Hämta 2 åt gången?
3 svar · 366 visningar · startad av Biasse
Medlem sedan aug. 2003480 inlägg
Hur gör man för att det bara ska visas 2st poster/sida och sen välja sida under?
Connect.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("../../lagret/digelo.mdb")
IF Request.Querystring("action") = "delete" Then
SQL = "DELETE * FROM members WHERE ID=" & Request.Querystring("id")
Connect.Execute(SQL)
Response.Redirect "msn.asp"
ELSE
SQL = "SELECT * From members ORDER BY namn ASC"
Set RecSet = Connect.Execute(SQL)
<div align="center">
  <table width="350" border="0" style="border: #1e2535 1px solid" bgcolor="#efefef">
    <% Do Until RecSet.EOF %>
      <tr><td width="15%">
		<font color="#1E2535" face="Verdana" style="font-size: 9pt">Namn:</font></td>
		<td width="82%"><font color="#cc0000" face="Verdana" size="2"> <%=RecSet("namn")%></font></td></tr>
		<font color="#1E2535" face="Verdana" style="font-size: 9pt">E-Mail:</font></td>
		<td width="82%"><font color="#cc0000" face="Verdana" size="2"> <%=RecSet("mail")%></font></td></tr>
		<font color="#1E2535" face="Verdana" style="font-size: 9pt">MSN:</font></td>
		<td width="82%"><font color="#cc0000" face="Verdana" size="2"> <%=RecSet("msnmail")%></font></td></tr>
		<font color="#1E2535" face="Verdana" style="font-size: 9pt">Telefon:</font></td>
		<td width="82%"><font color="#cc0000" face="Verdana" size="2"> <%=RecSet("telefon")%></font></td></tr>
		<font color="#1E2535" face="Verdana" style="font-size: 9pt">Mobil:</font></td>
		<td width="82%"><font color="#cc0000" face="Verdana" size="2"> <%=RecSet("mobil")%></font></td></tr>
		<font color="#1E2535" face="Verdana" style="font-size: 9pt">Bil:</font></td>
		<td width="82%"><font color="#cc0000" face="Verdana" size="2"> <%=RecSet("bil")%></font></td></tr>
	  <tr><td width="15%"></td>
		<td width="82%"><p align="left"><a href="msn.asp?action=delete&id=<%=RecSet("id")%>">
	  <font face="Verdana" size="2">
	  <span style="background-color: #EAF8FF; text-decoration:none">Radera</span></font></a><hr color="#1E2535" size="1"></td></tr>
RecSet.MoveNext
Loop
Recset.Close
Connect.Close
Set Recset = Nothing
Set Connect = Nothing
END IF
  </table>
Löste det..
<title>Members</title>
<body bgcolor="#FFFFFF">
<p align="center"><font face="Verdana" color="#CC0000" style="font-size: 13pt">Medlemar</font></p>
SQL = "SELECT * From members ORDER BY namn DESC"
RecSet.Open SQL, Connect, 1, 3
RecSet.PageSize = 2
X=0
If Request.QueryString("page") = "" OR NOT IsNumeric(Request.QueryString("page")) Then
intPage = 1
Else
intPage = CInt(Request.QueryString("page"))
RecSet.AbsolutePage = intPage
DO UNTIL RecSet.EOF OR X = RecSet.PageSize
X=X+1
RecSet.MOVENEXT
LOOP
If RecSet.PageCount > 1 Then
For i = 1 To RecSet.PageCount
If i <> intPage Then
Response.Write("<a href=""?page=" & i & """>" & i & "</a> ")
Else
Response.Write("[" & i & "] ")
Next
RecSet.CLOSE
Connect.CLOSE
Set RecSet = nothing
Set Connect = nothing
</table>
Måste krångla vidare på detta ändå.... Hittar inget om det jag undrar nu som funkar.
I det övre härså fårjag allt att ligga i klickmeny från 1 och stigande.
Men helst vill jag ha det så att det ligger en meny från a tillö såman kan välja på namn i bokstavs ordning. Hur ska det se ut då?
Medlem sedan okt. 2004392 inlägg
Menar du att du vill ha länkarna längst ner A B C D E F G H.. istället för 1 2 3 4 5 6...
I så fall kan du kasta ditt paging system och bara välja namn som börjar på bokstaven a (tex) i SQL queryn. Ta en titt på denna: http://www.webforum.nu/showthread.php?t=12406
EDIT:
Ville ge extra uppmärksamhet till det LarsG skrev:
sql = "select distinct left(username,1) from members order by 1"
Jag har aldrig testat något sånt, men om det funkar så är det ju perfekt.
EDIT (igen):
Markera tråden som olöst igen, jag kan se folk ignorera denna tråd då den är redan löst, då kan du förlora hjälp som kanske skulle hjälpa dig lösa ditt nya problem.
121 ms — deklarationer (db)
125 ms — ändringar (db)
