Hur fixar jag detta?
1 svar · 313 visningar · startad av Ivar
Medlem sedan aug. 2002218 inlägg
Jag har denna kod som funkar bra, men jag vill att bilderna och texten vissas horisontellt, men hur?
' ### arraydim 3 st
arrValda = Array(0,0,0,0)
' ### koppling
Set objCon = Server.CreateObject("ADODB.Connection")
objCon.Open "Provider=Microsoft.Jet.OLEDB.4.0; Data Source=" & Server.MapPath("db/annonser.mdb") & ";"
Set objRs = Server.CreateObject("ADODB.Recordset")
	' ### tabellinfo samt villkor
	strSQL = "SELECT * FROM mak"
	objRs.Open strSQL, objCon, 3, 3
	intPoster = objRs.RecordCount
	' Start 2-0 = 3 poster
	For x = 0 To 2
				Do
				strOk = true
				Randomize
				intSlump = int(rnd()*intPoster)
				For Each value In arrValda
				If value = intSlump Then strOk = false
				Next
	If strOk Then arrValda(x) = intSlump
	Loop Until cBool(strOk)
				objRs.Move intSlump
				If Not objRs.EOF Then
				Response.Write "<table width='100%' bordercolor='#99FF66' align='center' cellpadding='0' cellspacing='1' border='1'> "
							Response.Write "<tr>"
							if "" & objRs("fileName") = "" Then
Response.Write "<td><center>" &objRs("item")&""
				<td><center><img src="bilder/<%=objRs("filename")%>"  height="80" border="0">
				<%end if%>
				Response.Write "</tr></td></table></center>"
				End if
				objRs.MoveFirst
				Next
objRs.Close
Set objRs = Nothing
objCon.Close
Set objCon = Nothing
Fixat,
' ### arraydim 3 st
' ### koppling
	For x = 0 To 2
				Do
				strOk = true
				Randomize
				Next
				objRs.Move intSlump
				<%end if%>
				End if
				objRs.MoveFirst
				Next
objRs.Close
Set objRs = Nothing
objCon.Close
129 ms — deklarationer (db)
129 ms — ändringar (db)
