radera alla filer i en mapp
4 svar · 311 visningar · startad av devotion
Hur raderar jag alla filer i en angiven mapp?
Henrik
Tjena :)
Testa detta. Paramtern i funktionsanropet specificerar vilken katalog som du vill ta bort alla filer i.
Google Says.. skrev:
Public Function DeleteAllFiles(ByVal FolderSpec As String) _
  As Boolean
'Deletes all files in folder specified
'by parameter FolderSpec.  Does not delete
'subfolders or files within subfolders
'Returns True if sucessful, false otherwise
'Requires a reference the Microsoft Scripting Runtime
'EXAMPLE: DeleteAllFiles "C:\Test"
Dim oFs As New FileSystemObject
Dim oFolder As Folder
Dim oFile As File
If oFs.FolderExists(FolderSpec) Then
    Set oFolder = oFs.GetFolder(FolderSpec)
    On Error Resume Next
    For Each oFile In oFolder.Files
        oFile.Delete True 'setting force to true
                        'deletes read-only file
    Next
    DeleteAllFiles = oFolder.Files.Count = 0
End Function
Testar!
Henrik
Fast å andra sidan hade aktiviteten i denna forum-del varit ganska mycket lägre om alla bara googlade :e
hehe... :D
//Henrik
123 ms — deklarationer (db)
133 ms — ändringar (db)
