Använda två databaser
8 svar · 576 visningar · startad av devotion
Jag har följande kod:
Dim sSQL, objConn, objRS1, objRS2,  iStatus, sNote, sCategory, sName, sArtNr, sUnit, iPrice, iNextId
'Ange status; 0 = "synkroniserad med SPCS", 1 = "Inte synkroniserad mot SPCS"
iStatus = 0
'Notering
sNote = ""
' Öppna databasen
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.ConnectionString = Application("sConn")
objConn.Open
sSQL = 		"SELECT tblArticle.articlenumber, tblArticle.articleName, tblPrice.articlePrice, tblPrice.articleCategoryNumber, tblArticle.articleUnit, " &_
			"tblCategory.CategoryName, tblCategory.categoryNumber, tblDiscount.articleDiscount, tblSupplier.SupplierName, tblSupplier.SupplierId, " &_
			"CASE WHEN articleDiscount is null THEN articlePrice ELSE articlePrice*(1-([articleDiscount]*0.01)) END AS articlePriceWithDiscount " &_
			"FROM tblArticle " &_
			"INNER JOIN tblPrice ON tblArticle.articlenumber = tblPrice.articleNumber " &_
			"INNER JOIN tblSupplier ON tblPrice.articleSupplierId = tblSupplier.SupplierId " &_
			"LEFT OUTER JOIN tblDiscount ON tblPrice.articleCategoryNumber = tblDiscount.categoryNumber AND tblPrice.articleSupplierId = tblDiscount.supplierId " &_
			"LEFT OUTER JOIN tblCategory ON tblPrice.articleSupplierId = tblCategory.supplierId AND tblPrice.articleCategoryNumber = tblCategory.categoryNumber " &_
			"ORDER BY tblArticle.articlenumber"
Set objRS1 = Server.CreateObject("ADODB.Recordset")
objRS1.Open sSQL, objConn, 3, 1
If not objRS1.EOF then
	do until objRS1.EOF
		sArticleNumber = objRS1("articleNumber")
		sArticleName = objRS1("articleName")
		sUnit = lCase(objRS1("articleUnit"))
		iPrice = replace(cDbl(objRS1("articlePrice")), ",", ".")
		'Ta ut de två första tecknena i E-numret
		sList = left(sArtNr, 2)
		'Hämta kategorinamn mha sList
		Set objRS2 = objConn.Execute ("SELECT listName FROM tblList WHERE listNr = '" & sList & "'")
		If not objRS2.EOF then
			sCategory = objRS2("listName")
		objRS2.Close
		Set objRS2 = Nothing
		[b]'--------------------------------------------------------------------
		'Här ska det hämtas info från en annan databas...
		Set objRS2 = objConn.Execute ("SELECT nextId FROM tblNextId WHERE table = 'tblArticle'")
			iNextId = cLng(objRS2("NextId"))
		objRS2.Close
		sSQL = 	"INSERT INTO tblarticle ([Id], [Group], [Status], [Modified], ArtNr, [Name], [Category], [Unit], [Price], Custom1, Custom2, [Note]) " &_
				"VALUES(" & iNextId & ", " & iGroup & ", " & iStatus & ", Now(), '" & sArtNr & "', '" & sName & "', " &_
				"'" & sCategory & "', '" & sUnit & "', " & iPrice & ", '" & sCustom1 & "', '" & sCustom2 & "', '" & sNote & "')"
		objConn.execute sSQL,,128
		sSQL = "UPDATE tblNextId SET nextId = nextId + 1 WHERE Table = 'tblArticle'"
		objConn.Execute sSQL,, 128[/b]
		objRS1.Movenext
	Loop
Else
	Response.write "Fel!"
End if
objRS1.Close
Set objRS1 = Nothing
Response.write "Datat har lagrats!"
Koden hämtar data från en tabell i databas 1 och ska hämta och skriva data till tabeller databas 2.
Det som är i fetstil är ifrån databas 2.
Hur gör jag detta?
Jag har följande connectionstring i Global.asa
Sub Application_OnStart
	Application("sConn") = "Provider=SQLOLEDB.1;Password=xxxxxxx;Persist Security Info=True;User ID=sa;Initial Catalog=IntranetSydostel;Data Source=.\sqlexpress"
End Sub
Jag använder MS SQL-server
Kanske frågan är i fel forum... flytta i så fall... :)
Henrik
Medlem sedan mars 2005232 inlägg
Jag kan inte asp eller så och har inte kolla igenom koden speciellt noga. Men är det inte smidigare att ha två tabeller i en databas, istället för två databaser med en tabell i varje?
Om du har två databaser så har du väl två connectionstring:ar?
Alternativt, om användaren för koppling 1 även har rätt till databas 2, så kan du komma åt den direkt, genom att ange tabellnamnen med databasnamn.ägarnamn.tabellnamn, där ägarnamnet oftast är tomt (dbo), ex. "SELECT * FROM AndraDatabasen..Tabellen".
OBS! Att köra med sa-användaren rekommenderas inte!! Major säkerhetshål.
Så här menar du?
' Öppna databasen
objConn.Open
Set objConn2 = Server.CreateObject("ADODB.Connection")
objConn2.ConnectionString = Application("sConn2")
objConn2.Open
Skulle du kunna utvecla det lite... är inte riktigt med.. :r
Ska åtgärda det... Är bara test och utveckling just nu... i den skarpa versionen ska jag inte ha sa-kontot...
Henrik
Jag provar väl, även om det inte är så himla lätt att beskriva på något annat sätt...
Om användaren som användes för inloggning i din första connection har rättigheter i databas två kan du prata med den databasen genom att prefixa tabellnamnen med databasnamn...
Jag provade att göra så här:
(utskrift av SQL)
INSERT INTO UppdragNu.dbo.tblArticle ([Id], [Status], [Modified], [Nr], [Name], [Category], [Unit], [Price], [Note]) VALUES(10002, 0, '2006-07-31 18:00:00', '0000040', 'EKKJ 1x10/10', '', 'm', 360, '')
Det verkar ju funka.. Var det så du menade?
Jag får dock ett felmeddelande...
Feltyp:
Microsoft OLE DB Provider for SQL Server (0x80040E2F)
Det går inte att infoga rad med dubblettnyckel i objektet dbo.tblArticle med det unika indexet IDX_tblArticle_Nr.
/createUppdragNuDb/addUppdragNuArticles.asp, line 80
Line 80 är när jag försöker exekvera ovanstående SQL...
Det kanske inte har så mycket med frågan att göra egentligen... Jag lyckas dock inte lösa det och vet inte riktigt vad det betyder... Någon?
Henrik
Jag lyckades klura ut vad:
Feltyp:
Betydde...
Jag försökte lägga till samma artikelnummer två gånger och det går ju givetvis inte... Frågan är dock varför det blev så... Scriptet skall ju loopa ut alla artikelnummer från databasen...
Henrik
Vad gör rad 80 då?
@nders skrev:
Vad gör rad 80 då?
Det var jag som strulade till det som vanligt....
Rad 80 exekverar inserten...
Men jag hade klippt och klistart fel sql.... så när jag körde koden så försökte jag sätta in dubletter, vilket inte är tillåtet...
Har åtgärdat det nu... :)
Och jag fattade till slut vad ni menade! Det gick utmärkt att använda sig av en annan databas som hade "samma rättigheter"
Henrik
269 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
128 ms — deklarationer (db)
129 ms — ändringar (db)
