God afton!
Besökaren ska kunna välja att svara på en annons eller tipsa en kompis om annonsen. (se kod nedan)
<%if request.form("inTipsa") = "Tipsa" then%>
<span class="textB">
<form method="post" action="posta.asp" name="reply">
<input type="hidden" name="chrPosta" value="x">
<table>
<tr><td colspan="2">Tipsa en kompis om annonsen.</td></tr>
<tr><td>Din kompis epostadress: </td><td><input type="text" name="strEmail"></td></tr>
<tr><td>Ditt namn : </td><td><input type="text" name="strSenderName"></td></tr></table>
<input type="hidden" name="strReply" value="<%=request.form("strAd")%>"><br/>
<input type="submit" value="Sänd">
</span>
<%else%>
Din epostadress: <input type="text" name="strSenderMail"></br><br/>
<input type="hidden" name="chrPosta" value="y">
<input type="hidden" name="strEmail" value="<%=request.form("strEmail")%>">
<textarea cols="73" rows="9" name="strReply"></textarea><br/><br/>
</span>
<%end if%>
Väljer besökaren att kontakta annonsören fungerar det och annonsören får e-brevet. Men väljer man att tipsa en kompis så kommer ingen e-post.
recipient = Request.Form("strEmail")
senderEmail = request.form("strSenderMail")
if request.form("chrPosta") = "y" then
subject = "Svar på din oddjobb.se-annons"
body = Request.Form("strReply")
elseif request.form("chrPosta") = "x" then
name = Request.Form("strSenderName")
body = "Nu då"
subject = "Intressant för dig?"
' Create the JMail message Object
set jmail = Server.CreateOBject( "JMail.smtpmail" )
jmail.ServerAddress = "smtp.m6.webbhotellsgruppen.se"
jmail.silent = TRUE
'jmail.ContentType = "text/html"
jmail.ContentType = "text/plain"
' Set Sender Information
jmail.Sender = SenderEmail
jmail.ReplyTo = SenderEmail
'jmail.sendername = SenderEmail
' Recipient Address and Name
jmail.AddRecipientEx recipient, ""
' Set the Subject and Body
jmail.subject = Subject
jmail.Body = body
' Send Email - Perform Error Checking
jmail.Execute%>
<!-- #include file="inc/searchfield.asp"-->
<%If jmail.errormessage <> "" Then
Response.write "<pre>" & jmail.errormessage & "</pre>"
Response.write "Meddelandet är skickat."
set jmail = nothing%>
Skriver man ut variablerna så ser dessa helt ok.
Något förslag?
