Ta fram det lägsta priset
25 svar · 1 092 visningar · startad av devotion
Hmm, har en fråga!
Jag har följande kod, Tack emission... :birp
Set objRS = Server.CreateObject("ADODB.Recordset")
objRS.Open sSQL, objConn, 3, 1
set sSuppliers=CreateObject("Scripting.Dictionary")
set sArticles=CreateObject("Scripting.Dictionary")
set sSupplierArticles=CreateObject("Scripting.Dictionary")
Do while not objRS.EOF
	sSuppliers(cstr(objRS("SupplierId"))) = cstr(objRS("SupplierName"))
	sArticles(cstr(objRS("articleName"))) = cstr(objRS("articleUnit"))
	sKey=cstr(objRS("SupplierId")) & vbTab & cstr(objRS("articleName"))
	if not sSupplierarticles.Exists(sKey) then
		set sSupplierArticles(sKey)=CreateObject("Scripting.Dictionary")
	sSupplierArticles(sKey)(cstr(objRS("articleNumber")))=Array(cdbl(objRS("articlePrice")),cstr(objRS("CategoryName")))
	objRs.MoveNext
Loop
response.write "<table><thead><tr><th>Artikelbenämning</th><th>Enhet</th>"
	for each iSupplierId in sSuppliers
		response.write "<th>" & sSuppliers(iSupplierId) & "</th>"
	next
	response.write "</tr></thead><tbody>"
	for each sArticle in sArticles
		response.write "<tr><td>" & sArticle & "</td><td>" & sArticles(sArticle) & "</td>"
			response.write "<td>"
			sKey=iSupplierId & vbTab & sArticle
			if not sSupplierArticles.Exists(sKey) then
				response.write "&nbsp;"
				response.write "<div id='result'><ul>"
				for each sSupplierarticle in sSupplierarticles(sKey)
					i = i+1
				 	if i = 1 then
					  'detta är det lägsta priset, spara undan i en variabel
					  dLowestArticlePrice = cdbl(sSupplierarticles(sKey)(sSupplierarticle)(0))
					  sFirstArticleNumber = sSupplierarticle
					dArticlePrice = cdbl(sSupplierarticles(sKey)(sSupplierarticle)(0))
					sArticleNumber = sSupplierarticle
					sArticleCategory = sSupplierarticles(sKey)(sSupplierarticle)(1)
					Response.Write "<li><span onclick=""changeValue('" & sArticleNumber & "','" & dArticlePrice & "','" & sArticleCategory & "','articleNumber')"" style=""cursor:pointer;color:blue""></span></li>"
				next
				Response.write "</ul></div>"
			response.write "<a href="""" onclick=""return showResults(event,this)"" style=""color:blue;text-decoration:none"">" & sFirstArticleNumber & " - " & dLowestArticlePrice & " kr</a><input type=""hidden"" name=""articleNumber"" value=""" & sFirstArticleNumber & """>"
			response.write "</td>"
		next
		response.write "</tr>"
	next
response.write "</tbody></table>"
objRS.Close
Set objRS = Nothing
objConn.Close
Set objConn = Nothing
set sSuppliers = Nothing
set sArticles = Nothing
set sSupplierArticles = Nothing
Jag vill få fram den första posten, dvs det lägsta priset på en artikel, men när jag gör som i ovanstående kod, så blir det det lägsta priset oberoende av leverantör.... Och det blir ju lite fel... Vad gör jag för fel?
Resultat:
http://80.73.182.130/testscript/cart_test.asp
Henrik
Snarare tvärtom väl?
Nåväl, här kommer en rejält omskriven version, med klasser i stället för arrayen som databärare. Mest i utbildningssyfte...
En trevlig bonuseffekt är att du inte behöver söka ut artiklarna i någon speciell ordning. Det lägsta priset uppfattas ändå.
Den kan kräva en del fix, för jag har ingen möjlighet att testa.
Class Article
	Public Name
	Public Unit
	Public CheapestSupplierArticle
End Class
Class SupplierArticle
	Public Article
	Public ArticleNumber
	Public CategoryName
	Public Price
	Public Supplier
End Class
Class Supplier
	Public Name
	Public Id
End Class
	supplierId=cstr(objRS("SupplierId"))
	supplierName=cstr(objRS("SupplierName"))
	articleName  =cstr(objRS("articleName"))
	articleUnit=cstr(objRS("articleUnit"))
	articlePrice=cdbl(objRS("articlePrice"))
	categoryName=cstr(objRS("CategoryName"))
	sSuppliers(supplierId) = supplierName
	articleNumber=cstr(objRS("articleNumber"))
	if not sSuppliers.Exists(supplierId) then
		set oSupplier = new Supplier
		oSupplier.Name = supplierName
		oSupplier.Id = supplierId
		set sSuppliers(supplierId)=oSupplier
		set oSupplier = sSuppliers(supplierId)
	if not sArticles.Exists(articleName) then
		set oArticle=new Article
		oArticle.Name=articleName
		oArticle.Unit=articleUnit
		set oArticle.CheapestSupplierArticle=Nothing
		set sArticles(articleName) = oArticle
		set oArticle=sArticles(articleName)
	sKey=supplierId & vbTab & articleName
	set oSupplierArticle=new SupplierArticle
	set sSupplierArticles(sKey)(articleNumber)=oSupplierArticle
	set oSupplierArticle.Article=oArticle
	set oSupplierArticle.Supplier=oSupplier
	oSupplierArticle.ArticleNumber=articleNumber
	oSupplierArticle.CategoryName=categoryName
	oSupplierArticle.Price=articlePrice
	'Ser man på! En billigare version!
	if oArticle.CheapestSupplierArticle is Nothing then
		set oArticle.CheapestSupplierArticle=oSupplierArticle
	elseif oArticle.CheapestSupplierArticle.Price>oSupplierArticle.Price then
	objRs.MoveNext
Loop
		set oSupplier=sSuppliers(iSupplierId)
		response.write "<th>" & oSupplier.Name & "</th>"
	next
		set oArticle=sArticles(sArticle)
		response.write "<tr><td>" & sArticle & "</td><td>" & oArticle.Unit & "</td>"
					set oSupplierarticle=sSupplierarticles(sKey)(sSupplierarticle)
					Response.Write "<li><span onclick=""changeValue('" & oSupplierArticle.ArticleNumber & "','" & oSupplierArticle.Price & "','" & oSupplierArticle.CategoryName & "','articleNumber')"" style=""cursor:pointer;color:blue""></span></li>"
				next
			response.write "<a href="""" onclick=""return showResults(event,this)"" style=""color:blue;text-decoration:none"">" & oArticle.CheapestSupplierArticle.ArticleNumber & " - " & oArticle.CheapestSupplierArticle.Price & " kr</a><input type=""hidden"" name=""articleNumber"" value=""" & oArticle.CheapestSupplierArticle.ArticleNumber & """>"
		next
	next
objRS.Close
Set objRS = Nothing
objConn.Close
Ja, givetvis.... :r
Men, vad fint det ser ut... Man kan väl säga att det är betydligt över min förmåga......
Har testat lite på morgonen och får följande fel:
Feltyp:
Körningsfel i Microsoft VBScript (0x800A01A8)
Objekt krävs.: '[string: "Elektroskandia"]'
/articles/cart.asp, line 74
rad 74:
mvh
Henrik
Ta bort raden
"sSuppliers(supplierId) = supplierName"
Den råkade bli kvar
Funkish!
Ska jag vara ärlig så undrade jag vad den raden gjorde där... Men jag ifrågasätter inte mästaren!
Tack som fan!
Henrik
Ps.. Bara resten kvar... ;)
hmmm...
Det blir inte helt bra:
http://80.73.182.130/articles/cart.asp
Bifaogar en dump...
Henrik
Berätta
Jo, det är ju endast det totalt sett lägsta priset som visas hos alla leverantörer... Bilden jag skickade med visar vilken information som finns om artikeln: EKKJ 1X10/10. Den har ju ett lägsta pris på 122 kr. Det är detta pris som visas hos alla leverantörer... Det skall ju vara leverantörens artikel med det lägsta priset som visas...
Henrik
Tror du det går att lösa?
Hade en tanke att lägga till ett fält i tblCart
defaultArticle
datatyp bit...
Om den är null ska det lägsta priset visas som default om den däremot är "ikryssad" ska den artikeln visas. Det kan ju finnas tillfällen då man inte vill jämföra med det billigaste utan vill ha en dyrare, och kanske bättre, vara...
Edit//Se nedan!
Henrik
Gjorde en tabell till istället...
tblDefaultArticle
*supplierId
*userId
*defaultArticleNumber
*defaultArticle (bit)
Så nu ser SQL-frågan ut så här:
sSQL = 	"SELECT tblArticle.articleName, tblArticle.articleUnit, tblPrice.articlePrice, tblSupplier.SupplierName, " &_
	"tblCart.articleAmount, tblSupplier.SupplierId, tblCategory.CategoryName, tblPrice.articleNumber, tblDefaultArticle.defaultArticle " &_
	"FROM tblArticle " &_
	"INNER JOIN tblPrice ON tblArticle.articlenumber = tblPrice.articleNumber " &_
	"INNER JOIN tblSupplier ON tblPrice.articleSupplierId = tblSupplier.SupplierId " &_
	"INNER JOIN tblCart ON tblArticle.articleName = tblCart.articleName " &_
	"INNER JOIN tblCategory ON tblPrice.articleSupplierId = tblCategory.supplierId AND tblPrice.articleCategoryNumber = tblCategory.categoryNumber " &_
	"LEFT OUTER JOIN tblDefaultArticle ON tblPrice.articleSupplierId = tblDefaultArticle.supplierId AND tblPrice.articleNumber = tblDefaultArticle.defaultArticleNumber "&_
	"ORDER BY tblPrice.articlePrice"
Är ingen artikel vald som default är det Null annars 1
Henrik
Det går att lösa, men nu måste jag nanna. Kan ta tag i det på lördag.
Coolt! :)
Words like violence
Break the silence
Henrik
Hej igen!
Nu blir resultatet så här:
Och det ser ju fint ut...
Det som dock inte stämmer är att det är det lägsta priset totalt sett som visas...
Henrik
Class Product
	Public Name
	Public Unit
End Class
Class SupplierProduct
	Public Product
	Public CheapestArticle
	Public Supplier
	Public Articles
	Private Sub Class_Initialize
		Set Articles=CreateObject("Scripting.Dictionary")
		Set CheapestArticle=Nothing
	End Sub
End Class
	Public SupplierProduct
	Public CategoryName
	Public Price
End Class
Class Supplier
	Public Name
	Public Id
End Class
set sProducts = CreateObject("Scripting.Dictionary")
set sSupplierProducts=CreateObject("Scripting.Dictionary")
	if not sProducts.Exists(articleName) then
		set oProduct = new Article
		oProduct.Name=articleName
		oProduct.Unit=articleUnit
		set sProducts(articleName) = oProduct
		set oProduct=sProducts(articleName)
	if not sSupplierProducts.Exists(sKey) then
		set oSupplierProduct=new SupplierProduct
		set oSupplierProduct.Product=oProduct
		set oSupplierProduct.Supplier=oSupplier
		set sSupplierProducts(sKey)=oSupplierProduct
		set oSupplierProduct=sSupplierProducts(sKey)
	set oSupplierArticle.SupplierProduct=oSupplierProduct
	if oSupplierProduct.CheapestArticle is nothing then
		set oSupplierProduct.CheapestArticle=oSupplierArticle
	else if oSupplierProduct.CheapestArticle.Price>oSupplierArticle.Price then
	oSupplierProduct.Articles(articleNumber)=oSupplierArticle
	objRs.MoveNext
Loop
	next
	for each sArticleName in sProducts
		set oProduct=sProducts(sArticleName)
		response.write "<tr><td>" & sArticleName & "</td><td>" & oProduct.Unit & "</td>"
			sKey=iSupplierId & vbTab & sArticleName
				for each sSupplierarticle in oSupplierProduct.Articles
					set oSupplierarticle=oSupplierProduct.Articles(sSupplierarticle)
				next
				response.write "<a href="""" onclick=""return showResults(event,this)"" style=""color:blue;text-decoration:none"">" & oSupplierProduct.CheapestArticle.ArticleNumber & " - " & oSupplierProduct.CheapestArticle.Price & " kr</a><input type=""hidden"" name=""articleNumber"" value=""" & oSupplierProduct.CheapestArticle.ArticleNumber & """>"
		next
	next
objRS.Close
Set objRS = Nothing
objConn.Close
Säkert med en del fel, men det kan vara en utgångspunkt.
Hej! :)
Tar denna koden hänsyn till om en annan artikel än den lägsta är vald som default enligt:
http://www.webforum.nu/showthread.php?p=1200358#post1200358
Har inte riktigt fått igång det än men jag provar och försöker!
Tack för all hjälp; emission! :)
Henrik
Hmmm, jag får detta felet..:
Feltyp:
Kompileringsfel i Microsoft VBScript (0x800A040E)
'loop' utan 'do'
/testscript/cart_2.asp, line 184
Loop
Jag tycker dock det ser rätt ut.... (mend et är det ju inte eftersom jag får ett felmeddelande.. ;)
<%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%>
<% 'Option Explicit %>
<title>Untitled Document</title>
var prevElm;
function showResults(e,a)
  var left, top;
  if (window.event){
    left = window.event.clientX;
    top  = window.event.clientY;
  } else if (e){
    left = e.pageX;
    top  = e.pageY;
  if (left && top){
	if (prevElm)
		prevElm.style.visibility = "hidden";
    window["a"] = a;
    elm.style.left = left + "px";
    elm.style.top  = top + "px";
    elm.style.visibility = "visible";
  return false;
function chooseResultContainer(id)
  prevElm = window["elm"];
  window["elm"] = document.getElementById(id);
document.onclick = function(e)
  var tmp = window.event ? window.event.srcElement : e ? e.target : 0,
      fnd = false;
  if (tmp){
    while (tmp){
      if (tmp == elm || (typeof a != "undefined" && tmp == a)) {
        fnd = true;
        break;
      tmp = tmp.parentNode;
  if (!fnd) elm.style.visibility = "hidden";
function changeValue(p,c,s,i,linkid)
  if (a && elm){
    a.innerHTML = p + " - " + c + " kr";
    document.forms[0].elements[i].value = c;
    elm.style.visibility="hidden";
    document.getElementById('link'+linkid).title=s;
    document.getElementById('link'+linkid).style.color="pink";
<link href="../css/cart.css" rel="stylesheet" type="text/css" />
<body>
'Deklarera variabler
Dim objConn, objRS, objDict, sSQL, sSuppliers, sSupplierArticles, sArticles, sKey, iSupplierId, sArticle, sSupplierarticle
iResultCount = 0
' Öppna databasen
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.ConnectionString = Application("sConn")
objConn.Open
Class Product
	Public Name
	Public Unit
End Class
	Public Product
	Public Supplier
	Public Articles
	End Sub
End Class
	Public CategoryName
	Public Price
End Class
Class Supplier
	Public Name
	Public Id
End Class
	objRs.MoveNext
[B]Rad 184---> Loop	[/B]
	next
				next
		next
	next
objRS.Close
Set objRS = Nothing
objConn.Close
</html>
Henrik
	[b]else if[/b] oSupplierProduct.CheapestArticle.Price...
	[b]elseif[/b] oSupplierProduct.CheapestArticle.Price...
Aha!
Det kund eman ju nästan sett själv.. :(
Tack schnabeln!
Nu kom det dock ett annat fel..
Körningsfel i Microsoft VBScript (0x800A01FA)
Klass har inte definierats: 'Article'
/testscript/cart_2.asp, line 149
Testar och letar vidare ... :)
Henrik
Det ska inte vara "New Product" då, eftersom det är det emission (dvs du) kallat klassen?
Aha!
Classen Article var definierad som product... Ändrade till Article
Class product
	Public Name
	Public Unit
End Class
till
Class Article
	Public Name
	Public Unit
End Class
till
då fick jag istället följande fel:
Feltyp:
Körningsfel i Microsoft VBScript (0x800A01B6)
Objektet stöder inte egenskapen eller metoden.
/testscript/cart_2.asp, line 181
det berodde på att
skulle ändras till:
set oSupplierProduct.Articles(articleNumber)=oSupplierArticle
så nu verkar det funka fint tror jag... tets och provar mer! ... :)
Då skulle man bara fått in det där emd default artticle oxå..... ;)
Henrik
274 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
119 ms — deklarationer (db)
142 ms — hämta tråd, inlägg och bilagor (db)
129 ms — ändringar (db)
