Har för mig att det går att använda excel som en databas att läsa data ur.
Hur kopplar man upp sig mot en excelfil? Använder man vanliga sql frågor?
4 svar · 564 visningar · startad av Mattias Nordin
Kul att det är möjligt. Men jag får ett fel med nedan...
' Selected constants from adovbs.inc
Const adOpenStatic = 3
Const adLockPessimistic = 2
Dim cnnExcel
Dim rstExcel
Dim I
Dim iCols
' This is all standard ADO except for the connection string.
' You can also use a DSN instead, but so it'll run out of the
' box on your machine I'm using the string instead.
Set cnnExcel = Server.CreateObject("ADODB.Connection")
[b]cnnExcel.Open "DBQ=" & Server.MapPath("derivat.xls") & ";" & _[/b]
"DRIVER={Microsoft Excel Driver (*.xls)};"
' Same as any other data source.
' FYI: TestData is my named range in the Excel file
Set rstExcel = Server.CreateObject("ADODB.Recordset")
rstExcel.Open "SELECT * FROM TestData;", cnnExcel, _
adOpenStatic, adLockPessimistic
' Get a count of the fields and subtract one since we start
' counting from 0.
iCols = rstExcel.Fields.Count
<table border="1">
<thead>
' Show the names that are contained in the first row
' of the named range. Make sure you include them in
' your range when you create it.
For I = 0 To iCols - 1
Response.Write "<th>"
Response.Write rstExcel.Fields.Item(I).Name
Response.Write "</th>" & vbCrLf
Next 'I
</thead>
rstExcel.MoveFirst
' Loop through the data rows showing data in an HTML table.
Do While Not rstExcel.EOF
Response.Write "<tr>" & vbCrLf
Response.Write "<td>"
Response.Write rstExcel.Fields.Item(I).Value
Response.Write "</td>" & vbCrLf
Next 'I
Response.Write "</tr>" & vbCrLf
rstExcel.MoveNext
Loop
</table>
rstExcel.Close
Set rstExcel = Nothing
cnnExcel.Close
Set cnnExcel = Nothing
ger för mig...
Microsoft OLE DB Provider for ODBC Drivers error '80040e21'
ODBC driver does not support the requested properties.
/tab_products/sales_marketing/crm_related_info/create_derivat_table/create_table.asp, line 28
Följande fungerar...
Dim objConn
Dim objRS
Set objConn = CreateObject("ADODB.Connection")
objConn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=D:\servernsLokalaSökväg\book1.xls ;Extended Properties=Excel 8.0;"
'or could use -> objConn.Open "DBQ=C:\Data\Book1.xls;DRIVER={Microsoft Excel Driver (*.xls)};"
'With Excel & ADO, you work with the sheet as a table
Set objRS = objConn.Execute("select * from [Sheet1$]") %>
<table border=1>
<% while not objRS.eof %>
<tr>
<% For X = 0 To objRS.Fields.Count - 1 %>
<td>
<%=objRS.Fields.Item(X).Name%><br>
</td>
<% Next %>
</tr>
<% objRs.MoveNext
Wend
objRs.Close %>
</table>
<% Set objRS = Nothing
objConn.Close
Set objConn = Nothing %>
Det enda som jag inte förstår är varför det första fältet alltid får bokstaven F framför datan i exceldokumentet. Hmm....
<%Dim objConn
Dim objRS
objConn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=D:\webroot\blaj\book1.xls ;Extended Properties=Excel 8.0;"
<table border=1>
<%'*** SKAPAR HEADERN ***' %>
<tr>
<td>
<%=objRS.Fields.Item(X).name%><br>
</td>
<% Next %>
</tr>
<%'*** SKAPAR INNEHÅLLET ***' %>
<% while not objRs.eof %>
<tr>
<td>
<%=objRS.Fields.Item(X)%><br>
</td>
<% Next %>
</tr>
<%objRs.MoveNext
Wend %>
</table>
<% objRs.Close
Set objRS = Nothing
objConn.Close
