JeppewebMedlem sedan sep. 2006462 inlägg hur förhindrar jag att det automatiskt blir ett mellanslag i skrivrutan "PostNr" ?
<%@ Language=VBScript %><%
Option Explicit
Public Function JSEscape(Value)
Dim Char
Dim Index
Dim Length
Dim Offset
Dim Buffer
Length = Len(Value)
Buffer = Value & Space(Length)
For Index = 1 To Len(Value)
Char = Mid(Value, Index, 1)
Select Case Asc(Char)
Case &H27 'single quote '
Mid(Buffer, Index + Offset, 2) = "\'"
Offset = Offset + 1
Case &H22 'double quote "
Mid(Buffer, Index + Offset, 2) = "\"""
Offset = Offset + 1
Case &H8 'backspace <BS>
Mid(Buffer, Index + Offset, 2) = "\b"
Offset = Offset + 1
Case &H5C 'backslash Mid(Buffer, Index + Offset, 2) = "\\"
Offset = Offset + 1
Case &H9 'horizontal tab <HT>
Mid(Buffer, Index + Offset, 2) = "\t"
Offset = Offset + 1
Case &HA 'line feed (new line) <LF>
Mid(Buffer, Index + Offset, 2) = "\n"
Offset = Offset + 1
Case &HB 'vertical tab <VT>
Mid(Buffer, Index + Offset, 2) = "\v"
Offset = Offset + 1
Case &HC 'form feed <FF>
Mid(Buffer, Index + Offset, 2) = "\f"
Offset = Offset + 1
Case &HD 'carriage return <CR>
Mid(Buffer, Index + Offset, 2) = "\r"
Offset = Offset + 1
Case Else
If Offset Then
Mid(Buffer, Index + Offset, 2) = Char
End Select
Next
JSEscape = Left(Buffer, Length + Offset)
End Function
Dim rs
Dim con
Dim fldOrt
Dim fldPostNr
Dim LastOrt
Const adCmdTable = 2
'* ASP/VBScript: Förbereder svaret
Response.Buffer = True
Response.Expires = 1440 '1 Dag
Response.ContentType ="text/javascript"
Response.AddHeader "Content-Transfer-Encoding", "text"
Response.AddHeader "Content-Disposition", "filename=PostNummer.js"
'* JavaScript: Array som håller orter för postnummer
Response.Write "var postnr = loadPostnr();" & vbCrLF
'* JavaScript: Funktion formaterar postnummer
Response.Write "/**" & vbCrLf
Response.Write " * Function: formatPostNr(postNr)" & vbCrLf
Response.Write " * Parameter: postNr - Postnummer som skall formateras" & vbCrLf
Response.Write " * Return value: Formaterat postnummer" & vbCrLf
Response.Write " **/" & vbCrLf
Response.Write "function formatPostNr(postNr)" & vbCrLf
Response.Write "{" & vbCrLf
Response.Write " var strText = postNr.replace(/\D/gi, '');" & vbCrLf
Response.Write " var strPostNr = strText.substring(0, 3) + ' ' + strText.substring(3, 5);" & vbCrLf
Response.Write " return strPostNr;" & vbCrLf
Response.Write "}" & vbCrLf
'* JavaScript: Funktion som hämtar Ortnamn för angivet postnummer
Response.Write " * Function: getOrtnamn(postNr, noMatch)" & vbCrLf
Response.Write " * Parameter: postNr - Postnummer som kontrolleras" & vbCrLf
Response.Write " * Parameter: noMatch - Svar som ges om postNr ej finns" & vbCrLf
Response.Write " * Return value: Funnet Ortnamn eller noMatch" & vbCrLf
Response.Write "function getOrtnamn(postNr, noMatch)" & vbcrlf
Response.Write "{" & vbcrlf
Response.Write " var re = /\d{5}/" & vbcrlf
Response.Write " var strText = postNr.replace(/\D/gi, '');" & vbcrlf
Response.Write " if (re.test(strText))" & vbcrlf
Response.Write " {" & vbcrlf
Response.Write " var intPostNr = parseInt(strText);" & vbcrlf
Response.Write " var x = postnr[intPostNr];" & vbcrlf
Response.Write " if (x==undefined)" & vbcrlf
Response.Write " window.status='Fann ingen ort för postnummer: \""' + strPostNr + '\"" ';" & vbcrlf
Response.Write " }" & vbcrlf
Response.Write " else" & vbcrlf
Response.Write " window.status='';" & vbcrlf
Response.Write " return x;" & vbcrlf
Response.Write " window.status='\""' + postNr + '\"" är inget nummer';" & vbcrlf
Response.Write " return noMatch;" & vbcrlf
Response.Write "}" & vbcrlf
'* JavaScript: Funktion som laddar postnummer och Ortnamn
Response.Write "function loadPostnr()" & vbcrlf
Response.Write "var o;" & vbCrLF
Response.Write "var p = new Array();" & vbCrLF
'* ASP/VBScript: Öppnar databasen
Set con = Server.CreateObject("ADODB.Connection")
con.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("db/PostNr.mdb")
'* ASP/VBScript: skapar javascript koden för postnr
rs.Open "qrySelectOrtNummer", con, , , adCmdTable
Set fldOrt = rs("Ort")
Set fldPostNr = rs("PostNr")
Do Until rs.EOf
If LastOrt = fldOrt.Value Then
Else
Response.Write vbCrLF & "o='" & JSEscape(LastOrt) & "';" & vbCrLF
Response.Write "p[" & fldPostNr.Value & "]=o;"
rs.MoveNext
Loop
Set fldOrt = Nothing
Set fldPostNr = Nothing
rs.Close
'* ASP/VBScript: Frigör objekt
Set rs.ActiveConnection = Nothing
Set rs = Nothing
con.Close
Set con = Nothing
Response.Write "return p;" & vbcrlf
@ndersMedlem sedan juni 200032 969 inlägg Ta bort mellanslaget som läggs till i javascriptfunktionen formatPostNr:
Du kan ta bort den raden, och returnera strText från funktionen istället.
och du, tänk på att skriva vettiga trådrubriker.
JeppewebMedlem sedan sep. 2006462 inlägg okej, tack.. hur gör jag för att skriva ut på sidan när ngt är fel som t.ex ett invalidt postnummer ? just nu skrivs de ut i statusbar.. men jag vill få de utskrivet på sidan
tack på förhand
@ndersMedlem sedan juni 200032 969 inlägg Det framgår inte av den kod du visar, men antagligen har du någonstans en javascript-kodrad typ window.status = 'felaktigt postnummer';. Byt det till document.getElementById('errordiv').innerHTML='felaktigt postnummer'; och lägg till:
<div id="errordiv"></div>
, där du vill ha felmeddelandet.
JeppewebMedlem sedan sep. 2006462 inlägg '**
jag fick det inte att fungera.. ersatte med din kod..
@ndersMedlem sedan juni 200032 969 inlägg ... och hur ser det ut när du ersatt efter mitt förslag?
JeppewebMedlem sedan sep. 2006462 inlägg ingenting, det står "fel script" där nere, statusbar..
@ndersMedlem sedan juni 200032 969 inlägg Jag menade hur din kod ser ut när du fixat efter mina förslag.
JeppewebMedlem sedan sep. 2006462 inlägg <%@ Language=VBScript %><%
Option Explicit
Dim Char
Dim Index
Dim Length
Dim Offset
Dim Buffer
Length = Len(Value)
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Case Else
If Offset Then
End Select
Next
End Function
Dim rs
Dim con
Dim fldOrt
Dim fldPostNr
Dim LastOrt
Response.Write " document.getElementById('errordiv').innerHTML='felaktigt postnummer';
Response.Write " document.getElementById('errordiv').innerHTML='felaktigt postnummer'; Response.Write " }" & vbcrlf
Do Until rs.EOf
Else
rs.MoveNext
Loop
rs.Close
Set rs = Nothing
con.Close
Set con = Nothing
@ndersMedlem sedan juni 200032 969 inlägg Du måste avsluta dina response.write med ". (Där du lagt in document.getElementById-grejerna)
Dessutom kan du lägga in en vbcrlf efter som det är på de andra raderna.
(Jag förstår dock inte alls varför allt javascript skrivs ut med asp, det gör koden grymt svårläst).
JeppewebMedlem sedan sep. 2006462 inlägg Response.Write "/**" & vbCrLf
Response.Write " document.getElementById('errordiv').innerHTML='felaktigt postnummer'; & vbcrlf"
Response.Write " document.getElementById('errordiv').innerHTML='felaktigt postnummer';"
doesnt work
@ndersMedlem sedan juni 200032 969 inlägg Titta på de andra raderna så ser du att citationstecknet ska vara efter javascript-raden, före & vbcrlf.
JeppewebMedlem sedan sep. 2006462 inlägg fungerar fortfarande inte.. :/
Option Explicit
Dim Char
Dim Index
Dim Length
Dim Offset
Dim Buffer
Length = Len(Value)
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Offset = Offset + 1
Case Else
If Offset Then
End Select
Next
End Function
Dim rs
Dim con
Dim fldOrt
Dim fldPostNr
Dim LastOrt
Response.Write " document.getElementById('errordiv').innerHTML='felaktigt postnummer';" & vbcrlf
Do Until rs.EOf
Else
rs.MoveNext
Loop
rs.Close
Set rs = Nothing
con.Close
Set con = Nothing
@ndersMedlem sedan juni 200032 969 inlägg ... och på vilket sätt funkar det inte?
Javascriptfel? ASP-fel?
JeppewebMedlem sedan sep. 2006462 inlägg Javascriptfel.. det går inte att se förutom att det är en gul ikon och "fel script" i statusbar?
@ndersMedlem sedan juni 200032 969 inlägg Ok. Kör sidan i någon vettig webbläsare, typ Firefox, och använd javascriptdebuggern (Tools -> Javascript console), så går det att reda ut vad som är fel.
I IE kan man dubbelklicka på den gula ikonen och få lite (pyttelite) mer info, åtminstone ett felmeddelande.
JeppewebMedlem sedan sep. 2006462 inlägg Okej, i IE står det..
Syntaxfel rad 30 tecken 73..
ska testa FF också
JeppewebMedlem sedan sep. 2006462 inlägg rad 30 f.ö
Case &HA 'line feed (new line) \<LF\>
Mid(Buffer, Index + Offset, 2) = "\\n"
Offset = Offset + 1
@ndersMedlem sedan juni 200032 969 inlägg Du kan inte titta på rad 30 i asp-filen, utan du måste titta i den kod som genererats och skickats till webbläsaren.
