stul med aspUpload
1 svar · 251 visningar · startad av WebbisNet
WebbisNetMedlem sedan feb. 20032 027 inlägg
Denna kod har funkat helt utmärkt men strular nu
Set Upload = Server.CreateObject("Persits.Upload")
Upload.OverwriteFiles = False
Upload.SetMaxSize 100000, False
Count=Upload.Save(Server.MapPath("/images/gallery"))
For Each file In Upload.Files
  If File.ImageType = "UNKNOWN" Then
      Response.Redirect "/pictureupload/gallery/?error=filetype"
      File.Delete
  Next
If file.Size = 100000 Then
        Response.Redirect "/pictureupload/gallery/?error=fileTooBig"
    File.Delete
Next
Set File = Upload.Files
rubrik = replace(Upload.form("txtRubrik"),"'","''")
kommentar = replace(Upload.form("txtKommentar"),"'","''")
If NOT File Is Nothing Then
On Error Resume Next
strFileName= Upload.Files("blob").ExtractFileName
END IF
Persits.Upload.1 error '800a0005'
The system cannot find the file specified.
/pictureupload/gallery/persist.asp, line 7
Rad7 är Count=Upload.Save(Server.MapPath("/images/gallery"))
och om jag använder aspSmartUpload så får jag
aspSmartUpload.File error '80040460'
Unable to save file (Error 1120)
/pictureupload/gallery/persist.asp, line 18
Rad 18 är
file.SaveAs("/images/gallery/" & file.Name & "." & file.FileExt & "")
med denna kod
 Dim mySmartUpload
   Dim file
   Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
   mySmartUpload.AllowedFilesList = "jpg,png"
   mySmartUpload.DenyPhysicalPath = True
   mySmartUpload.MaxFileSize = 100000
   mySmartUpload.Upload
   Set file = mySmartUpload.Files("blob")
    If file.IsMissing Then
        Response.Write("Filen saknas!<BR>")
    Else
        strFil = file.FileName
        'Response.Write("Name = " & file.Name & "<BR>")
        'Response.Write("Size = " & file.Size & "<BR>")
        'Response.Write("FileName = " & file.FileName & "<BR>")
        'Response.Write("FileExt = " & file.FileExt & "<BR>")
jag får med filnamnet, ser det när jag skriver ut strFil, men därefter är det stopp
response.write strFil
'response.end
file.SaveAs("/images/gallery/" & strFil &"")
128 ms totalt · 3 externa anrop · v20260731065814-full.86db40fa
