Hej
Jag har fått problem med ett sökscript
Följande kod använder jag:
Dim Con
Dim SQL
Dim RS
Set Con = Server.CreateObject("ADODB.Connection")
Con.Open "DBQ=" & Server.MapPath("../db/databas.mdb") & ";Driver={Microsoft Access Driver (*.mdb)};"
<html>
<body bgcolor="#FFFFFF" link="#000000" vlink="#000000" alink="#000000" style="font-family: Verdana; font-size: 10pt">
<table border="0" cellpadding="0" style="border-collapse: collapse" bordercolor="#111111" width="130" id="table1">
<tr>
<td width="100%" style="border-top-style: none; border-top-width: medium" class="td2">
<form action="sok.asp" method="post">
<font face="Verdana">
<input class="form" type="text" name="sokord" size="17">
<input class="knapp" type="submit" value="Sök"><br>
</font></form>
</td>
</tr>
<tr>
<td width="100%" class="rum" style="font-size: 10pt; font-family: Verdana"></td>
</tr>
</table>
<font face="Verdana" size="2">
If Request.Form("sokord") <> "" Then
Response.Write "<table border=0 cellpadding=0 cellspacing=0 style=border-collapse: collapse bordercolor=#111111 width=400>"
Response.Write "<tr>"
Response.Write "<td width=100% class=rubrik1 style=border-style: solid; border-width: 1>"
Response.Write "Sökningen efter <i>" & Request.Form("sokord") & "</i> gav följande träffar.<br>" & vbCrLf
Response.Write "</td>"
Response.Write "</tr>"
Response.Write "<td width=100% style=border-top-style: solid; border-top-width: 1 class=td2>"
SQL = "Select * from spelare Where Text Like '%" & Request.Form("sokord") & "%' "
SET RS = Con.Execute(SQL)
While Not RS.EOF
Response.Write "<font class=text>"
Response.Write "<b>" & RS("Rubrik") & "</b><br>" & vbCrLf
Response.Write "" & RS("namn") & " "
Response.Write "<a href='fakta.asp?visa=" & RS("ID") & "'>Läs mer!</a><br><br>"
RS.MoveNext
Wend
RS.Close
Set RS = Nothing
Response.Write "</table>"
Response.Write "</div>"
</font>
</html>
Con.Close
Set Con = Nothing
problemet är att det man söker efter inte går att hitta, även att ordet man söker efter finns med i kolumnen i databasen den söker i.
Vad kan det vara för fel??
Tacksam för all hjälp jag kan få :r
