Meny-skript
2 svar · 426 visningar · startad av Niceone
NiceoneMedlem sedan nov. 200126 inlägg
Någon som vet hur man gör detta i ASP eller har nått exempel på liknande Asp meny med id, parentid lösning mot MySql?
Tacksam för hjälp eftersom jag kört fast lite, lite klurigt detta... :OO
$show_sub_levels_id = $_GET["show_sub_levels_id"];
$database = "test";
$path = "";
$www_user = "user";
$www_password = "";
mysql_connect("$path","$www_user","$www_password") or die("Temporary error, please try again later. (unable to connect to database)");
mysql_select_db("$database") or die ("Temporary error, please try again later. (unable to select database)");
function getTree($parentId="0", $show_sub_levels_id="", $level="0"){
$query = "SELECT * FROM sektioner WHERE parentId='$parentId' ORDER BY text";
$result = mysql_query($query) or die(mysql_error());
$rows = mysql_NumRows($result);
for($index=0; $index<$rows; $index++){
$id = mysql_result($result,$index,"id");
$text = mysql_result($result,$index,"text");
$url = mysql_result($result,$index,"url");
for($a = 0; $a<$level; $a++){
echo "-";
if($url != ""){
echo "<a href=\"$url\">;$text</a><br&nb
sp;/>\n";
}else{
echo "<a href=\"$php_SELF?show_sub_levels_id=$id\">;$text</a><br&nbs
p;/>\n";
if($id == $show_sub_levels_id){
if(hasChild("$id")){
getTree("$id", "$show_sub_levels_id", $level+1);
function hasChild($id){
$query = "SELECT * FROM sektioner WHERE parentId='$id'";
if($rows != 0){
return TRUE;
}else{
return FALSE;
getTree("0", "$show_sub_levels_id", "0");
och databasen:
CREATE TABLE `sektioner` (
  `id` int(11) NOT NULL auto_increment,
  `parentId` int(11) default NULL,
  `text` varchar(255) default NULL,
  `url` varchar(255) default NULL,
  PRIMARY key (`id`),
  key `parentId` (`parentId`)
) TYPE=MyISAM;
INSERT INTO `sektioner` (`id`,`parentId`,`text`,`url`) VALUES ("1","0","l?nk 1","");
INSERT INTO `sektioner` (`id`,`parentId`,`text`,`url`) VALUES ("2","0","l?nk 2","");
INSERT INTO `sektioner` (`id`,`parentId`,`text`,`url`) VALUES ("3","1","subl?nk 1:1","http://1,1");
INSERT INTO `sektioner` (`id`,`parentId`,`text`,`url`) VALUES ("4","1","subl?nk 1:2","http://1,2");
INSERT INTO `sektioner` (`id`,`parentId`,`text`,`url`) VALUES ("5","2","subl?nk 2","http://2");
TravoniMedlem sedan okt. 20041 556 inlägg
Sök på rekursiv här i asp-forumet så skall du hitta det du söker. :)
Tackar, hittade vad jag sökte!
128 ms totalt · 3 externa anrop · v20260731065814-full.cf67ef55
