Sök Problem!!
7 svar · 409 visningar · startad av Vinnaren
VinnarenMedlem sedan sep. 2005833 inlägg
Hej
Jag har fått problem med ett sökscript
Följande kod använder jag:
Dim Con
Dim SQL
Dim RS
Set Con = Server.CreateObject("ADODB.Connection")
Con.Open "DBQ=" & Server.MapPath("../db/databas.mdb") & ";Driver={Microsoft Access Driver (*.mdb)};"
<html>
<body bgcolor="#FFFFFF" link="#000000" vlink="#000000" alink="#000000" style="font-family: Verdana; font-size: 10pt">
<table border="0" cellpadding="0" style="border-collapse: collapse" bordercolor="#111111" width="130" id="table1">
  <tr>
    <td width="100%" style="border-top-style: none; border-top-width: medium" class="td2">
<form action="sok.asp" method="post">
<font face="Verdana">
<input class="form" type="text" name="sokord" size="17">
<input class="knapp" type="submit" value="Sök"><br>
&nbsp;</font></form>
    </td>
  </tr>
  <tr>
    <td width="100%" class="rum" style="font-size: 10pt; font-family: Verdana"></td>
  </tr>
</table>
<font face="Verdana" size="2">
If Request.Form("sokord") <> "" Then
    Response.Write "<table border=0 cellpadding=0 cellspacing=0 style=border-collapse: collapse bordercolor=#111111 width=400>"
    Response.Write "<tr>"
    Response.Write "<td width=100% class=rubrik1 style=border-style: solid; border-width: 1>"
    Response.Write "Sökningen efter <i>" & Request.Form("sokord") & "</i> gav följande träffar.<br>" & vbCrLf
    Response.Write "</td>"
    Response.Write "</tr>"
    Response.Write "<td width=100% style=border-top-style: solid; border-top-width: 1 class=td2>"
    SQL = "Select * from spelare Where Text Like '%" & Request.Form("sokord") & "%' "
    SET RS = Con.Execute(SQL)
    While Not RS.EOF
    Response.Write "<font class=text>"
    Response.Write "<b>" & RS("Rubrik") & "</b><br>" & vbCrLf
    Response.Write "" & RS("namn") & "&nbsp;"
    Response.Write "<a href='fakta.asp?visa=" & RS("ID") & "'>Läs mer!</a><br><br>"
    RS.MoveNext
    Wend
    RS.Close
    Set RS = Nothing
    Response.Write "</table>"
    Response.Write "</div>"
</font>
</html>
Con.Close
Set Con = Nothing
problemet är att det man söker efter inte går att hitta, även att ordet man söker efter finns med i kolumnen i databasen den söker i.
Vad kan det vara för fel??
Tacksam för all hjälp jag kan få :r
HermanMedlem sedan maj 2001431 inlägg
hmm va knasigt!
du kan ju testa att skriva ut SQL-uttrycket och se om det verkar rimligt.
Du borde få ett felmeddelande eftersom Text är ett reserverat ord (datatyp). Byt namn på fältet.
Dessutom: när du postar kod, gör det med [kod]-taggar, så blir saker och ting lättare att läsa.
något felmeddelande får jag inte. Men när jag söker på tex "a" så kommer typ alla poster upp som finns i tabellen. men söker man på ett ord så kommer det inget fram, mer än att det inte hittades :OO
Prova då att skriva ut sql-frågan, som Herman skriver. Prova att köra SQL-frågan direkt i Access, för att se om det blir någon skillnad.
ok, men hur ska frågan se ut?? är nybörjare på detta :stud
Har provat med
SELECT *FROM spelare WHERE Text Like oskar;
men fick ingen träff, även att han ska finnas med :l
vet inte om jag skrev rätt??
Den SQL-frågan borde inte heller fungera, du borde få ett felmeddelande alt. en förfrågan om att fylla i värde för okänt fält (oskar).
SQL-frågan bör se ut ungefär som i ditt inlägg ovan, och den bör fungera, under förutsättning att du får rätt data från formuläret. Så: skriv ut SQL-frågan med response.write, så är det lättare att se om något är fel.
Nej, du saknar apostrofer runt sökordet, och också wildcards.
ok, tror jag har hittat felet :OO Lite klantigt kanske ;)
Man sökte i fel kolumn, var därför jag inte fick några träffar.
Men tack för all hjälp :bire
137 ms totalt · 3 externa anrop · v20260731065814-full.fb544a5a
