ladda upp fil
6 svar · 702 visningar · startad av nille99
Medlem sedan aug. 2002352 inlägg
jag har ett asp kod som klarar av att ladda upp fil på min server
men ibland så har filnamnet så konstiga namn, så jag vill ha en text ruta där jag kan skriva in ett nytt namn
hur gör jag?
<form method="post" action="outputfile.asp" enctype="multipart/form-data">
\<input type="file" name="blob"\>\<br\>
\<input type="text" name=namn\>\<br\>
\<input type="submit" value="Ladda upp, yo!"\>
outputfile.asp
Server.ScriptTimeout = 500
Response.Expires=0
Response.Buffer = TRUE
Response.Clear
'Response.BinaryWrite(Request.BinaryRead(Request.TotalBytes))
byteCount = Request.TotalBytes
RequestBin = Request.BinaryRead(byteCount)
Dim UploadRequest
Set UploadRequest = CreateObject("Scripting.Dictionary")
BuildUploadRequest RequestBin
name = UploadRequest.Item("namn").Item("TextName")
contentType = UploadRequest.Item("blob").Item("ContentType")
filepathname = UploadRequest.Item("blob").Item("FileName")
filename = Right(filepathname,Len(filepathname)-InstrRev(filepathname,"\"))
value = UploadRequest.Item("blob").Item("Value")
filtyp = lcase(right(contentType,3))
Set ScriptObject = Server.CreateObject("Scripting.FileSystemObject")
set fso = server.createobject("scripting.filesystemobject")
set folder = fso.getFolder(server.mappath("./filer"))
pathEnd = Len(Server.mappath(Request.ServerVariables("PATH_INFO")))-14
' Set MyFile = ScriptObject.CreateTextFile(Left(Server.mappath(Request.ServerVariables("PATH_INFO")),pathEnd)&filename)
'Set MyFile = ScriptObject.CreateTextFile(Server.mappath(filename))
for each file in folder.files
if file.name = filename then
filename = "kopia" & filename
elseif file.name = "kopia" &filename then
filename = "kopia1" & filename
next
Set MyFile = ScriptObject.CreateTextFile(Server.mappath("filer/" & filename))
For i = 1 to LenB(value)
MyFile.Write chr(AscB(MidB(value,i,1)))
Next
MyFile.Close
response.write "<b>Filens sökväg:</b> " & Server.mappath(filename) & "<br>"
response.write "<b>Filnamn:</b> " & filename & "<br><br>"
response.write "<b>typ:</b> " & filtyp & "<br><br>"
response.write "<b>value:</b> " & name & "<br><br>"
fick det fungera
name = UploadRequest.Item("namn").Item("Value")
nynamn = name & "." & filtyp
Va bra!
  1. [kod]-taggar när du postar kod
  2. Acceptera som slutgiltigt svar
kort fråga
hur skriver jag över en fil på serven?
jag löste problemet
jag tog bort filen före jag la ut den igen
Medlem sedan jan. 20011 154 inlägg
Annars har du parametrar i fso för overwrite
http://www.devguru.com/technologies/vbscript/14051.asp
255 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
126 ms — deklarationer (db)
124 ms — ändringar (db)
