samma felmeddelande
1 svar · 581 visningar · startad av ridder
Medlem sedan dec. 200611 inlägg
hmm.. När jag nu skall kolla "äldre" frågor på omröstningne får jag:
Microsoft VBScript runtime error '800a000d'
Type mismatch
/nyclub3/old_poll.asp, line 56
(Har markerat rad 56.)
<%Dim strVotedPoll
Set Check = Conn.Execute("SELECT votedPoll From com_users Where active=1 and userid=" & FixaTecken(Session("user_id")))
  strVotedPoll = Check(0)
Check.Close:Set Check=Nothing
If Request.Querystring("action") = "" Then%>
<table cellpadding="2" cellspacing="0" border="0" width="100%" align="center">
<%Set Fraga=Conn.Execute("SELECT pollid,fraga From com_fraga Order by PollId desc limit 1")
If Fraga.EOF Then%>
  <tr>
    <td colspan="2"><%=strPoll_NoPost%></td>
  </tr>
<%Else%>
  <tr>
    <td colspan="2"><b><%=Fraga(1)%></b></td>
  </tr>
  <%totalt = Conn.Execute("SELECT sum(klick) From com_svar Where pollID=" & FixaTecken(Fraga(0))).Fields(0)
  SQL1 = "SELECT pollID,klick,svar,id From com_svar Where pollID="& FixaTecken(Fraga(0)) & " Order By svarnr"
  arrRecSet = GetDbRows(SQL1)
  If Not IsArray(arrRecSet) Then%>
    <tr>
      <td colspan="2"><b><%=strPoll_NoSvar%></b></td>
    </tr>
  <%Else
    For i = 0 To ubound(arrRecSet,2)
      stat     = arrRecSet(1,i)
      If stat <> 0 Then
        res      = (Clng(stat)/Clng(totalt))* 100
      Else
        res = "0"
      If Int(strVotedPoll) = Int(Fraga(0)) Then%>
        <tr>
          <td width="82%"><%=arrRecSet(2,i)%> (<%=stat%>)</td>
          <td rowspan="2" width="18%" valign="bottom" align="right"><%=Round(res,0)%>%</td>
        </tr>
        <tr>
          <td bgcolor="<%=sidBG%>" height="5"><img src="gfx/stapel.gif" width="<%=Round(res,0)%>%" height="5" border="1"></td>
        </tr>
      <%Else%>
        <tr>
          <td width="82%"><a href="default.asp?action=vote&svarID=<%=arrRecSet(3,i)%>&pollId=<%=Fraga(0)%>" class="vit"><%=arrRecSet(2,i)%></a> (<%=stat%>)</td>
        </tr>
        <tr>
        </tr>
      <%End If
    Next%>
    <tr>
      <td><br><%=strPoll_Rost%>: <%For i=1 to Len(totalt)%><%=Mid(totalt,i,1)%><%Next%></td>
      <td align="right"><br><a href="old_poll.asp"><%=strPoll_Aldre%></a></td>
    </tr>
  <%End If
[red]End If%>[/red]
</table>
<%ElseIf Request.Querystring("action") = "vote" Then
  If Int(strVotedPoll) = Int(Request.Querystring("pollId")) Then
    'Conn.Close:Set Conn=Nothing
    Response.Write "<script language=Javascript>"
    Response.Write "self.location.href='default.asp';"
    Response.Write "</script>"
  Else
    Response.Redirect "default.asp?action=saveVote&svarID=" & Request.QueryString("svarID") & "&pollId=" & Request.Querystring("pollId")
ELseIf Request.Querystring("action") = "saveVote" Then
  Conn.Execute("Update com_svar Set klick=klick+1 Where id=" & FixaTecken(Request.QueryString("svarID")))
  Conn.Execute("Update com_users Set votedPoll=" & FixaTecken(Request.Querystring("pollId")) & " Where userid=" & FixaTecken(Session("user_id")))
End If%>
Bifogade fel fil. Har nu löst det ändå.
125 ms — deklarationer (db)
118 ms — ändringar (db)
