Ingen som kan ta en titt på scriptet?
<%@LANGUAGE="VBSCRIPT" CODEPAGE="CP_ACP"%>
Response.CacheControl = "no-cache"
Response.AddHeader "Pragma", "no-cache"
Response.Expires = -1
Function CheckCAPTCHA(valCAPTCHA)
SessionCAPTCHA = Trim(Session("CAPTCHA"))
Session("CAPTCHA") = vbNullString
if Len(SessionCAPTCHA) < 1 then
CheckCAPTCHA = False
exit function
if CStr(SessionCAPTCHA) = CStr(valCAPTCHA) then
CheckCAPTCHA = True
End Function
%><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<body>
<form action="kontakt.asp" method="post" name="maila" onSubmit="return tecken()">
<p class="form"><input name="namn" type="text" class="formstyle" tabindex="1" size="35" /><label for="namn"><small>Namn</small></label></p>
<p class="form"><input name="email" type="text" class="formstyle" tabindex="2" size="35" /><label for="email"><small>E-mail</small></label></p>
<p><textarea name="meddelande" cols="60" rows="8" class="formstyle" tabindex="3"></textarea></p>
<img src="aspcaptcha.asp" alt="This Is CAPTCHA Image" width="86" height="21" />
if Request.ServerVariables("REQUEST_METHOD") = "POST" then
strCAPTCHA = Trim(Request.Form("strCAPTCHA"))
if CheckCAPTCHA(strCAPTCHA) = true then
<strong>Meddelandet har skickats! (<%=strCAPTCHA%>)</strong>
<strong>Fel kod, försök igen</strong>
<p><input name="strCAPTCHA" type="text" id="strCAPTCHA" class="formstyle" tabindex="4" size="15" /><label for="strCAPTCHA"><small>Skriv siffrorna i bilden ovan.</small></label>
<form method="post" name="frm" /></p>
<p><input type="submit" class="send" onClick="postComment();" value="Skicka medelande" /></p>
<!-- SEND -->
Namn = Request.Form("Namn")
Email = Request.Form("Email")
Meddelande = Replace(Request.Form("Meddelande"), vbCrLf, "<BR>" & vbCrLf)
Set jmail = Server.CreateObject("JMail.Message")
jmail.AddRecipient "nille@nilleonline.com"
jmail.From = "" & Email & ""
jmail.Subject = "Kontakta mig!"
jmail.Body = "Meddelande via hemsidan skickades " & Now & ""
jmail.appendHTML "<b>Meddelande via hemsidan</b><br>"
jmail.appendHTML "<b>Skickades:</b> " & Now & "<br>"
jmail.appendHTML "<b>Namn: </b> " & Namn & "<br>"
jmail.appendHTML "<b>E-mail: </b> " & Email & "<br>"
jmail.appendHTML "" & Meddelande & "<br>"
jmail.Send ("smtp.cliche.se")
</html>
Vad är det som gör att scriptet inte funkar? Någon som har lust att förklara hur jag får det att fungera? Misstänker att jag måste koppla send scriptet till action i formuläret, men hur gör jag det?
