla login sidan "Login/Default.asp" istället för att komma till "New Login/Default.asp"
Denna kod ska ge fel meddelandet och skicka till nya login sidan. Men den skickar till gamla login sidan.
Med den koden kommer man att redirectas till "../Main/RegisterFinish_Check.asp" oavsett hur inloggningen går. Javascriptet kommer aldrig att köras, eftersom en Response.Redirect gör att inget skrivs ut på sidan.
Om man har nyligen blivit reggad och loggar in så kommer man till "../Main/RegisterFinish_Check.asp" Där kollar den om man har fyllt i extra uppgifter om man har gjort det skickas man till sidan men om man inte gjort det skickas man till sidan där det finns extra uppgifter.
Så här ser mina nuvarande login kod ut som jag använder på min gamla login sida.
Set ObjRS = ObjConn.Execute("Select * From TLUsers where UsrTLAlias='"&SafeSQL(Request.Form("UsrTLAlias"))&"'" & " and UsrPassword='"&SafeSQL(Request.Form("UsrPassword"))&"'")
IF ObjRS.Eof then
Session("loginerror")="Du har skrivit in fel lösenord eller användarnamn. <br> Försök igen!"
Else
Session("UsrAdmin") = ObjRS("UsrAdmin")
Man blir skickad dit så fort man försöker logga in, oavsett om man lyckas eller inte.
Nej, det är inte så. Om amn skriver fel användarnamn och lösenord så skickas man till login sidan men om amn skriver in korrekt användarnamn och lösenord så skickas man till "../Main/RegisterFinish_Check.asp".
Jo, det är visst så! Sedan är det väl någon sessionkontroll eller något på RegisterFinish_Check.asp som gör att du skickas tillbaka till gamla login-sidan...
Japp.
		If NOT Session("UsrLogin")="UsrOnline" Then
	ObjConn.Close : Set ObjConn = Nothing
			Session("meddelande") = ""
			Response.Redirect "../Login/Default.asp"
Men hur kan jag lösa detta problemet?
Du får väl låta bli att skicka användaren till RegisterFinish_Check.asp om inloggningen misslyckas, eller låta Sessions-kollen på RegisterFinish_Check.asp skicka tillbaka till den nya Login-sidan....
Vilket skulle du rekommendera?
Både och. Det finns ingen anledning att skicka vidare till RegisterFinish_Check.asp om inloggningen misslyckas, och Sessions-kollen ska väl alltid skicka tillbaka till den rätta inloggningssidan?
		If ObjRS.Eof then
// Här kommer fel meddelandet, om man har skrivit fel så skickas man vidare till login sidan.
Else
// Här skickas man till sidan om inloggningen lyckas.
Response.Redirect "../Main/frameset.asp"
Medlem sedan mars 20041 505 inlägg
En irrelevant fråga kanske, men man använder väl inte // för kommentarer i VbScript? Du borde få felmeddelanden va?
271 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
121 ms — deklarationer (db)
147 ms — hämta tråd, inlägg och bilagor (db)
119 ms — ändringar (db)
