Dictionary eller nått annat fint
40 svar · 1 452 visningar · startad av devotion
Hej :(
Skulle bli väldans glad om någon kunde hjälpa mig med detta...
Har följande kod som loopar ut artiklar
'Deklarera variabler
Dim objConn, objRS, objDict, sSQL, dArticlePrice, sCategoryName, sArticleNumber, sArticleName, sArticleUnit, iSupplierId, sSupplierName
' Öppna databasen
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.ConnectionString = Application("sConn")
objConn.Open
sSQL = 	"SELECT tblArticle.articleName, tblArticle.articleUnit, tblPrice.articlePrice, tblSupplier.SupplierName, " &_
		"tblCart.articleAmount, tblSupplier.SupplierId, tblCategory.CategoryName, tblPrice.articleNumber " &_
		"FROM tblArticle " &_
		"INNER JOIN tblPrice ON tblArticle.articlenumber = tblPrice.articleNumber " &_
		"INNER JOIN tblSupplier ON tblPrice.articleSupplierId = tblSupplier.SupplierId " &_
		"INNER JOIN tblCart ON tblArticle.articleName = tblCart.articleName " &_
		"INNER JOIN tblCategory ON tblPrice.articleSupplierId = tblCategory.supplierId AND tblPrice.articleCategoryNumber = tblCategory.categoryNumber " &_
		"ORDER BY tblPrice.articlePrice"
Set objRS = Server.CreateObject("ADODB.Recordset")
objRS.Open sSQL, objConn, 3, 1
Do while not objRS.EOF
	dArticlePrice =  cdbl(objRS("articlePrice"))
	sCategoryName = objRS("CategoryName")
	sArticleNumber = objRS("articleNumber")
	sArticleName = 	objRS("articleName")
	sArticleUnit = 	objRS("articleUnit")
	iSupplierId = objRS("SupplierId")
	sSupplierName = objRS("SupplierName")
	dArticlePrice = objRS("articlePrice")
	Response.write "Artikelnummer: " & sArticleNumber & " Artikelbenämning: " & sArticleName & " Leverantör: " & sSupplierName & " Pris: " & dArticlePrice & "<br>"
	objRS.MoveNext
Loop
objRS.Close
Set objRS = Nothing
objConn.Close
Set objConn = Nothing
Resultatet blir:
http://80.73.182.130/testscript/dictionary.asp
Kan man inte använda dictionaryobjeketet och göra så resultatet blir så här:
http://80.73.182.130/testscript/resultat.asp
eller ännu hellre slippa listrutorna och göra så det blir så här:
http://80.73.182.130/testscript/ruta.asp
enligt denna tråd:
http://www.webforum.nu/showthread.php?p=1198146#post1198146
Är mycket tacksam för en spark i rätt riktning.. :)
Henrik
Vilka datamängder talar vi om? Kommer det oftast att röra sig om 2 produkter? 100? 1000?
Om du med datamängder menar antalet artiklar i listan, kan det kanske röra sig om 100-200 max. Tanken är ju ett prisjämförelsesystem. Tex dra el i ett garage... Välja de artiklar som behövs och på så sätt få fram den billigaste leverantörern....
MVH
Henrik
Ok, ja då kan det vara funkis med ett par Dictionaries.
Loopa igenom resultatet och bygg samtidigt upp tre Dictionaries.
set suppliers=CreateObject("Scripting.Dictionary")
set articles=CreateObject("Scripting.Dictionary")
set supplierarticles=CreateObject("Scripting.Dictionary")
	suppliers(cstr(objRS("SupplierId"))) = cstr(objRS("SupplierName"))
	articles(cstr(objRS("articleName"))) = cstr(objRS("articleUnit"))
	key=cstr(objRS("SupplierId")) & vbTab & cstr(objRS("articleName"))
	if not supplierarticles.Exists(key) then
		supplierarticles(key)=CreateObject("Scripting.Dictionary")
	supplierarticles(key)(cstr(objRS("articleNumber")))=cdbl(objRS("articlePrice"))
	response.write "<table><tr><td>Artikelbenämning</td><td>Enhet</td>"
	for each supplierId in suppliers
		response.write "<td>" & suppliers(supplierId) & "</td>"
	next
	response.write "</tr>"
	for each article in articles
		response.write "<tr><td>" & article & "</td><td>" & articles(article) & "<td>"
			key=supplierId & vbTab & article
				response.write "&nbsp;"
				for each supplierarticle in supplierarticles(key)
					response.write supplierarticle & ":" & supplierarticles(key)(supplierarticle) & "<br>"
				next
			response.write "</td>
		next
	next
	response.write "</table>"
Loop
Med reservation för syntaxfel.
Gud hör bön..;)
Tack så mycket emission...
Men jag fick följande fel:
Feltyp:
Körningsfel i Microsoft VBScript (0x800A01C2)
Fel antal argument eller felaktig egenskapstilldelning.
/testscript/dictionary.asp, line 43
Rad 43:
Henrik
set supplierarticles(key)=CreateObject("Scripting.Dictionary")
aha! Okej!
Nu fick jag detta felmeddelande:
Feltyp:
Response-objekt, ASP 0104 (0x80070057)
Operationen är inte tillåten
Vad betyder det?
Henrik
Det kanske betyder att du glömt movenext i din loop? :)
My bad, jag klippte bort den.
Jo det var det ju... :r
Ska titta lite på resultatet.. det är siffror och text överallt:
Koden ser ut så här:
set supplierArticles=CreateObject("Scripting.Dictionary")
		set supplierArticles(key)=CreateObject("Scripting.Dictionary")
	supplierArticles(key)(cstr(objRS("articleNumber")))=cdbl(objRS("articlePrice"))
	next
			if not supplierArticles.Exists(key) then
				next
			response.write "</td>"
		next
	next
	objRs.MoveNext
Loop
objRS.Close
Set objRS = Nothing
objConn.Close
Henrik
Det ser lite struligt ut.... ska det inte bara vara två rader.... Det är ju bara två artiklar.
Sen är det nog lite förskjutet i sidled....
Men. grunden verakr vara där iaf... (Y) :)
Lade till en css för lite bättre läsbarhet..
Henrik
Loopen hamnade ju lite snett...sorry
	objRs.MoveNext
Loop
	next
				next
		next
	next
objRS.Close
Set objRS = Nothing
objConn.Close
Weeee!
Nu blir det ju kanon! :)
Men varför är tabellrubrikerna förskjutna? Annars är det ju perfekt! (y)
Henrik
Borde inte:
& article & "</td><td>" & articles(article) & [b]"<td>"[/b]
vara:
& article & "</td><td>" & articles(article) & [b]"</td>"[/b]
:r
Givetvis.....
Funkar finfint... Man blir nästan tårögd.... (y) (y)
Tack emission och @nders....
Henrik
Hej igen!
Nu ser koden ut så här:
Dim objConn, objRS, objDict, sSQL, sSuppliers, sSupplierArticles, sArticles, sKey, iSupplierId, sArticle, sSupplierarticle
' Öppna databasen
objConn.Open
set sSuppliers=CreateObject("Scripting.Dictionary")
set sArticles=CreateObject("Scripting.Dictionary")
set sSupplierArticles=CreateObject("Scripting.Dictionary")
	sSuppliers(cstr(objRS("SupplierId"))) = cstr(objRS("SupplierName"))
	sArticles(cstr(objRS("articleName"))) = cstr(objRS("articleUnit"))
	sKey=cstr(objRS("SupplierId")) & vbTab & cstr(objRS("articleName"))
	if not sSupplierarticles.Exists(sKey) then
		set sSupplierArticles(sKey)=CreateObject("Scripting.Dictionary")
	sSupplierArticles(sKey)(cstr(objRS("articleNumber")))=cdbl(objRS("articlePrice"))
	objRs.MoveNext
Loop
response.write "<table border='1'><tr><td>Artikelbenämning</td><td>Enhet</td>"
	for each iSupplierId in sSuppliers
		response.write "<td>" & sSuppliers(iSupplierId) & "</td>"
	next
	for each sArticle in sArticles
		response.write "<tr><td>" & sArticle & "</td><td>" & sArticles(sArticle) & "</td>"
			skey=iSupplierId & vbTab & sArticle
			if not sSupplierArticles.Exists(sKey) then
				for each sSupplierarticle in sSupplierarticles(sKey)
					response.write sSupplierarticle & ":" & sSupplierarticles(sKey)(sSupplierarticle) & "<br>"
				next
		next
	next
objRS.Close
Set objRS = Nothing
objConn.Close
set sSuppliers = Nothing
set sArticles = Nothing
set sSupplierArticles = Nothing
Funkar kanon!
Emission! Om du har tid och lust får du gärna kommentera koden, vad den gör så att säga. Så jag lär mig något och sliper fråga igen... ;)
Tack igen! Webforum rockar..(y)
Henrik
Hmmm.. kom på en sak... :)
Om jag vill ha med artikelkategorin också... categoryName Hur gör jag för att lägga till den informationen i
och
next
Henrik
Självklart! Rätt inställning!
'Skapa tre dictionaries
'Detta ska innehålla leveratörerna
'Detta ska innehålla artiklarna
'Detta ska innehålla leveratörernas artiklar
'Loopa igenom recordset för att fylla på "dictionarierna" :)
	'Stoppa in en leverantör, med SupplierId som nyckel. Om samma leverantör kommer flera gånger i recordsetet så skriver den bara över. Ingen ny rad läggs till.
	'Stoppa in en artikel, med articleName (i brist på annan identifierare) som nyckel. Om samma artikel kommer flera gånger i recordsetet så skriver den bara över. Ingen ny rad läggs till.
	'Värdet sätter vi till articleUnit
	'Skapa en nyckel som är sammansatt av SupplierId och articleName. Avgränsa med en Tab, så att t.ex. SupplierId=1,articleName="11" skiljer sig från SupplierId=11,articleName="1"
	'Detta dictionary (sSupplierarticles) innehåller i sin tur flera egna dictionaries, eftersom en leverantör kan ha flera olika artiklar relaterade till gällande articleName
	'Om det är första gången, skapa ett nytt dictionary
	'Lägg till en rad, med articleNumber som nyckel och priset som värde
	objRs.MoveNext
Loop
'Starta tabellen
	'Loopa igenom alla leverantörer. När man kör "for each" på Scripting.Dictionary så får man nyckelvärdet som iterationsvariabel, i detta fall det SupplierId som vi stoppade in
	next
	'Loopa igenom artiklarna
		'Loopa än en gång igenom leverantörerna, för att bygga tabellen i sidled
			'Återskapa nyckeln som plockar fram den specifika artikellistan
			'Det är ju tänkbart att leverantören inte lagerför artikeln, och i så fall måste vi hantera det. Dictionaryt blir gramse om man försöker plocka ut ett värde som inte finns, därav Exists.
				'Tjoho! Det fanns artiklar! Låtom oss loopa igenom dessa.
				'I stället för att köra med sSupplierarticles(sKey)(sSupplierarticle) så hade man kunnat mellanlagra
				'set articleDict=sSupplierarticles(sKey)
				'for each sSupplierarticle in articleDict
				'	response.write sSupplierarticle & ":" & articleDict(sSupplierarticle) & "<br>"
				'next
				next
		next
	next
'Over and out
och
next
Henrik
sArticles(cstr(objRS("articleName"))) = Array(cstr(objRS("articleUnit")),cstr(objRS("categoryName")))
och därefter plockar du ut enheten med
sArticles(sArticle)(0)
och kategorin med
sArticles(sArticle)(1)
Tack för det... då ska jag se om jag lyckas lägga till categoryName, enligt mitt förra inlägg..;)
Henrik
282 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
130 ms — deklarationer (db)
144 ms — hämta tråd, inlägg och bilagor (db)
122 ms — ändringar (db)
